kgg
Contributing Member-
Everything posted by kgg
Stupid question, which way does the thread come off the bobbin. If I am not mistaken in your Pffaf 335 the thread comes off the bobbin clockwise like a domestic machine rather then counter clockwise. Some machines don't really care but others if the bobbin is inserted incorrectly thread slack can occur resulting in poor stitching. kgg
I am not familiar with the bobbin case of your machine but I would check and see if there is any bits of material in the case also if the case is supposed to have a backlash spring it is working ok. I suspect that the odd loops have more to do with tension problems then anything else.
Sounds as through you need to back off the bobbin tension as the thicker leather is creating more resistance on the bottom thread which means you have to have more top tension to pull the bobbin thread into the leather. If possible could you post a couple of pictures of your top thread path from the thread spool to the needle. kgg
M Size Bobbin Center Hole Inconsistency Question....
kgg replied to Bmwmoa67707's topic in Leather Sewing Machines
If this is a new Juki from a Juki dealer call them and ask for the proper replacements. When I purchased my Juki 1541s from a dealer I purchased an additional dozen bobbins amongst other items. All of which were identical to the ones that came with the machine, no problems with any of them not fitting properly on the winder or in bobbin holder. I suspect the ones you got were after market replacements. Others have stated maybe ok, maybe work but you shouldn't have to do work arounds to get them functioning on a new machine. It is the small stuff that drives you crazy. kgg -
Exactly what I was trying to get at RockyAussie. Depending on the material, condition of the machine, type of machine (drop feed vs compound feed or flatbed vs cylinder), needle / thread, presser foot tension are are factors which can lead to material being are sucked in on the sides between the plate and feed dog or pushed down in the needle hole. Materials like muslin, stretchy material like micro fibre or elastic, even Sherpa if it isn't hard back can get sucked in. Depending on the project / thickness / material a good old fashion Singer 15 will do a much nicer job then my compound feed Juki. kgg
I think the easier way would to use a flatbed attachment for your cylinder Singer or just use an old domestic Singer. I would also place a sheet or two of regular paper on the feed dog side of what you are sewing so either the elastic or the hook material doesn't get sucked down or stretched by the feed dog. When finished just tear the paper off. As far as the sewing the hook and elastic together I would sew the edges of the hook and elastic together then fold over to hid the first seam and sew again to flatten and strengthen. Don't forget the paper on the feed dog side. It would be nice if you had a photo of what you are trying to accomplish as other methods maybe more suitable. kgg
There are a lot of factors that can go into getting a projects surface smooth, without having to do a lot of after printing touch-ups. Most of what you print is going to be for personal use and surface appearance really doesn't manner as long as it is functional and presentable. My list of the factors affecting surface appearance so it acceptable and I am sure there are more that can be added are: Experience and design software used, I like Fusion 360 but there are many others available. Your approach when designing the project. I still like the old school way of designing, putting my initial design thoughts to paper. Whereas my son just does it within the software. Whatever works best for you. Using 3d software and printings really will cause you to think of things in a different manner. Slicer software and the settings, which sometimes needs to modified depending on the project and filament being used. The quality of the 3d printer and the care taken in setting the unit up. Buy a decent machine within your budget as the prices verses capabilities are getting cheaper every year. I chose the Prusa i3 mk3 which was a kit and a royal pain to put together. Took about ten to twelve hours to assemble. Time consuming along with the manual having some errors coupled with some pictures being incorrect. I figure within the next couple of years a metal 3d printer will be almost affordable as new / more manufacturers come online. The bed temperature. The type and size of the nozzle. The type and quality of filament, just like sewing thread, they are not all equal. Even the colour of the filament can affect the final look as some colours show small imperfections and layering more then others. Drafts, ambient temperature and humidity can be major factors that can affect the printing. Just what I have found so far. kgg
UT3200: Flatbed attachment for the Cowboy CB-3200
kgg replied to Uwe's topic in Leather Sewing Machines
Really nice precision work. kgg -
Juki 341top thread breaking when backstitching
kgg replied to twotrees's topic in Leather Sewing Machines
Another problem area to check is the last thread guide right before the needle. Check and see if there is not a small burr or a groove rubbed into the inside of the hole. Small thread could be affected more then larger diameter thread. kgg -
I would: 1. Recheck thread path, how the needle is inserted and it is a leather needle. 2. Move up to a size #19 needle. Sometimes depending on the material / thickness you need a slightly larger needle hole. Also going up one size will add a small amount of strength to the needle to help prevent any slight needle deflection. If you don't have a #19 change the needle the one in the machine may have a burr, be dull or be slightly bent. I find it is better to size the needle up one size. 3. Change out the spool of thread. Depending on the manufacturer particularly cheaper thread it maybe defective or you are down to about 15 percent thread left on the spool. If you are using an 8 oz spool go to the 1 lb size which usually has less problems. 4. Change needle every 8 hours of use and more often when sewing certain materials. kgg -
Bert51 if humans don't cleanup the dead fuel / brush / over growth, nature will through other means like what you are experiencing. The Greenies / Tree Huggers / Climate Activists whatever label you want to use don't get it no matter what county they are in. There needs to be a practical, sensible, cost effective approach. Prayers are with you and those affected. kgg
I would give Techsew a call in the morning they would be able to answer your questions. I don't think the 3800 is a very current model and think the price as well as access to parts are going to be major factors in your decision. kgg
My heart goes out to those being affected by the fires. Unimaginable devastation. Be careful and be safe. Known when to say when. kgg
I am going to assume you mean a Consew P206 RB as I didn't think the P1206 rb had a safety clutch: Try this link for the P206: https://www.youtube.com/watch?v=H-pL2vISk2k kgg
Glad to hear the temperature is decreasing slightly. I do agree with Bert51. What is the "dealer" saying / doing about the problems you are having to solve, are they going to do something / anything? It is lucky that you are apt at solving and fixing the problems related to quality control something the "dealer" should have done. If you were an average or newbie not around the corner from a repair shop, you would be really peeved and maybe have a pretty boat anchor. Your experience does show that a dealer who goes over and sets up their product is crucial to customer satisfaction / retention / recommendation. kgg
From a post back in 2016 by Darren Brosowski , I think the first part means with the handle at the 9 o'clock position.: "Turn the handwheel until the needle is at its bottom point. - Put the shuttle driver in with the 1/3rd moon bit alongside the needle - two thirds towards the front (your side of the machine) and one third behind the needle."
If you order directly from Reliable they can set the machine up to handle V138 but as it comes it will handle V92 top and bottom. The needle system for the machine is 135x17 but you will need 135x16 needles sized to the thread size for leather. So for V92 I would use size 19 needle. A good reference chart: https://www.tolindsewmach.com/thread-chart.html kgg
The Reliable Barracuda 200ZW straight stitch / zig zag US Homedepot with free shipping link: https://www.homedepot.com/b/Appliances-Household-Appliances-Sewing-Machines/Reliable/N-5yc1vZcf97Zben/Ntk-Extended/Ntt-sewing+machine?Ntx=mode+matchpartialmax&NCNI-5 Reliable Barracuda 200ZW straight stitch / zig zag link: https://reliablecorporation.com/products/barracuda-200zw-portable-walking-foot-zig-zag-sewing-machine kgg
What's The Better of the Machines Available?
kgg replied to RoosterShooter's topic in Leather Sewing Machines
I think a lot of the price on a lot of Chinese machines has more to due with what the reseller figures the market will bear and what the customer perceives the value of the item to be. Example 29k type machine no label from Asc365.com in Ontario, Canada who imports a lot of different stuff from China and advertises on kijiji costs $1079 ($825 US) with no table / motor and probably with little/no support ( https://www.kijiji.ca/v-other-business-industrial/city-of-toronto/leather-sewing-machine-leather-sewing-mending-machine-shoe-repair-industrial-188073/cas_10224180?channelId=101&td=4H9L53pF2g-jafmKKdIpi_wsecM9ZoX8bISfb_-hv5GcjWbzWXSCMddq86deX-pFHG9_WUE8Kz0xk6quJCEAyeieMUi-RrpSn9YRoSa77dBEYK8IVF6Oi1wrxYZse6XyMvxbyM-OG35BSz-y18eskoAS_G8aPoGLUYZj1490fvckHqx-N_z-uBbhjGlvJV21dJxEL_8-OPWY5nqd8ajN4TdL3LWIuLeJ2XYcD_4QhKjh184OVo826pijD1floMkPk0LKnD7MS-R3WeGXBAMZPzIcGfi8u57v0JNWeSvYNUZSkXNYgEohRgo7wKBgUy3RP3W6urdQomA9n8NdnAZBrfJvPfD8meXIBEfmMEERdU99NPHWcO0bgAr4lHBxq4QFcyuz8oIA7x4HTzY5mL39Gbf7ETS31kfJC4vcGvCWKcVKYUXqu17t0GGSUsidkCDKBgv11HdFyrWfJdwN9HhAd_Kni6EzWBZkN3YRHsNUpvUMYXo71_TidOLho8v_c7oyM3G3Ov0QqDyxFLwxJzm06vZgKjVSdHBJA2lhle5My4XMgQ7iCS-XBVHWGWtVzswt5Dxy0W4pPa1shHu-8InKIilPy4SvqJpcDAjlct4GXx8 ) while another reseller sells a similar 29k machine, also in Canada, for $2500 ($1900 US) with table / servo motor and support. I would have to look at the $1500 saving less the cost of the table/servo motor. kgg -
Nice increase in a couple of months and over 50% increase since 2015. Begs the question. Are the prices going to fall back once the tariffs are removed or lessen?? Maybe it may be best to buy a good used machine and wait the tariffs out. kgg -
I should have added for belts it depends on how thick of leather you are sewing. kgg
It should work find for that purpose but since you are in the US why not go to your local home depot and get the Reliable Barracuda saving on the price and shipping. kgg
Jeff's bobbin holder (as designed by Rocky Aussie)
kgg replied to dikman's topic in 3D Printers and Lasers
I had the ends lift on one of my prints but tracked it back to the humidly being sucked in the filament. I left damn roll out for a couple of days. Solution was to use our Print Dry to remove the dampness and then remember to store it in the proper vac container with couple silica gel desiccant packs after use. kgg -
Checkout the topic " Jack 513A engine problem..." someone just recently had a problem with their servo motor. Also give the dealer a call they should be able to walk you through correct the problem. kgg
On this side of the pond your 8 oz and 1 lb pound spools are really available in most sizes including V46. The yardage of thread on the spool is going to depend on thread size. A really good thread / needle chart is the one on Toledo Sewing Machines website ( https://www.tolindsewmach.com/thread-chart.html ). The only thing to be careful of on the chart is the amount of thread is in yards per pound not meters per kilogram. When I spoke with American & Efird this summer they were eliminating their 8 oz spools in the near future. If I am not mistaken 4 oz (113g) and 8 oz (227g) are more common with the 1 lb spools not so common. kgg
