kirbytorres
Everything posted by kirbytorres
  1. Have you checked if your leathers edge is straight, before measuring against it?
  2. You should have started with this picture... really excellent work.
  3. looks good... but wouldn't the battery pull up the chuck making it difficult to remove from the holster?
  4. These are before and after pics of using cmc as burnishing agent. Still need work on sanding and leveling, but am satisfied with the results.
  5. Love the magnet at the sides of the saddle..
  6. Still have the problem in my end of the planet... hope this would be fixed the soonest.
  7. I have read somewhere that by submerging a veg tan leather on hot/warm water and then letting it dry, would make the leather harden. Would that hardened leather be good as a stropping leather?
  8. Liner on the wallet looks awesome, as well as the stitches. Was the size of the wallet intentional? the bill does not seem to go all the way in. @RockyAussie what are "keeper"? Kirby
  9. this is quite interesting...
  10. okay... will try and find the thickest one I could find
  11. I've always thought of doing this... do you have any problems with regards to the thickness of the blade?
  12. Here, where I live, its more known as Tylose or CMC. Just like you, this is more locally available than Tokonole or fiebings. I haven't used it yet, but at less than half a dollar for a small 50g bag, its a no brainer for me. I'll post results once I use it.
  13. CMC is Carboxymethyl Cellulose otherwise known as Tylose. It is used in cake baking, particularly to harden sugar paste for decorative flowers. Not really sure it is the same as gum tragacanth. Read that it is a cheaper substitute to tokonole. I bought 50 gm of Tylose powder for around half a dollar from where I'm from.
  14. Just recently learned that some use a diluted mixture of CMC with water instead of Gum or Tokonole as burnishing agent. For those that use this, how do you store the extra solution? how long would it last? what water:CMC ratio do you use? Kirby
  15. Is this just two pieces of leather stuck/sewn together? How does one get the cover to be stiff like a book?
  16. I use felt cloth with roughly the same thickness of the leather to create the prototype and then use that as your pattern for the leather
  17. Looks really good... would be mirroring LyndHolls request for a pattern if available or at least pictures at different angles as well as the inside. Thanks
  18. Will try that edge paint thing, thanks
  19. Hello Nick I've read that oil-tanned leather cannot be burnished, but will try it here. Will try your suggestions on rounding out the edges and post the results here Thanks Kirby Appreciate that, thanks
  20. My 2nd project - checkbook cover
  21. This is what it looked inside
  22. Hello, I've recently started on this very satisfying hobby, and attached below, was my very first project I was too cheap to buy one so decided to make one using repurposed "leather", I had a key holder that I was not using. Someone gave me a metal card holder, so I used that
