I had some terribly smelly leather too a few years ago. Smelled like urine. I used liquid saddle soap, literally soaked it, followed by rinsing the surface with water and let it dry. It helped some. Finally bleached it with oxalic acid followed by another rinse. The combination worked. Might work for yours too. Then it needs some NFO.
Does car upholstery count as light or medium?
Northmount replied to JessH's topic in Getting Started
@JessH hasn't been around since 2021. When you want to get someone's attention, either quote some part or all of their post or tag them using the @ symbol followed by their username and pick the username from the pop up list. You may have to scroll down some to see the list. When you properly tag a person, the tag shows up like this post. If they aren't tagged or quoted, they may not receive a notice email.- 11 replies
- light leatherwork
- medium leatherwork
(and 1 more)
Water based is a better description than acrylic. The resist is able to block water based dyes (and of course acrylic paints). The solvents in pro dyes and other alcohol based dissolve the resist. I have found they even penetrate lacquer based finishes to some extent. From Tandy's site: Eco-Flo Leather Dye is a water based, low V.O.C., penetrating leather dye for use on natural veg-tanned tooling leather. It's great for overall solid color dyeing or background dyeing.
shoemaking Shoemaking machines for sale in Montreal Canada.
Northmount replied to Dayan's topic in Old/Sold
Please provide photos and descriptions including manufacturer and model numbers where applicable. Please read the marketplace rules and comply. Pricing is required. Any shipping info or restrictions are also required.- 2 replies
- eyeletmachine
- glue activator
(and 4 more)
Wow. Love this design and concept!
Atom 20 Ton Clicker Press-Asking $6900 Gently Used MSRP $12,300
Northmount replied to GretchenDesign's topic in Old/Sold
@GretchenDesign Moved your post to the marketplace. The marketplace rules are here. -
Cobra Class 26 Loose Stitch and Noise
Northmount replied to Bullduke's topic in Leather Sewing Machines
This is called dry friction. It generates random vibration frequencies that excite the natural frequencies of connected parts (causing resonance and high vibration amplitudes). So needs to be lubricated. Brass bushings may be oil-less self lubricated or not. Self lubricated type are often used in fractional horsepower motors. If memory serves me correct, these shouldn't be oiled. I don't know if oiling would result in increased friction as the oil is dispersed, squeezed out or thrown out.- 18 replies
- tension
- loose stitch
(and 1 more)
@NancyLou moved your post to leather sewing machines. This is where the sewing machine guys hang out.
@Yolonda Moved your post to Leather Sewing Machines
- 3 replies
- tippmann boss
- pfaff
(and 2 more)
Hitting the corner with the needle
Northmount replied to PlanoMike's topic in Leather Sewing Machines
Moved to leather sewing machines. -
Weaver Mighty Wonder 8-Ton Hand Operated Clicker Press
Northmount replied to Lockeland Leather Works's topic in Old/Sold
@Lockeland Leather Works You have an interested party above. @sw2surf You need to tag or quote a user so they will get a notification.- 7 replies
- clicker press
- for sale
(and 2 more)
GALLI RC-50 Single Edge Painting Machine (110V)
Northmount replied to Giannisamira's topic in Old/Sold
Please post your photos on this site. 3rd party host pictures often go missing rendering the post useless. If you need to reduce the file sizes take a look through this thread. There are also lots of additional helps on the web. -
Moved your post to "wanted"
I received an email back from Mat: ----------------------------------------------------------------------------------- I'm still active in my leatherworking but unfortunately I don't have those pictures anymore. They were stored somewhere and I don't believe this service is still operating. Sorry about that. Also I have moved a bit more towards watch straps and wallets. If you are interested I've made few video tutorials. https://www.youtube.com/@mkleathers3453 If you find them helpful to the community feel free to use them. ----------------------------------------------------------------------------------- Just had a quick look at his video Custom Leather Pouches, Cases and Bags. Some interesting items and ideas. It's mostly a promotional advertising video.
Email address missing, goes to MSN.com.
Techsew 4800 PRO Like New - NORTH GTA Ontario Canada
Northmount replied to adventureleather's topic in Old/Sold
I assume that this is CAN$. -
Moved your post to the Marketplace, Business and Estate Sales. It doesn't belong in getting started. Please read and comply with the MarketPlace Rules. It appears you are located at or near Moncton, New Brunswick, Canada according to your IP address.
Please read and comply with MarketPlace Rules You must supply your location (Europe, Mars, Etc.) and price in US$. According to your IP address, you appear to be located near Boston, Massachusetts, 02112. No email address supplied as identified in your post, suggest interested parties message you.
Moved you post to leather sewing machines. This is where you can find the guys that can help you. You should add your location to your profile. Helps to find the best info and locations to help you. You appear to be at Ballyogan (Leopardstown), Leinster, Ireland according to your IP address.
Juki 1508 bobbin and tension
Northmount replied to Leatherface320's topic in Leather Sewing Machines
Moved your post to leather sewing machines. This is where the sewing machine guys hang out and most likely place you'll get some help. -
Emailed the business, no response, but did not bounce. Also the op lost the pictures according to Just one of the problems using 3rd party hosts.
Also same as a Techsew 2700.
@shug Merged your 2 posts on strap cutter blades.
Wow. Great job. Very realistic.
