Ditto what BeaverSlayer says, It is an oxygen scavenger used to preserve foods and prevent oxidation. Also used in steam boiler water treatment to reduce the residual disolved oxygen level to less than 20 ppb. Tom
How much can you disassemble without doing more damage? If there is room to work ... You can lift the leather away from any backing material. Cut a patch to be inserted behind the leather. May need to skive the edges to reduce the transition around the patch. Use a slower setting glue and work it into the surface of the patch and the underside of the leather. Press it all together and let it set. Depending on what if anything is behind the leather, you may be able to use a roller to help press it together and roll out any bubbles. I've done this with leather jackets and had an almost perfect repair, hard to see or find after it was finished. Didn't have to rip the lining out of the jacket. There is no glue that will hold the leather edge to edge. Also as the leather is very old, dried out, etc. it would only tear beside it if it did hold together. You may need to remove fuzzies from the edges to provide a cleaner edge to work with. This type of repair can be used for small cut or tears as well, however you may have to cut the small tear longer to give enough flexibility and room to work the patch and glue in behind. There is a post somewhere here about a material used to fill in cracks on shoes that may be used to fill in surface cracks. I think it was sort of like a latex and painted on in layers to build it up. Before you start doing the repair, try to condition the old leather by working a little neatsfoot oil or other leather conditioner into the surface of the leather to make it more flexible, but DON'T saturate it. Glue doesn't stick to oil, and you don't want the oil getting on the clothes of anyone that sits on the chair when you are finished the repair. Take your time, go carefully. Tom
When you add a hint of green, I would keep it closer to the stem. The outer edges of the leaf dry out first, so shouldn't have any green left. And I like it without the green. Looks like an inverted carving style, which is fine. Been doing some myself. But as mentioned, reduce the amount of matting. The leaf surface in nature is smooth between veins. Tom
There should be a piece of leather, sort of like a welt, between the outside and the lining leather. It should be the same thickness as the magnets. Punch a hole for the magnet to rest in. Glue the magnet plus welt to the outside layer. You can use a layer of strong cloth over the magnet to the welt. Then glue the lining in place over all of it. Depending on where your folds and stitching lines are, you could do some decorative stitching to provide some more strength. And you may need to skive the edges of the welt to help it blend in. Mount the magnets in a welt in the purse body as well. Won't likely need any extra reinforcement so no cloth. Make sure your magnets are placed with the right polarity before you glue up. As a side note, I tried using just a thin roughly 24 AWG piece of sheet steel in the flap to keep the bulk down. It doesn't hold as well as using magnets in both pieces. If you do use a steel plate in the flap, use several magnets, and larger diameters, like 3/4 inch to get enough holding power. Do a mock up to see if it has the strength you want. Tom
Floral Spur Straps
Northmount replied to Double U Leather's topic in Saddle and Tack Accessory Items
Fantastic! Tom -
Or punch a hole in the belt to fit, epoxy the leather to the metal tip, then cut or file off the excess post, or take the post off completely and just epoxy to the belt. Tom
Bill Fold Critique Needed
Northmount replied to jamos1978's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Pretty good for 6 days! You already know what you need to work on, so the next step is more practise. And when you think you have practised enough, do more practise. Tom -
And you can attach a flat bed adapter to a cylinder arm machine. Depending on what parts you are sewing, sometimes the flat bed makes that part of the job easier. Tom
Wallets In The Snow
Northmount replied to Bifrost's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Pretty nice. Lots of color. Check the tension on your sewing machine. I notice in the first couple pictures, the knot is pulled up too high. Tom -
Made A Check Book Cover Today
Northmount replied to Fd3615's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looking pretty nice. Keep it up. Tom -
White Powder Crystals On Leather Surface
Northmount replied to chevvy64's topic in All About Leather
Warm them with a hair dryer to see what they do. If it is fat, will tend to melt as it gets warm. Tom -
To help reduce the wrinkling in the lining, form the leather as you glue the lining in so that it is curled about halfway to the position it will be when fully folded. I assume you are concerned with the flap. Note that the flap will not return to flat as it has to stretch the lining to do that. If you can't tolerate not being able to return to flat, then you can design (force) wrinkles in the location you want by gathering a little extra bulge in the lining as you glue it. Try it on some scrap pieces first to see if it is doing what you want it to. Tom
Google Search Results Containing Malware
Northmount replied to Dennis Oakley's topic in Feedback and Suggestions
Works fine for me. You likely have a root kit virus, pointing you to a rouge DNS server. Search for malwarebytes and install it and run a scan. Also download tdsskiller from support.kasper.com/5350 install it and run it to detect and fix. I had a similar thing a month or so ago, also related to google searches, but couldn't get any results from a google search. Hope this helps Tom -
I second using a hair blade. Try the fine and coarse to see which looks the best. I'm tending to the fine blade, since the thistle is wispy. Tom
Difference Of Craftsman Oak, Oak Leaf, Live Oak Tooling Leather?
Northmount replied to naturalisme's topic in Getting Started
The catalog has some description. I'll abbreviate their descriptions. Live Oak - Best, top quality, long life, superior performance, excellent carving, tooling, dyeing, oiling qualities, American sourced Oak-Leaf - Good, premium import, excellent tooling and embossing, occasional blemishes and brands, fine hand carving leather Craftsman Oak - Economy, imported, medium firm temper, stamp, carve and dye well, low cost, may have brands, blemishes, insect bites. Tom -
Check that your leather scraps are vegtan leather. Depending on the bag of scraps you got, there may be leather that isn't suitable for stamping. If you haven't cased the leather, read up on how to properly case leather before carving and stamping. See http://leatherworker.net/forum/index.php?showtopic=19121&hl=%20casing%20%20tutorial&st=0 casing tutorial by Hidepounder (Bob Parks). Dry leather doesn't take impressions well. Tom
It would be great if people would read the last few posts in a thread instead of just the first one or two. Look at post number 88 immediately above your post. Tom.
Try applying very light layer of glue to both pieces and let set a little before pressing them together. Or use contact cement, but still keep the layer of glue thin. For very porous surfaces, you may need two coats if the first coat soaks in and dries to quickly. Two thin coats are far better than a heavy coat. Remember for contact cement to let the glue set until almost dry (very little tack) before assembly. Press together with a roller after you have positioned the seam correctly. With most contact cements, you have little chance of repositioning the parts if you aren't lined up correctly. Avoid getting any glue on surfaces that are to be dyed and finished. Will show up after the dye or finish is applied. Tom
Try using a deglazer to remove anything on the surface that may be impeding the dye soaking into the leather. Also try using some oxalic acid to remove any stains. Otherwise, a lot of posts recommend thinning the dye, then building up the color in layers, allowing to dry and buffing well in between. Airbrush has also been recommended. Not too expensive so might be within your budget. Lots of info on airbrushing here if you want to do a search. Great job on the hat, and keep testing different ideas for dying the leather before actually doing the hat. Too many of us are in a big hurry and jump right in without any testing or practice. Tom Edit: Some do dampen the leather slightly before applying the dye. Some also give the leather a very light coat of oil (Neatsfoot or Extra Virgin Olive OIl (EVOO)). Neatsfoot will darken the leather more than EVOO.
Found a 270 page PDF called Bush Leather Work by Ron Edwards. http://blog.survival-goods.com/LIBRARY/Manuals/bushcraft%20leather%20work%20PDF.pdf Lots of info on lace cutting, plaiting, making pouches, bags, belts, etc. Hope you enjoy looking through it. Tom
Go for it. You may be able to work through a local college's continuing education program to help look after the logistics. Though that could lock you into a lower hourly rate for your time. Some high school con-ed programs may do the same. Also consider libraries. Tom
Descriptions and pictures might help you sell these kits. Reminds me of an old saying about "buying a pig in a poke" or something like that. Your location and shipping might help too! Tom
Personal Gallery Picture Problems
Northmount replied to LNLeather's topic in Feedback and Suggestions
This is one of the best places to be! Happy New Year to Joanna and the rest of the crew that makes the site work, and Happy New Year 2013 to all the rest of you leather workers out there! Tom
