kgg
Contributing Member
Everything posted by kgg
  1. Having a sewing machine demo'd by the owner and they can't get it running right is a real red flag for me. Why is the owner wanting to sell it???? Problems not being mentioned??? To me if an owner can't get their own machine running right then the machine is worth little more then it's scrap value or at least a drastic drop in price to help cover possible repairs. The clutch motor is another red flag as to how fast the machine was operated at prior to the new servo motor being installed. Typical speed on those clutch motors is either 1725 or 3450. Any speed reduction??? The servo motor control panel indicated it was running at 1600 rpm but what was the actual rpm's the machine was run at. Any speed reduction? Most of the Singers Patchers shouldn't be run at much more then 500 rpm's but the Alder maybe different. Another option that may fit your needs if space is a real concern are the portable walking foot sewing machine's like Sailrite Ultrafeed and Reliable Barracuda, to name a couple. kgg
  2. Chris is pretty good and glad you got it to where you feel comfortable sewing. kgg
  3. It wouldn't be my first choice. The parts are probably going to be to be expensive should it require any. I stay away from Alder and Pfaff machines for two reasons replacement parts and accessories are much more expensive then other manufacturers in my location and the machines are difficult to sell. I also stay away from any machine with build in electronic functions as I like to keep my machines as simple and cost effective as possible. I would check the availability and cost of replacement parts for the Alder in your area. kgg
  4. You can't go wrong with a Juki as they are what a lot of the clones copied and parts / accessories are readily available. That said all lot will depend on how the machine has been cared for. If any of those machines were used in a commercial setting they probably are being sold for a reason. The Juki DNU- 1541S will do the upholstery work but as for shoes, boots etc being sewn to soles you will need a heavier weight machine. Upholstery class machines can handle about 3/8" thick material or less depending on the material. I would check / look for leads with the local sewing machine dealers, repair shops, shoe repair shops as well as places that do tack repairs like horse riding / polo clubs and companies that do upholstery work. kgg
  5. Nice work. kgg
  6. Which model number. Do you have any history of the machine? Yes but it also depends on the model, work history and just not the age. The max stitch length of my 1949 Singer 29k 71 was manufacturer spec'd at 7 to 15 per inch. My 1998 Singer 29k71 is probably similar. Sewing 9 mm of veg tan is effortless but I have not sewn over the 9mm thickness myself. There are two end plates that came with the 29k each marked for the size of needles that plate could accept for the range of needles. The range of needles it can handle are from #11 to #24 needle. The 29k machines if complete will have a hand wheel which can be used on either the pulley end or the side drive. Parts for the Singer 29k 70, 29k 71, 29k 72 are still readily available and fairly inexpensive but the older models can be a challenge for some parts. This is an example of a what I think is a nice running 1949 Singer 29k71: https://leatherworker.net/forum/topic/97429-singer-29k-71-all-cleaned-up/?tab=comments#comment-661772 This is an example of a what I think is a nice running 1998 Singer 29k71: https://leatherworker.net/forum/topic/97594-how-singer-29ks-should-operate/?tab=comments#comment-662317 This is an example of how quiet a 1998 Singer 29k71 should be and this machine is louder and not quite a smooth as the 1949 Singer 29K71: https://odysee.com/@SingerSewing:0/singer:a This maybe something you can compare with the one you are interested in. The main question is this the right machine for putting soles on, I don't know. kgg
  7. What a shame, that video was from back in 2015. I did wonder after watching both of the video's if he (now I know it was you) ever got it working correctly. kgg
  8. Good repurposing of an old drill. kgg
  9. I would checkout this video as it adjusts a set screw behind the small horizontal plate that adds or releases tension on the up and down movement of the rear pressor foot shaft. May help in reducing the jerky movement. The video is called "Techsew 4100 Trouble shoot" Link: youtube.com/watch?v=NHswdukpWog&t=600s kgg
  10. I do find it odd that a lot of the heavy duty machines say their machines can take a #18 to XX needle or V69 to XXX thread but you can't readily get them. kgg
  11. I can't be of any help other then check with a cobbler that does replacement soles cut from either used car tires or the sheets of retreads rubber used to retread tires. kgg
  12. I would still check with Aaron Martin in western Ontario as they do cater to the horse and tack people and mybe able to source them. kgg
  13. I would try: i) Cowboy Dealer ii) Aaron Martin in western Ontario as they maybe able to order ------ aaronmartin.com/product.php?cat_id=996&catview=20&submit=View ---- they list Schmetz in a 160 (#23) iii) Cutex Sewing ------ cutexsewingsupplies.com/products/100-organ-7x3-dyx3-794-sewing-machine-needles-singer-consew-highlead?variant=32221430415413 --- they list Organ in a 120 (#19) iv) Amazon ---------- amazon.com/7X3-Sewing-Machine-Needles-Highlead/dp/B01FGZ22X6?th=1--- they list Organ in a 120 (#19) kgg
  14. Thank you. Give it a go, you got nothing to loss. The only problem maybe the length of usable shaft which could be extended with inside threaded shaft extenders or similar shaft extenders. kgg
  15. Thank you. The thread on the both sides of the the machine shaft are your standard SAE 5/8" - 11 just that the right side has your standard right hand thread twist and the other side is a left hand thread twist (commonly known as bastard thread). There is a silver color nut for the side with the regular thread and a dull sort of yellowish nut for the other. Also the machine did come with two 8" cotton polishing pads. kgg
  16. Not sure yet and the heat maybe the down fall but over the next day or so I am going to give it a go on a half round sheath that I have be playing with so we'll see. kgg
  17. I agree, just got to figure out what sizes of grooves that will get used the most. I think I am going to use some good old fashion Canadian ironwood (eastern hophornbeam ) which is the hardest wood in Canada and I have a lot of it. kgg
  18. I was looking to step-up from the inexpensive rotary tool attachment to a more professional setup. Sticker / spec shock would be an under statement as anything I would consider decent was about $750 plus shipping with adjustable speed control but only with 1/2" or less diameter shafts and amp ratings of 5 or less. After much looking and pondering I settled on a 8" buffing / polishing bench machine made in Taiwan from Princess Auto (Photo 1) as it pretty well covered off what I was looking for: i) 3/4" main shaft cut down to 5/8" (Photo 2) ii) CSA approved iii) 7 amp rating iv) adjustable speed control from 2000 - 3450 rpm. The price was $130, tax in, and all I had to do was purchase a burnisher ($75 tax in and delivered) and re-drill the 1/2" hole with a 11/16" bit. The next thing was to figure out the sanding wheel side. I chose to go with a 3" x 4 1/2" sanding sleeve which I could have in hindsight gone with a 2" diameter sleeve. This required me to get a 4 1/2" rubber sanding drum ($30 tax in and delivered) and 3" x 4 1/2" sanding discs ($28.50 tax in and delivered). Then I had to re-drill the 1/2" hole with a 5/8" bit and cut it roughly to the usable 5/8" section of the shaft. To cut the rubber sanding drum I stuck it on the shaft and with the machine running I used a utility knife to cut it to the proper length (Photo 3). This did work but the drawback was there was a lot of the sanding disc unsupported about 77mm (Photo 4). The piece I am holding is just too tighten or loosen the spacer in place / removal (Photo 5). To this point the cost is $263.50 for something that can do the job but... The sanding disc side of the machine was begging to get modified so I 3D some stuff: 1. A spacer which fills the unsupported and allows the use of the full sleeve (4 1/2 long x 3 inch diameter) rather then just 37 mm of the supported surface. 2. A 3.15 inch long x 3 inch diameter sander wheel for using standard sheets of sandpaper (Photo 6). This was a scrap piece of 1000 grit sandpaper I had handy just to show how it wraps around the drum. This way I can have a better range of available sanding grits and get three pieces of sandpaper out of a sheet. It's also cheaper as a sanding sleeve costs about $8 each whereas a 3 pack of the expensive 3M sandpaper sheets are about $8 and I get 9 pieces so it costs about a dollar per. I did like the principal that the Just Wood burnisher in the UK uses to attach the sandpaper to the drum but I figured I could build a better mouse trap. My thought on the Just Wood as I see it is once you cut the sandpaper sheets too the proper width along the length of the sandpaper sheet you have to trim the length by about 10mm and the sandpaper is being held in place by a hollow flatten pin that is dependent on a friction fit in a oblong hole. 3. A 4.25 inch long x 3 inch diameter burnisher with 1- 15mm, 1-10mm, 1-8mm, 2- 6mm and 1-4mm concave slots. This does work but if I like it I probably will use it as a guide and turn it in wood (Photo 7). The cost of PLA filament about $30. Total Cost including about $30 in PLA filament is $293.50. So far no problems like flying bits and pieces, fractures or catastrophic failures when run at full bore. Any and all comments are welcomed.
  19. I don't think of it as so much as pushback but on this side of the pond, at least where I am, the cost of those items would be much greater then the £30 ($50 CAD) you paid. The taper bearing alone would be probably be £30 ($50 CAD) or more depending on the size and to get a decent pulley the cost would be £60 ($100) or more. Not everyone feels comfortable in modifying their machine so for a little more money it is easier just to order a speed reducer setup and belt that is mounted under the table mount. If the machine is used and or the motor is older I would recommend replacing the motor with a newer servo motor. Then if the speed still needs to be further reduced add a under-the-table speed reducer setup. kgg
  20. It still is, with Imperial easier to access for a lot of items like nuts, bolts, drill bits, pulley's etc. kgg
  21. Right up front I know nothing about your particular machine. According to the spec of your machine you have a single needle domestic embroidery machine which maybe able to do some normal tailoring sewing tasks but it is geared more for doing embroidery tasks using generally thinner fabrics. Most domestic sewing machines not domestic embroidery machine can do about 1mm or so of soft leather, chrome tan. The older domestic sewing machines like the Singers could probably handle much thicker soft leather occasionally as they were case iron bodied machines with real metal gears and shafts. For leather you need a metal bodied machine with metal gears and the thicker the leather the heavier the machine you need. I wouldn't attempt to use your machine for leather or thick tough fabric like 21 oz canvas. Since there is no one machine that will do everything the key in finding a new or used sewing machine for leather is knowing what you would like to sew whether that is wallets or saddles. kgg
  22. You never said the size of thread you want to use. I did a quick check of the Global WF 975 manual and the max needle is a #22 (140 metric) which is the bottom end for V138 ( Tkt 20 ) in softer thinner material. I couldn't find a manual for the WF 69 so I would check with the seller and see what is the max needle size these machines can handle.
  23. As MtlBiker said call Chris at Japan Sewing. Good prices and save on shipping cost or you can pick it up. I have purchased all my new machines from him, good service. kgg
  24. What Country / City are you located in as someone maybe able to direct you to vendor close to your location. kgg
  25. I personally use the brush type motors similar to the one Wiz mention on my machines with no problems. I would say definitely put a new servo motor on your machine and give it a try. You could always add a speed reducer at a later date if you find that it still doesn't give you the control you need. kgg
