Everything posted by terrymac
Send me an email,and I will provide examples of toolings.
Mine was finding out how efficiently a chainsaw can remove teeth. We were cutting firewood all day and I had one last log to finish. Caught the tip on something and it kicked back and got me on the chin and front teeth. I have had saws kick back but never like this one. I had removed the tip guard on the chain thinking it was just in the way. That was a dumb mistake as the saw didn’t have a hand brake as found on all saws today. I soon got me one that did have the hand break. After a couple hundred stitches done by a plastic surgeon and some replacement dental work, I was good to go. I actually was very lucky as it could have a whole lot worse.
The company that makes Tokenole went bankrupt and another company has bought the product, but is going to take sometime to set up manufacturing. In the meantime there are going to be shortages. The manager of the local Tandy said it should only last a few months, but you know how that can go.
I have a set of #7 Dixon pricking irons. One as eleven teeth and one has four teeth. $90,00 for pair. Excellent condition.
Normal, (Tandy) bevelers have a 15 degree angle. Barry's steep bevelers have 30 degree angle, and his extra steep have 45. Hope this clarifies.
Clear lac, made by the same people who made the old Neatlac. Terry
There is a picture in one of the coaster. Difference in bevelers is as follow: Standard bevelers (Tandy) 15 degree slope Barry King steep. 30 degree slope Barry King extra steep. 45 degree slope Hope this helps
3M packing tape with filaments. This stuff sticks and leather will not stretch. Have never tried applying to wet leather. Once stuck, don't know I would dunk in water, but I use water spray to case,.and no problems with the tape. Only downside is when pulled off, it will raise any loose fibers your leather may have. Hope this helps Terry
If you have paste that will pour out, something is wrong. I have never, in 60 years, encountered that. If you just recently purchased, I will bet it was frozen at some point. With all of the cold weather, it is entirely possible. You can't tell the difference between light and dark brown in the jar. They both look alike. Terry
Please send me a PM and we can discuss your particulars. I am doing some custom sewing Thanks Terry
I also use paper towels to get the majority of the paste and then follow up with wool to get the paste out of cuts , impressions. Terry
The key to using Fiebing antique paste is using wool shearing, either real or synthetic. If you are trying to remove with any kind of towel, you aren't getting it all. I learned the hard way. Tandy sells synthetic wool with as.pads or by the yard. The pads can get expensive, by the yard not to bad. Terry
The biggest problem I can see is Tan Kote is not normally used a resist. You are far better of using Clearlac or Fiebings Pro Resist Terry
The depth of the background is determined by the depth of your swivel cut Terry
If the glue sets for a period of time, it will separate, but it is easily stirred(not sure about gallon size can). Your pieces either need to hit with a hammer or pressed together with some force. I have never experienced the problem you are. I also keep some thinner around to stir in if it starts getting to thick. Terry
Looking at buying a machine but overwhelmed.
terrymac replied to Brigeyboo's topic in Leather Sewing Machines
Where in the bell did this yo yo come from? Whiz is one of the most respected and knowledgeable people on this forum. When was the last time you imported a machine into the United States from China? If a person was highly proficient with sewing machines it may be workable, most of the people looking to buy are not. If this is any indication of what we can expect from you, I respectfully suggest you go find another place to offer your sound advice -
Angelis leather paints, especially if you are spraying. Just be sure and get some "2 Thin" from Angelus to thin the paint. They recommend a 2.: 1, ratio, but I am using more like a 1:1, it seems to spray better. If you follow directions, this stuff is really tough. I don't think the oil dyes will work any better for you. Trying to dye over a white background would be a disaster in IMHO. It might help if you are using the paints as Angelis recommends this be done with some of their neon colors. Hope this helps, Terry
I have been using Clearlac ever since Tandy removed Neatlac and have never had a problem with it subduing color.. I have to admit I never use black, too many problems associated. If you will try Fiebings "Cordovan dye" 99 out of 100 people can't tell it is not black, and you don't have the problems normally associated with black. I have never tried thinning, can't tell you about that. Hope this helps Terry
Easiest way I know is to use a back beveler. It rounds off the "back" side of your cut. Barry King sells them Terry
To get a longer lasting shine, paraffin is used as the final step, usually burnished with some sort of a mechanical device. The problem is this only last for a period of time, especially when worn everyday. I have gone to using edge paint. It is a much more tedious process, but when applied properly it is tough. This stuff lasts. I am using Venis or Herrera, both sold by Rocky Mountain Supply.
Excellent background article. The people from southeast Asia have jumped on this style and many have become proficient. The All Stohlman award winner a few years ago was a little lady from Japan who had actually spent a considerable amount of time with Don King in Sheridan studying under him. The problem when discussing Sheridan style, 95 percent of the people on this forum call anything with flowers and circles, Sheridan. A few years ago, Hidepounder wrote a piece on the various styles of western floral tooling, trying to educate people on what the differences are. I am sure you can do a search on this forum and find this In my mind, the premier Sheridan tool maker is Don Kong's grandson Barry King. He is carrying on the family tradition, using the tool forms started by his grandad. Terry
It might work if the tack is made from veg tan leather rather than bridle or harness. The latter are infused with oils during the tanning process. If veg tan, I would use a glaze reducer to remove the finish on top. Angelis sells a deglazer that seems to work well. I would also recommend Angelis paint as it is made for painting leather. Terry
- 2 replies
- leather painting
- horse tack
(and 4 more)
