jrdunn
Everything posted by jrdunn
  1. Just FYI, https://leathermachineco.com/product/cobra-class-4-p-heavy-duty-stitcher-with-eps/
  2. Welcome Rich!
  3. That is a screw pin shackle, sometimes called a Crosby(brand) or mistakenly called a clevice. A clevis pin isn't threaded.
  4. i haved used veg tan on the yokes but not for the "leggings". I can't imagine how long or hard a man would have to work to wear through 4-5oz chrome tan as long as they are cared for. I'm sure not saying it can't be done but sure that I can't do it. With 4-5 oil tan it's sometimes difficult to get them supple enough to be comfortable.
  5. My sincerest apologies! I was wanting to show the lacing, so I grabbed the first picture I came to. Those aren't the ones I made but the picture I, more or less "copied". I used a slightly wider front belt and an 1.5" back belt and my photography isn't near that good. No, mine aren't veg tanned and I assume those aren't either. Unless you wanted to tool them, I'm not sure why you'd want veg tan. It would also be hard to get it supple enough to wear and use all day, as well as more expensive. JM2C
  6. Just "no nonsense" working chaps but simplidity is my style (assuming I have "style").
  7. This pair use that lacing to adjust the zipper for leg size. The leather that the zipper is sewed to has 2-3 sets of holes for the lacing to go through to make the leg size larger or smaller. Hope this helps.
  8. Attaboy Chuck! Good work and good deed.
  9. Your questions are way beyond my abilities but welcome and I'd sure like to see pictures of that saddle!
  10. I respectfully disagree. I think that looks better than a "dye job". JM2C
  11. I think most of that is polyethylene. I don't know the hazards of PE. Heck, I didn't know the hazards of PVC.
  12. Thanks for the info. I don't know if ABS drainage pipe might be an alternative for you? It too is common for residential wastewater pipes in the U.S. I guess I need to get my leather out of that 8" PVC. It sure is handy, though.
  13. Perhaps even some international fame! Nice work by the way.
  14. Fred, I do know that in the U.S. and Canada PVC is widely used in water and wastewater mains. That is not to say that we always do things that are good for us. With some experience in water and wastewater treatment and some training(Some people will brag about anything.), I have never heard this. Do you have any information what effect these chlorides have on the water or the leather? Chlorine is often used in the treatment of both, maybe that's why it wasn't mentioned. I'm not trying to hijack the thread, just wondering what this might cause.
  15. That is a good looking maul, Chuck!
  16. Does anyone have information on the handwheel/sheave or do I need to go the "speed reducer route?
  17. Constabulary, Thank you for the response! I think this is the information I was needing. I have a parts list for the 16-188 and it lists the needle bar (p/n 4264) that you put in your 34K. I double checked the measurements and they are the same. I have found an Ebay seller that has that part #. He lists it for a Singer 17 also. Thanks again, Jim PS. I should confess that everything I know about sewing machines came from this forum. Thank you to all our members!
  18. The needle bar was stuck. The bend is slight and at the place where it was sticking out of the machine. I assume someone tried to coax it loose, it fell over or got hit by something else. These are just my guesses. Thanks for the help!
  19. Someone gave a friend of mine a Rex 26-188. My research here on this forum indicates that it is a clone of The Singer 16-188. (Thank you, everyone for all the information that has been contributed over the years!) It was stuck with surface rust from being stored improperly. After copious amounts of kerosene and elbow grease, I got it rolling over. It, of course came with a clutch motor set up to run about 2000 SPM. A 1725 rpm motor, 3.5" drive sheave and 3" sheave on the balance wheel. I got it sewing and discovered that the needle bar is bent. Finally, the questions: 1) Does anyone know if the needle bar from the Singer 16-188 will fit the Rex? And where I might get one? 2) Does anyone know where I might get a sheave at least 6" o.d. with a 14 mm bore? Will it be OK to replace the hand wheel with a sheave? Any other information is welcome and will be appreciated. Thanks, Jim
  20. That!
  21. I only WISH my first actual project looked that good! Nice work. I'm sure he'll love it.
  22. And I really like the looks of the ones that Chuck has made.
  23. I know that "too tight" is relative but does crisp molding around the ejection port make it difficult to draw? It is a handsome holster!
  24. 14chow, I hadn't seen this thread before but maybe you could help me understand. According to the prices I see, the Cub is only $500 less than the CB3200(from Cowboy Bob). I know shipping would be higher but you get a reverse, table and a servo motor. That's worth the extra $500 to me. I know sometimes that extra $500 is just too hard to come by. What do you think? Thanks, Jim
  25. I ordered and recieved one of @shoepatcher's drawers. It is a quality wooden drawer and fits my 29K71 perfectly. Thanks Glenn!
