kgg
Contributing Member-
Everything posted by kgg
I should have done this earlier so here are the two pdf's that I have. LS-246-4_P-1.pdf LS-246-4+Instruction+Manual.pdf
Thanks for the info I did get a copy of the parts list and instruction manual after a little more digging. kgg
I designed these shoes is anyone interested
kgg replied to Jojomojo's topic in Shoes, Boots, Sandals and Moccassins
I looked at your webpage, photo's and descriptions. Your "Jojmojo " bio says you are in Texas.This what I took again from your website. You designed the sneakers, the sneakers will be made in Italy if you get 7 orders, there are seven comments on the craftsmanship, the sneaker is Italian canvas with Italian leather highlights and they cost $194 US with free shipping. There is no information about yourself, the manufacturer or what sets you apart from the other sneaker manufacturers. The sentence with "Minnie ways I think this is mine relamine release one of them" I am having difficulty understanding what your trying to say. kgg -
You work is excellent. Not my cup of tea but beauty is in the eye of the beholder. kgg
Transform a 3d printer to a cnc drag knife leather cutter
kgg replied to LifeLuv3R's topic in Leather Machinery
Personally I won't try it. The 3d printers are additive made to build a project from the plate up. Maybe a plotter would be a better choice. A couple of problems I can see is getting the leather too firmly stay in place which would be difficult, variations in the thickness of the leather and the stress of cutting probably would create havoc on the thin belts. I watched a video out of Germany where a guy cut some vinyl (which is a constant thickness and very thin) "Convert 3D printer to yinyl cutter / plotter || Anet a8 " (youtube.com/watch?v=JIQ0U3CrsVQ). Just my opinion, best of luck, kgg -
Prusa 3D Printer Heated Bed Sheet Mileage Replacement
kgg replied to kgg's topic in 3D Printers and Lasers
Anytime. kgg -
Steel Belt Liners
kgg replied to MarlinDave's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Totally Agree. The only good thing that ever came out of China was gun powder. The rest not so much. kgg -
Yes, they do make skiving tables with a vacuum system. Essentially the exhaust for the waste material which normal falls down a chute is replaced with a tube that a exhaust vacuum removes the waste material into a container or bag. I think installing a exhaust fan something like a high CFM inline hot air duct fan connected to a 4" tube would probably work just a well but a lot quieter then a vacuum cleaner or shop vac. Something like " https://www.amazon.ca/VIVOSUN-Inline-Booster-Extreme-Grounded/dp/B01C82SYZ0/ref=sr_1_6?dchild=1&keywords=Inline+Duct+Fan&qid=1628524596&sr=8-6 " kgg
To me it looks like a Singer 128k or 99k. But I am leaning towards a 128 (for book Binding). kgg
According to ISMACs the serial number with no letter prefix dates the machine to 1892. http://ismacs.net/singer_sewing_machine_company/serial-numbers/singer-no-prefix-serial-numbers.html kgg
I think sewing firefighter helmet shields is going to be beyond the ability of this machine and you would need a Juki 441 class machine to do that type of work. I am going to assume the owner isn't the original owner and doesn't have the manual to determine the model. If this is a high speed machine extra care is going to be needed for oiling internal parts. Remember no one machine is going to be able to cover all those bases properly. kgg
It is definitely not a Juki 1541. I think it is very similar to the Juki LU 2210 series. If it is a LU 2210 series it is a high speed machine (3500 stitches per minute) using 134 x 35R with a max needle size of #23 (160) and a max size thread of V138 top and in the bobbin. This would be about 3.6 mm or 9/64" thick material. Does the serial number look like: LU2212WASZ70A this type of numbers will tell you what it is. How thick do you want to sew? kgg
The filament you are using has a good reputation for a quality product. We have on occasion used PETG but use a lot of PLA+ and really I cant give specifics other then we hate the damn stuff. PLA is stronger but less flexible then PETG (snaps versus bending). It either won't want to stick (when too cool) or stick like S to a blanket when to hot and needs hairspray as a release agent. This is how we dialed in our printers which may or may not help you with your setup. 1) Design a 2" (50mm) x2" (50mm) by one line height cad object. Then slice it do the bed so there are squares with about 1 inch gaps between them. 2) Dial in Z at temp we run (for example we run 240 to 250c for 3d850 and 250 to 260 for 3d870 w/ bed at 70c. To put this in perspective 3d850 typically is run at 230 and 60. Hotter is better, right up until it burns the plastic. The trick is to stay on the lower this side of burning. The hotter it is the better, as it will want to run together and make for stronger bonds between the layers/lines. w/ zero fan for first 5 layers (further allowing the lines to blend together). 2a) Lower head until you start to see ripples in the top of a square (this means too much pressure and its flow is UPWARD). Then back off by 50 microns for next square. Repeat until it is what you like. 3) Then we re-slice with 105 initial line width and first layer extrusion at 110. We then increase first layer extrusion until it starts to ripple. IF bottom is nearly perfectly smooth we back of z height until it is no longer smooth... and then play with extrusion multiplier vs z height. This will vary greatly from bed to bed and machine to machine. One of ours runs at -1.505 w/ 110% the other is -.985 w/ 130 percent. Or did until those plates wore out and we are now back to square one and have to start again. 4) We then dial in elephant foot compensation - typically "-.4" range so that walls are straight. Over the next 50 or so prints we then dial it in until its perfect. Your Celtic knot bottom layers looks good but you will never get perfect bottoms. Jerk and acceleration gets reset when it has to turn or start a line. This faster/slower/faster pattern builds up pressure in the nozzle which causes random bursts of plastic. You want it to start a line and end it slightly inside a wall so that any extra bursts of goop just makes the wall stronger. We run at 850/850 for jerk and acceleration. We run walls and infill (at 98 to 99 percent to allow any small ripples to fill up the micro gaps at the same speed - 100. So that pressure is constant. We run first layer at 50. constant speed means constant pressure which gives you a better chance of dialing in the 'perfect' first layer and every other layer. Hope the info makes sense, kgg -
What I am seeing in the photo's that could be contributing to your print problems: 1. Not enough extrusion on first layer. We typically run at 105 percent for the first layer to get more squish but not so much to cause elephant footing. 2. Improper "Z" height. I would open your 3d cad software and make and make 2"(50 mm) x2"(50mm) squares. Then make columns and rows on the bed in your slicer and slice them. As each square is printed.... lower "Z" height until the TOP of the square starts to ripple from pressure. Step back to the previous square. Z height well now be as close as it can be before causing ripples. 3. Nozzle Temperature to low. With unheated beds... nozzle temps should be higher. We don't use std PLA anymore. We use 3D850 and 3D870, which is kinda sorta like PLA but not. With our mosquito head we run the temperature at 240 and on the e3d v6 at 250 (e3d v6). If you are using std PLA run it at just a touch before it starts to burn. Probably 230. It will flow faster and easier allowing for you to push up your speed (our first layer is laid down at 50 w/ rest at 100 w/ accerleration at 850) and stick better to a cold plate. With all this said you will NEVER get a perfectly smooth surface like it was vacuum molded. There will almost always be a line (even with 10 percent overlap) from where border and infill patterns meet. To REDUCE it, go with lines not the celtic knot pattern you are using now. It will be less work and faster to print. What machine are you using and nozzle temperature. The quality of filament (China vs North American or European made) will also affect the print quality of your items. I relate filament to sewing thread where cheap quality equals poorer product and added frustration. Hope this helps. kgg -
The main problem with your request is you haven't said what you are planning on sewing or what country you are in. Without that info it is very difficult to recommend a machine and whether a cylinder bed or a flatbed would be best suited to your needs. You mentioned the Sailrite Fabricator, which if I am not mistaken is a modified clone of the flatbed Singer 111w and in the upholstery class of machines. I would first recommend buying a brand name like a Juki 1541S within this class or if that is out of your price range maybe something like a Consew 206RB-5. Finding a new upholstery class machine under $1000 is not going to happen. The Rex you mentioned from Amazon is, I assume a portable walking foot machine which do have their place but were designed mainly for repairing sail material offshore. Within the portable walking foot machines you also have the Sailrite LSZ, Reliable Barracuda to name a couple of other options. The under $1000 mark for an industrial machine really leaves you to the used market. kgg
Thanks Constabulary, it seems like an unpopular model probably because it is only a needle feed. kgg
Can someone point in the right direction for the specifications and a manual for a Juki LS 246-4. Lots of info about the DSC 246 but little I could find on the LS. kgg
Try a thin coating of ordinary glue stick on your bed to help with the filament bonding to the surface of the glass. kgg -
For those who use 3D printers and maybe wondering what to expect as far as life expectancy of heated bed sheets on a Prusa machine might be. I just had to replace my bed on the Prusa Bear upgraded i3 MK3 3D printer as the bottom layer was slowly degrading with some lifting and voids occurring, not pretty. The bed on this machine had to be replaced after 200 miles of filament. I figure not bad, but the older Prusa i3 with the same bed has over twice the filament mileage, hum. The bed was replaced with a new Satin Powder sheet bed and the results are really nice a few test pieces as compared to the original heatbed steel sheet. Any one have similar / better / different results?? kgg
Visit a dealer with a sample of your stuff and see what does the job best. Buy a brand name sewing machine like a Juki. kgg
I can see using up to a #20 needle in thick or sticky material for added needle strength and making a little larger thread hole but a #22 is to big a needle in my opinion for V69. I think the problem is probably also related to other factors. Detailed pictures or a video of how you are threading the top thread from the top of the small 1/2 pound spool to the needle would help a lot. Being a bit more specific on how thick the leather your are sewing would help. What direction is the bobbin spinning in the bobbin holder, CW or CCW. How are you tensioning the bobbin thread? What size of thread are you using in the bobbin? kgg
- 4 replies
- tension problem
- leather sewing machines
- (and 2 more)
I think all information related to needles quality / size/ type / fiction etc. as it is important to the quality of work any machine can provide and is often overlooked. I just sold my PFAFF 1245 in the last couple of days. Now I have room for another machine but had a inquiry from a guy basically around the corner from me who said he had bought an old Singer 211 but considered it a $500 "boat anchor". He needed something that worked without shredding / breaking / bird nesting the V92 thread that he was using on some boat canvas. We had a phone conversation and narrowed down his problem with the "boat anchor" to probably the type and size of needle he was using. I offered him a couple packs of my Schmetz needles to try and now the "boat anchor" is just sailing along find. kgg
- 5 replies
- needle quality
- needly eye
(and 2 more)
Depending on your local store but if they are like most they will typically deal mostly with domestic sewing machine related items. For needles I would recommend you check out Wawak, good prices and fast delivery. kgg
As wiz said they are the oil wicks. If you email Techsew they probably would email you a copy of their manual which should help you with routing the wick to the correct locations. kgg
I guess it proves the point that you get what you pay for. My personal experience has lead me to using only Schmetz needles as a lot of the other brands that I tried were just frustrating to use. This maybe particular only to my needs, machines and what I sew. It was interesting to see the quality decline of the Flying Man needles over a six year period. kgg
- 5 replies
- needle quality
- needly eye
(and 2 more)
