kgg
Contributing Member
Everything posted by kgg
  1. All the machines you have been looking at a mostly used in the home garment area. To do upholstery reliably you need to move up to a walking foot machine. On the lower end of the price scale look for a portable walking foot like the Reliable Barracuda which can handle up to V138 thread and can be purchased at your local Home Depot store for about $500 US. kgg
  2. My experience with bird nesting (thread gathering on the underside) is that it has more to do with bobbin thread tension issues then the top thread tension. A lot of times it can be as simple as the bobbin being place in the bobbin holder incorrectly so the bobbin thread is unwinding in the wrong direction. Done that more then once myself. The needle size and needle could also be a culprit. Needle maybe damaged / bent / have a burr / installed incorrectly or incorrect size for thread size being used. For needle size reference I would look at the Toledo Sewing Chart ( https://www.tolindsewmach.com/thread-chart.html ) to see what size needle should be used for your thread. kgg
  3. If the presser foot has to much downward tension this can easily be adjusted by the presser foot tension knob. If the presser foot is too aggressive it can either be changed to a smoother foot or the teeth be filed smoother. I think for the thickness you mentioned the the Juki 1541, will do the job and give you the option of thicker materials in the future as it is compound feed (feed dog, presser foot and needle). I have to be careful with thinner materials with my Juki1541S and do the necessary adjustments to thread tensions and presser foot tension. That said it likes thicker stuff and will sew whatever I can stuff under the presser foot. The Consew 206RB-3 is I think a compound feed machine as well. In my opinion given the choice between a Juki or a clone in the same mechanical shape I would pick the Juki. If you come across a used machine be prepared to put a servo motor on it for better sewing control, they are much quieter then a clutch motor and more energy efficient. kgg
  4. Question AusSimon what are you or planning on making? Since you have been using a 4411 with a degree of success moving up to a basic walking foot maybe all that you need. Example would be a basic portable walking foot like a new Reliable Barracuda (~$650 CA) or a new industrial walking foot like a Juki DU 1181 (~$1400 CA). kgg
  5. I am going to assume you are using V69 thread. My suggestion would be try a sample with the leather on top, 1/2" foam layer next and a sheet of ordinary paper on the bottom. If that works the paper can be torn off latter. Another suggestion would be to back off the presser foot tension so the material just moves rather then trying to compress it so much and use the largest leather needle you can get. kgg
  6. To sew the thickness of leather you noted you need heavy iron which does take space. Mounting a machine on a table with wheels and having a smaller foot print may help. The only other option is maybe a one armed bandit like the Outlaw but they still will require a fair bit of working space. kgg
  7. Just to add to the confusion when you by a servo motor you need to know if it is rated using the Metric horsepower or the Imperial horsepower rating. Imperial HP has 745.7 watts and the Metric HP is 735.5 watts. Maybe the horses in the metric countries were a touch smaller and a little less powerful. haha kgg
  8. It I think will come down to your thread size that you want to use. The machines that you have listed are going to limit you to small thread sizes range. Have you considered a patcher like the Cowboy CB29 that will allow you to sewing in tighter spots and use up to V138 thread? kgg
  9. My bad, you are correct. kgg
  10. I feel your pain, there is never going to be a exact conversion between Metric and English measurements. In Canada we often buy items that are weighted in pounds but priced in kilograms, lumber is still mostly English while liquids are metric (1 litre = 1.057 US quarts or 0.88 Imperial quarts). Can get a bit confusing. The best you can hope for are approximate conversion values. The easiest thing is to get a good metric ruler / tape /meter stick (.9144 yards) and forget about trying convert, it will just drive you crazy. Personally I prefer the Imperial measurements. kgg
  11. If you are looking for a nice backup machine that won't take up much space I would suggest looking for a used portable walking foot machine. Like the Reliable Barracuda, Sailrite, Techsew 611 to name a some. kgg
  12. Buy a Juki that fits your present and foreseeable future needs. Buy Once, Cry Once kgg
  13. Like the idea. Maybe if you used a larger calibre spent casing like a 45-70 it could be used in the construction of a belt. Seating the bottom cutoff of the casing so the prong of the belt buckle would go through the primer hole rather than just the normal hole in the leather. What a shame. kgg
  14. That sounds about right. The size of cone you are using is approximately 4 oz. There has be discussion on the problems associated with the 8 oz cones particularly black in colour from China in the past. I can see that the problems would be that much greater particularly when you get down towards the last 10 to 20 % with such a small cone. I would suggest replacing the thread cone with a new one of a larger size (1 lb would be best), check the needle and size of needle making sure it is fully seated and installed correctly. kgg
  15. Some good advice given. I would for upholstery class sewing recommend Juki DNU-1541S or Juki LU-1508n. For holsters definitely going to need much heavier iron in a 441 class machine. kgg
  16. Have you tried contacting / checking out American & Efird at http://www.amefird.com . Great quality thread with the technical specs of their thread available. kgg
  17. I think it looks to be similar to a Durkopp Adler 867 single needle machine. kgg
  18. The amount of magnetic field is not only going to depend on the size of magnet but the type magnet you are planning on using. The best solution is to remove the magnet from the design and come up with a different method of attachment otherwise you may have some unhappy customers with scramble info on their cards. kgg
  19. Why not give "Current Applications" a call they are the company who manufactured the motor shown in the photo and they are still in business in Watertown, NY ( https://www.currentapps.com/ ). kgg
  20. Real murky, clear as mud. I couldn't find what a limited lifetime warranty includes / excludes in my searches. I like clearly defined warranties that way I know what I am getting / not getting. You are so close to both save the shipping charges / sewing shops markup and buy direct from either Reliable or Japan Sewing. When it comes to accessories folders, binders, needles, etc buy from Japan Sewing that is who Reliable gets their stuff from. Let us know which machine you got. kgg
  21. Reliable has been around since 1955.
  22. Totally Agree! kgg
  23. I have in the past own a Reliable Barracuda and had no issues whatsoever with it. It came with a test strip under the foot of what the machine was sewn off before shipment and worked properly out of the box. The warranty as with the 4300Cw was defined. I still can't figure out for the life of me what a limited lifetime warranty gets you, maybe just me. When I was looking for a flatbed machine I compared a lot of machines for what I thought I wanted / needed. Reliable was my number two choice. My number one was a Juki 1541S, which I bought from Chris at Japan Sewing Machine and Supply C. ( http://japansewing.com/ ). Their website is terrible but once I called and spoke to Chris about what I was planning on using it for they gave me some choices, Juki or their clone, depending on the pocket book. They had a machine setup for me to test on my arrival, no BS and went over the machine with me. None of the clones I tested came close to the quality of the Juki. Since you are probably close to Toronto I would call them first. They carry Juki and their own line of Juki clones. The price I paid for my new Juki 1541S was cheaper then what some wanted for a comparable clone. With such a large layout of cash make a trip too both Reliable and Japan Sewing they are about 25 minutes from one and another. Bring some of your stuff along and do a comparison sew off. Buy Once, Cry Once. kgg
  24. I agree, knock off or clone, not good. Clone -- A copy or imitation of something already existing, especially when designed to simulate it. kgg
  25. Guns are just tools just like a hammer. Some people for whatever their reason or need will carry either a hammer or gun in the middle of the back. Accidents do and can happen. Personally I don't think I would carry in that body location from a comfort point of view carry in that location. Someone who is trained will carry and store their gun in a safe manner. kgg
