Northmount
Moderator
  1. See these links for several comments. https://leatherworker.net/forum/topic/38710-can-i-use-resolene-or-tan-kote-on-leather-jacket/?tab=comments#comment-240467 https://leatherworker.net/forum/topic/57765-dyeing-a-light-brown-jacket-dark-brown/?tab=comments#comment-372914 Tom
  2. I would use a scratch awl instead of a groover to mark out the cut lines. I think the groover gives too wide a line and lets you wobble back and forth a bit within the groove. Then cut with a very sharp knife. Don't attempt to cut all the way through in one pass. The more you try to cut through in one pass, the harder it is to keep a straight line. Use a stainless steel ruler with some cork on the back as a guide. I see from your IP address you are in Okotoks. Not too far south of me! Tom
  3. Also don't lift the foot too high or it will release your top tension. Tom
  4. @MusicCityJen Moved your post to Saddle Identification ... Tom
  5. Just tried this link and it tells me "The administrator has blocked your IP from accessing this website". I assume that he has blocked IP addresses outside of the USA. Tom
  6. @PhillyJay moved your post to leather sewing machines. Tom
  7. Let's stay on topic here. It was about anthrax, not COVID-19. A few posts hidden that were straying well off topic. Tom
  8. @Loquai Moved your post to leather sewing machines. Might get more / faster response here. You should also take a look at this thread. Tom
  9. The deciding factor for you could be who is the closest supplier and who gives the best warranty and followup support. Tom
  10. Northmount
    Waiting
    Another great piece Stewart! Tom
  11. Quoted from a site selling tokenole " Note: Use caution when applying Burnishing Gum on leather that is going to be stained, antiqued, or dyed as it may resist or block penetration." Also take a look at this post. So the best thing is to be careful and avoid contaminating the surface so you don't have to clean it up. You might find that Fiebings Deglazer will work for you where needed to clean up these spots. There are many posts here about burnishing and applying various edge coat treatments here if you want to take a little time to research them. Tom
  12. If you don't get the lemon juice (acid) evenly spread over the leather, you will have blotchy spots where the acid was stronger or left on longer. So are you complaining about the lighter areas, or the dark spot I see in one of the bleached areas? I'm not sure from your description. You can also use oxalic acid to bleach the leather. Mix 1 teaspoon per pint of water. Rinse the surface off after with fresh water. That applies to lemon juice too! Tom
  13. @Choeur Moved your post to Leather Sewing Machines. You'll get more help here than in help wanted. Also every post in Help Wanted has to be approved by a moderator before it can be seen by members. Tom
  14. @ellene Moved your post to leather sewing machines. You'll get more attention from sewing machine guys here. Tom
  15. A servo Motor, but not a digital type. Has brushes to feed the armature. Tom
  16. @Frodo Let's keep false politically biased information out of your posts. This is s leatherworker site, not a political FB page. Tom
  17. Here is a cahrt for sewing machine needles and thread that might help you. https://www.tolindsewmach.com/thread-chart.html Tom
  18. You are fighting the laws of physics. The foot is squeezing the leather out to the side. Cut your projects over-size and trim to required dimensions after sewing. Reduced presser foot pressure may help but if reduced too much, will result in the leather lifting with the needle's up stroke and skipped stitches. Tom
  19. As mentioned, HEPA filters are NOT for gases or vapours, just for dust. Respirators have filters available for organic solvents. If you use the same materials for recirculating air back to your room, you will find that it has to be capped off tight when not in use, otherwise next time you go to use it, its vapour absorbing capability has been used up just on ambient air. Since you are moving more air than what you would with a respirator, it also needs to be much larger than the respirator filter! Activated carbon filters work, but again must be capped off when not in use to save its capabilities. Regardless of what your filter material is, you also need to test the filter to see if it is working. So you put a fume source next to the inlet of the filter, and sniff the air at the outlet. If you can smell the glue/solvent, the filter needs replacement. The best has been mentioned above several times; extract the air and dump it outside. Since you are only doing small jobs from time to time, the heat loss is inconsequential. Not like you are using an auto spray booth with huge volumes of air removal that must be made up with filtered conditioned, heated air. If you want to run something full time for 8 hours per day and are concerned about wasting all that nice warm air, then you should look for a small air to air heat exchanger. Draw fresh air from outside, dump it into the room, exhaust from your gluing station to the outside. Keep about 3 to 6 feet between fresh air inlet and the exhaust outlet to prevent recycling the fumes back to your work space. Many high efficiency homes are now built with air to air heat exchangers, so they are available in many different sizes and different types of control. Unless you are using it a lot, you will find that payback will likely be around 10 years or so at a guess. I have a residential air to air heat exchanger that was built about 30 years ago as a research project. I have it installed in my workshop attic and use it to supply tempered air to a hood/helmet that I use when doing dusty wood work, or applying paint or varnish to projects. It exhausts room air and exchanges heat with the incoming air to the helmet (works winter or summer). Means I am tethered to a hose which is not all that convenient at times. Means no one else can be in the shop at the same time as they have no protection. It sure saves me a lot of headaches and sinus problems. Tom
  20. If you go to the home page and scroll down, you will find the forum names along with descriptions. There is also a search box upper right. When you get into the search you have options as to what search parameters you want to use. You can also do Google searches like this: "site:leatherworker.net finishes top coat" without the quotation marks. The site parameter restricts Google to searching the site specified. Add what ever parameters following that you want to search for. It is a Google search so follows all their standard conventions. Tom
  21. You need to resize the pics to fit within the limits. 800x600 pixels will do, can then post about 100 pics with no problems. See this link for some suggestions. Lost of other info in this thread too that might be useful for you. Please upload your photos here. According to the rules for marketplace, which you should read and adhere to, you need to post the price you are selling the machine for. Tom
  22. @FleurFeroce moved your post to leather sewing machines Tom
  23. You can upload to Youtube and post the link here. Tom
  24. @MichelleWall Moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners Have you looked through this part of the forum? Tom
  25. No picture attached. There is a thread about posting photos that might help you. Some of it is dated, and not fully applicable, but should give you some ideas of the process. Tom
