JLSleather
Contributing Member
Everything posted by JLSleather
  1. Threaded. Always. Never met a lace that didn't work with them, long as you have the correct size (the XL latigo needle wont work well with 1/8" flat lace).
  2. Same solvent you use to thin the dye. I 'rinse' between colors and 'clean' between uses - short version.
  3. As far as spray patterns, I think you could get about 3/4" wide out of the small tip (not including overspray), and I think twice that wide from the larger tip. Check Ebay, sometimes you can find them brand new for LESS than in the "box" stores. Not sure why, but there they are. I know you said cost not an issue, but if you're like me you don't spend $75 for what you can just as easily get for $50! You can get less expensive models, but I like that parts for these are everywhere. I can go to the hobby store right down the hill and replace a needle if I need to.
  4. Yeah, we've used the VL for years. They just re-designed it recently, so it's a bit different than mine, but likely not much. For what it's worth, I use the #1 tip MOST of the time, with pressuer between 20 - 25 lbs of air. They come with a 1/4 oz cup. Just to give an idea, I think she used about 1 ounce of dye to do the brown background and lettering on this binder, all with the #1 tip (it would have been a bit faster to use the #3 or #5 tip, but then you'd have to clean more than one tip and needle, so not really faster). I have several of these, so I just leave the #1 tip in that one, #3 in that one .. etc. I have several not because I'm saying it's THE best one, but just so when I pick up the next one, it works the same way as the last one ... Still, a #1 tip is certainly large enough to do straps / belts in not much time. Seriously -- 4 ounces is a LOT of dye for a strap. You didn't say which gun you bought. Some really ARE for extremely fine detail (only). The Paasche AB got very renouned for it's use in medical drawings (someone used it - maybe the 80's - to make a painting of the human eye, complete with blood vessels, etc. === That was AMAZING artwork). Oh, forgot .. this binder is about 13" x 13", and the back is colored solid brown same as the front color.
  5. Just guessing from many listings I've seen lately, apparently "hand tooled" is widespread- 'hand carved' is not. I guess if click a shape, emboss a design in a press, this is still "hand tooled" as long as you had a TOOL in your HAND when you edged it, or set the snaps, etc. Perhaps that's marketing poop, or perhaps that's as far as the conscience will allow some to go. You don't have to look far .. there are links to Etsy shops every third page around here. Now, each his own. I don't even sweat it - people have been full of it since before i was born. I just concern myself with MY stuff. If someone asks, I'll tell them how I did it. No charge. You don't have to buy the book. I have a machine, but I'll saddle stitch it if requested. I don't have a clicker press, though I haven't ruled that out and think if I clicked the shape, it'll still be my work. I could go on, but the ones who might listen already know ...
  6. A couple of things : Since you specifically mention making holsters, then you'll want to keep the leather thickness at least 7 ounce (some of the boys use TWO layers of 4/5, for a total of about 9 ounce thick). For very simple designs, not a lot of tools needed. Seriously, to make a simple holster, you could do that in a simple basketweave with... Piece of 8/9 ounce leather (about 2 sq ft for a good size one, less for smaller rigs) Knife to cut out (your exacto kit probably has what you need) Swivel knife, smooth beveler, basket stamp, cam or border tool (for basketweave design tooling), Some type of dye (Fiebing's spirit dyes are a long favorite of many folks), thread, stitchin needles, and something to make holes (I like an awl, but look around the forums), Folder, modeling tool, Hole punch (for belt slots, etc) for holsters, you might consider an oblong (#5) and a regular wood chisel. Together with your xacto, this would let you punch belt holes, too, if you were to decide on the belt to match. Plus, wait - no plus - that really is all you need. Beyond that, because I've made most of the mistakes that can be made, here's my 'add-on'. Spend $5 at a hobby store, if you don't already have transparent triangles. You know, the 30/60 , 45/90 little things likely in the drawing or drafting section. Great for making borders (straight), and many other uses you'll see once you have it within reach. If you're going to lace, spend the couple bucks and get threaded lacing needles called Perma-Lok. Without being long-winded about it, those "prong" needles are crap. Get a caliper, if you dont' have one yet. Doesn't need to say Sharpe or Starrett, just $10-15 at the hardware store (or auto parts store prolly got one too). Measure thickness of leather, distance to edge, size of holes, etc. I "ounce" thickness = .0156" (or about .4 mm) Do not pay someone for "scrap". This is one of the biggest insults I've seen from leather suppliers (and there are many). I recommend going with a USEABLE piece of leather.
  7. Well, ,uhhmm.. yeah, that would work. But if you're running it through a machine, why not put thread in the machine??!!
  8. Call 'em at S-T in St Louis. Their catalog shows it, but it's outdated, so you might check. Go here on the left side go down to "leathercraft kits" and click page 46 - half way down right side column. I've never used 'em, and I pretty much hate that cheap "mission grain" puke in those kits, but I'm guessing thats what this is -- they just put a different number on Tandy's kit.
  9. So, the cutting pattern is missing?
  10. The "old" billfolds - the ones you see in the tooling 'manuals' - were 9 1/4" x 3 3/8", which folds to about 4.5" wide. Updating that, simple enough to make a paper pattern (I like about 50lb bristol) to whatever size you like. Assuming the wallet in that picture is about this size, then using Horween leather you're looking at a whopping $10 worth of materials there.
  11. Yet more proof there's one born every minute. www.etsy.com/shop/crossandlily
  12. what's a 'lady' wallet? got a picture?
  13. Search bar. Block dyeing. Man, this must be gaining popularity (or perhaps just 'speedy' "etsy" style stuff).
  14. If you use those things, you might check with the Tandy store where you are. The one up this way keeps "extra" single letters - you can purchase like an extra "I" or a 7. I don't like those stamps (though I do own some somewhere), but the Tandy girl is worth making a trip down that way occasionally...
  15. That does look like a double-loop. Tough to tell with the colors involved and the small picture, but I'm "almost" sure. One more complicating issue, that's "backwards" from the way you'll usually see it done (including in instructions). Note how the lace slants, low on the left, high on the right. This is not "wrong", but most lacing directions will show it with the lace running high on the left and low on the right. If a smart person was going to GUESS, he might say that this lacing was done .. 1.) From the INSIDE of the wallet, pushing the needle through to the outside, or .. 2.) Done by a lefty. I've seen some lefty lace like this before. What's the difference? Probably none, but it'll look "backwards" in a lacing manual, which sucks for a guy trying to learn the technique! Here's what I mean, done from the OUTSIDE by a right handed person ... AND, if you care for it, here's some diretions that someone (maybe that smart guy?) put up some time ago, showing just how to do that ... http://kingsmerecrafts.com/page96.html
  16. I like the look, but to machine stitch that (with the top stitch like that) might require a patcher, or a post-bed (?).
  17. Alphabet stamps 'suck'. Cheap, and they look it. Search on here for posts by Electrathon about type and typesetting. His text looks as good as any I've seen.
  18. That's actually a pretty good idea. Or a table-top drill press, which would hold a drum sanding disc or a burnishing tool.
  19. Any dye will act a bit like that. Tooled areas are compressed, which can restrict the dye pentetration a bit. On the other hand, the hair blade - as you know - gives it a bunch of grooves the dye can crawl in. Put the two side by side and it looks even worse than it is. So, no, a different dye is no so much the issue as a different technique. Less, or more. Light, or heavy. You just need to get used to not doing it all the same way.
  20. Belt slot? You mean loop for the belt? Simple version, ask him how wide a belt he wants with it. Many belts these days are 2-ply 1 1/2- 1 3/4" wide. "Cowboy" rigs are often 2 1/4" - 2 1/2" wide. While he doesn't want a belt "right now", I don't like a lot of 'room' in there. Eaglestroker's pic above looks like a pretty good fit on the belt - not a lot of room to let the holster move or "rock". I stitch the loop down - screws are just one more thing to bang and scratch the gun. Again, pic above. He can tell you himself, but I 'guess' that the belt loop was sewn on that holster to allow for the thumb break (?). Note that if you prefer a lower riding firearm, you could just as easily sew the top of that loop first - grain side down - then fold it over the belt and stitch the bottom. Same size belt loop, but pistol rides lower. Oh, and Eaglestroker - nice color on that rig!
  21. Only the veg-tan will burnish on the edge, if that's a concern ...
  22. Hard pressed.. wrinkles... .
  23. Yeah, I gave up on SLC. Tthey replaced a hide with wrinklesThey replaced one that was the wrong cut (when you order backs, it shouldn't have a belly). They replaced hides that were clean from scars, but dry (you could actually HEAR the shears going through it). They replaced every time, but at some point you gotta ask how much time you want to spend on the phone. If you like HO leather, you might try this ... http://www.goligerleather.com/saddlery.html Personally, I like backs, but sides are available too.
  24. Nice looking rig, George. Coulda just not mentioned 'stumblin' onto the color combo
  25. Thread exchange got some "royal blue" that might be what you want (?) Comes in 207 all the way up to #554 (tow rope). http://www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Store_Code=TTE&Category_Code=waxed-thread
