Northmount
Moderator
  1. These links refer you to the same machine under different names. So you can look up specifications and comments under Consew 227R, Seiko CW-8B, etc. it's amazing what information you can find when searching here. https://leatherworker.net/forum/topic/87827-brother-ls3-c51-050/ https://leatherworker.net/forum/topic/46555-brother-ls3-c53b-walking-foot-cylinder/ Tom
  2. Use sand paper. Tom
  3. @Oneeyedfriesian Moved your post to Saddle Identification Tom
  4. Guests can't PM. Provide a contact email or answer/ask questions here. Tom
  5. @Bellandra8 Moved your post to the Marketplace Tom
  6. 135x17 are conical point for fabrics. 135x16 is a chisel type point used for leather. It will cut threads in fabrics in instead of sliding through between threads. Other than that, they have the same specification for length, diameter, etc. There are several different types of leather points, diamond, etc. Needles and stitch type.pdf for needle size versus thread size see this chart. Tom
  7. You can't. But I could move it to the marketplace for sale if you haven't already started a new post there. Tom
  8. Their ISP is Cloudflare.com located in the USA. Tom
  9. I found some about a year ago, name included Lemon scent or something like that. Don't remember what store it was in. Tom
  10. Depends on how often you use it, and what you use it on. You can harden it if you want. Black pipe is carbon steel. Remember, the harder you make it, the harder it is to resharpen when needed. A machinist built a post for me that was part of a mechanical accounting machine many years ago, and case hardened it with potassium cyanide. He had made it a little too thick where the slide was supposed to fit over it. Tried to stone it down, but couldn't even touch it. Took it back to the machinist, and he said how am I supposed to do anything with that now? I asked about heating it back up to soften it? He said, yes that would do it. So he fixed it and case hardened it again. Was interesting to see the chemical reaction as he dropped the red hot post into a little pile of potassium cyanide. Really sputters! Don't try this inside or you'll poison yourself. Deadly stuff. Tom
  11. I would look for pipe that has the inside diameter that you want. If you use the pipe you suggested, you will have to remove material from the inside when sharpening, thus any punching you do with it will wedge the leather cutout inside the pipe making it hard to remove and binding up the next hole you punch. Looking at a pipe table I see that 1.5" schedule 30 has an ID of 1.65". Sch 40 has and ID of 1.61". Both are close to the desired size of 1.625" (1-5/8"). Sch 40 is a commonly available pipe, also listed as STD wall. Tom
  12. @Hitopstamper Moved your post to General Saddlery Discussion. Tom
  13. Check out panavise parts and adapters. Tom
  14. @Mark842 Please see the above post. Tom
  15. Cute photo, good idea for a story. Tom
  16. Needle sizes and thread size chart. For hard or thick leather, go up one size larger needle. https://www.tolindsewmach.com/thread-chart.html Tom
  17. @MtlBiker Moved your post to leather sewing machines. Tom
  18. The OP hasn't checked in since October 8, so I suspect has no real intent to answer any questions or to sell the machine. @janosm If you are really interested in selling your machine, you need to answer these questions and to update your post as you said you would do several days ago. Tom
  19. Nice work Stewart! Tom
  20. Hey @ABC3! Did you get it all sorted out? Let us know please. Tom
  21. Have you looked at Grainger CLARKSON-OSBORN https://www.grainger.ca/en/product/1-5-8IN-ARCH-PUNCH/p/CSBMS10110 Tom
  22. I had some awful smelling veg tan leather from Tandy once. Cleaned it both sides with liquid saddle soap, really saturated it. Then went over it with Oxalic acid 1 teaspoon crystals to a pint of water. Laid it out flat to dry. Turned out to be a good piece of leather after all! Tom
  23. You probably have thread wrapped around the bobbin basket and shaft. Tom
  24. Moved your post to Leather Sewing Machines. Tom
  25. Moved your post to Leather Sewing Machines Tom
