TomG
Everything posted by TomG
  1. I used the same as a sealer. Thinned 50/50 with water. But, I stopped using that as I had a couple of reports that the paint flaked off with flexing. Now, I never was able to determine if it was from that or if I missed something on surface prep. I generally use a Q-Tip and some DA to clean the letters and let that dry thoroughly. I've also been known to lightly scuff or sand the tops of the letters to give the paint a place to grip better.
  2. What can I use to 'harden' acrylic paint? I use it to highlight stamped letters on dog collars. I realize that no paint will withstand scratching and such, but I'd like to make it as durable as possible.
  3. I tried one many years ago, but didn't like the bounce that it introduced. Especially for stamps. I also like the 'crispness' that I feel using a mallet or maul. My main stamping whacker are the poly-headed ones.
  4. What the others said. Properly treated and stored leather last many, many years. I have a bunch of belts that i friend let me have and they have been in storage about 15 years. Still good as new. Since you used Mink Oil Paste, I'd use that to give them a fresh coat.
  5. Even if you can find the white dye, don't waste your time. It has an extremely bad smell, and it would take many coats to get even a grey color. Just buy the drum dyed white Veg-Tan and save yourself the frustration and effort.
  6. If the leather is soft, as it appears it might be, use a little rubber cement and glue it to a piece of backer board or bag stiffener. Or even a manila file folder cardboard. Use a pair of wing dividers to mark the exact same distance from each end. From the photo, it looks like it's actually punched off.
  7. We can see the photos now. I. for one, have not solution for you.The only latex coatings that I have used were used as a resist on black dye projects and it was peeled off after. It's almost like you are going to need some sort of vulcanized coating, but not sure how or where to do that. If I want to waterproof leather, I use SnoPruf, but that has to be reapplied from time to time. And, to my knowledge, washing it would take it off or at least weaken it. I've also use Mink Oil paste, but the same caveats apply. Maybe a saddle maker has an answer for you. But, I think the washability factor is going to be your stumbling block here.
  8. Download the Fotosizer program. It's free and does a great job of resizing without loss of quality https://www.fotosizer.com/ Max file size is 1.46MB. Not sure of what photo formats this site accepts, but .JPG is always a good choice. Not sure what you are doing to post the binary type code, but it won't work. Just click on the choose files at the bottom of the message and pick them from your folders
  9. Called Vinegaroon here in the states. Like other said. Avoid Tandy if you want a good leather. I buy from Thoroughbred on KY. Always got good stuff.
  10. A lot of folks have easily modified these to act as a manual clicker. They add a cutting block and plates. This is the 20 ton press. They have a 12 ton for less. At one time, they also had a pneumatic model, but I didn't see it on my quick search. But, it sure would make it faster to do repeated cuts. https://www.harborfreight.com/20-ton-shop-press-32879.html
  11. I could be wrong, but I think is needs to be an odd number of strands. I've seen YouTube vids for 5 stand and I THINK there was one for any odd number. Have you tried cutting 6-strands and just using the same groups of 2 and do it like a 3 strand? I'm not sure what it would look like, but pretty sure it would be weird, LOL.
  12. A lot of it is strap rings and end pieces. The ones with the prongs should have a matching backplate the the prongs go into on the inside of the bag and then fold over. the ones with the 2-3 holes mostly go onto an edge or slot in the bag and are secured with screws from the inside. A couple look like that would go on the ends of the shoulder straps, one or 2 might be magnetic closures. They look like nice pieces, and gives you a good excuse to make some handbags.
  13. Maybe remove the metal pull and tie some leather lace in its place as a pull.
  14. I have an acquaintance who is looking for someone to possibly make some camera cases for him. I am not a case maker and really don't have the time to get up to speed on learning how to do it right. I've made a few fairly simple ones, but am no way a pro at doing them. If you might be interested and can do it for a reasonable and fair price, PM me and I'll forward your info to him.
  15. Believe it, Matt. Look at my OP and see the list of suppliers I tried. There may be others, but Google search doesn't pull up anything promising. I know it's not all-inclusive, but fairly thorough. I have 5 wholesalers I use and between them, I was able to get 50 of the 3/4" x 3" , solid brass, square eye swivel snaps. I routinely pay around $1.80 - $2.00 ea for them. 3 of them were out of stock and I cleaned out the other 2. eBay, Etsy, Amazon, and several others had a few in stock..Limited quantities and anywhere from $4.50 to $8 ea. When you are making a quantity of items that sell for $14 ea,, a 20% - 400% increase in hardware costs equates to about a 60% product price increase. Can't do that and the customer's won't pay it. I have checked into both of those sites you referred to and by the time you add VAT, shipping and customs fees, you're in the same price range as US retailers. Hopefully, supplies will open up soon and bring reasonable prices back. .
  16. Thanks. I only saw them in 1" size but sent them a info request. Thanks Hah. For some reason I didn't even check eBay. Probably because I usually buy wholesale and didn't even consider them. I'll take a look. Ya never know.
  17. Thanks, I've ordered stuff off Etsy that came direct out of China, and times run around 3-4 weeks. Unless it's over one of their national holidays.. I'm not sure of the exchange rate from AUS to USD, but as heavy as these are, I would think shipping from there might be prohibitive. But, it's something I'll look into
  18. Has anyone had experience ordering hardware directly from China? Since Covid hit, I have been struggling to get brass hardware for my dog collars and leashes. Especially the 3/4" brass snap swivel bolts with the square eye. I spent hours searching my normal suppliers and new sources and found everyone either sold out or 3 times the normal price. I've checked OTB, Buckleguy, CDW, Batz, Beiler, Ravenox, Amazon and a few others I can't remember of the top of my head.
  19. I used to use blue tape on the back, but with some leathers, it pulled up the fibers and made it sort of fluffy, for lack of a better word. How much, if at all, depended on the quality of the leather and what part of the side I was cutting it from. Since then, I dip dye 95% of my work - mainly strap type of products. I then use Molotow 15mm markers to apply an edge color of my choice and after that dries, to apply a little liquid glycerin soap to burnish the edges with. Makes it super easy, effective and most of all, clean. https://www.amazon.com/dp/B008H47HP2/ref=twister_B07GBDY6LH?_encoding=UTF8&psc=1
  20. Shoot them an email and ask them. It's their leather scraps and since they make boots with it, they would be the best ones to advise you. Be sure to show us some of your finished product!
  21. Shoot us a photo when you finish!
  22. Years ago, the letter sets like Tandy's were made of a different metal than todays. Lots of folks heated them up on a gas stove to do this, even going so far as to burn the letters in. In the past 10+ years ago, they have gone to a zinc pot metal that melts pretty easily. I have one of the inexpensive heat presses off Amazon and it works like a champ. I use 125 degrees C (257F) and press the foil for 2 seconds. Works great. If it were me, I'd try it by heating the stamp on an electric stove, skillet, etc, that I can adjust the temp on and measure it. Put the letter face down (no handle) for a few minutes, checking it frequently, then stabbing the handle on and quickly doing the stamping on some scrap. Another remote possibility, depending on the letter size, is to check eBay and see if you can find individual brass letters and just buy those. They can heat up nicely. Best of luck!
  23. Already checked with the 2 folks I know in my area. No luck. Moot point now anyway. She decided to go with the standard western set, so it's all good. Back when Chuck Dorset and John Pribbenot ran the local store, I could have done that, as I was a distributor back then. Since then most won't allow it. Moot point now anyway. She decided to go with the standard western set, so it's all good.
