catskin
Everything posted by catskin
I actually have a clutch motor on it. But have not sorted out how to make a convenient lever for engaging it. With my speed reducer it goes at a reasonable speed. Just thought the variable speeds with a servo would be nice. I would add a picture but seems the one picture I posted a long time ago took up all my allowance.
From the number of responses kind of looks like I might be the first to try.
Just wondering if anyone has put a servo motor on a BUSM / peirson # 6 machine? Did a search and no luck.
That price is high. BUT there is someone not far from me that is trying to sell one that does not work for $ 950.00. YES $ 950.00. She tells people it good but friend tried it and does not work. Badly worn.
It is similar to a 20-2 but is not a 20-2 likely some 20 sub class I own a good working 20-2 so know a fair bit about them. The 20-2 does not have the gear inside the flywheel nor does it have that kind of foot setup or the coil spring on the front.
Are You Able to Identify this Simanco Part?
catskin replied to Evo160K's topic in Leather Sewing Machines
It also looks near exactly like the one on my Adler 20-2 even the base. -
Sewing Machine Recommendation for Small Leather Goods?
catskin replied to YSRASupply's topic in Leather Sewing Machines
My suggestion would be to take leather as many ply as you will need to sew. Then add at least one more and test the machine. The reason for more is to be quite sure you will not be using it at the limit of what it can do. Even try to see how much more it can do if pushing the limit. For example if it will handle 2 more ply then you think you will be sewing that's good. I do not know these machines, what I advise would apply to any machine. -
New Tandy Craftool Pro Stitch Master made by Sailrite
catskin replied to Treesner's topic in Leather Sewing Machines
Plus 1 for Bikermutt!!!!! -
I know this is a really old thread but this is still on topic for mice. If you could attract a few weasels or turn loose a ferret or 2 mice would be gone shortly and stay gone.
From reading on here a lot it seems that there are more then one company that is copying the juki 441. And some seem to have better quality control than others. And that the poor ones get sold as like Cowboy, Cobra etc. on internet E-bay type of places.
- 28 replies
- cowboy4500
- stitch loop
(and 1 more)
Attachment or something that will make an overlapping seam?
catskin replied to VYO's topic in Leather Sewing Machines
The picture does not SHOW what you are describing. It shows flat pieces laid overlapping. -
From your picture it looks like simply putting one on top of the other and sew. -
If Cowboy machines now are like that I am glad I bought mine several years ago. There are apparently lots of companies copying the JUKI and some do better than others. That is why I wondered if this was maybe a shipped from china machine that was not from the same place Cowboy comes from. But claimed to be equal. For example those parts in the pictures don't look stainless steel as mine are.
- 28 replies
- cowboy4500
- stitch loop
(and 1 more)
When and where did you get this machine? Hardly any parts look like my Cowboy 4500 the parts on yours are all rough where mine are smooth and shiny I have never had to make any adjustments to any parts that came with my machine. Tension discs thread guides bobbin case all look cheap made compared to mine. Or is this just a copy made by somebody else that is supposed to be like a Cowboy.
- 28 replies
- cowboy4500
- stitch loop
(and 1 more)
With the rosin you may not need to sand paper the pulley. Just rib it on the belt. What I do is hold the rosin in my hand or warm it up a bit and run the belt through my hand. Its best to crush it a bit to a powder. It can be bought at most tack shops cheap. I bought about 1/2 lbs. for a couple dollars a few years ago.
Another option I have used on belts that are older and a bit stiff is to make a hole with an awl and use thread and a needle to connect the ends going round and round through the ends that leaves a more flexible joint than the wire clip and on older belt it is less likely to break out at the hole. I did this 30 years ago and its still going. It broke out at the clip in 2 days. The rosin works too, rodeo riders use it all the time on gloves and bull ropes.
Maybe NOT 5 but 25 or 50!!!!! Cost recovery.
The package that the seller put them in says 180, with a micrometer they measure the same as 180 for my Adler. Will have to look on them to see if they have 180 or the old number.
Some body made the parts to build that machine. So while it might not be cost effective to hire someone to make them there is no reason they could not be made by a person that likes to machine. And where for example a hole is worn bigger in the casting ( frame ) make the part over size that goes in. I realize this might sound unreasonable to some it would be possible.
Since they seem so rare and I only have a hundred of various sizes for my pearson I think I will not give out my source until I get some more. I will have to find out if I might have gotten the last of NOS in size 180 since the package is different from the ones of the other sizes I ordered. They are NOT schmetz. They are in a plain package with no company name only the name of the seller so likely were bought in a huge quantity and repacked at the seller. I will have to take a very strong magnifying glass to see if there is a company name on the needles. Schmetz is NOT on them ,so far all I have made out is a number and what looks like a logo. Stay tuned.
I just got a package of 180 needles for my Pearson # 6 so they are still available.
First frankenstien bobbin wonder for Pearson #6
catskin replied to plinkercases's topic in Leather Sewing Machines
I found the same thing with the one I built. ( pictured on another thread ) getting the thread to wind evenly while hand guiding it is a bit tricky. That might be why the Aaron Martin ones are so long between bobbin and tensioner. I intend to try putting a tensioner on mine at a distance to see if it then winds more evenly. But have not had any problems sewing even with uneven wound bobbins. -
Pearson question re LH shuttle plate
You are right. The pictures shows the cover with the spring but it says shuttle cover spring. NOT shuttle cover WITH spring. -
I can't tell on mine if its threaded or not. The pin is near flush on the outside. If it is it likely is a Whitworth thread. I thought you were close to Aaron Martin they have those slides listed for sale one the website. So would be easy for you to get that plus shuttle and bobbin. -
Jimi, I stand corrected. But it seems that it would have been a good idea for a lot more of the older machines to have had it done. Even now with powered machines it would be a lot easier when you have to make just a few stitches. The old harness machines Pearson, Landis #1 and maybe others had them. So the lighter machines would have been handy that way to.
