Luke Hatley
Ambassador
Everything posted by Luke Hatley
  1. www.Hidehouse.com will have the Bison Leather that you are looking for.
  2. Afine looking project..........your not a rookie no more.
  3. Boom.....Take a trip to the local Music Store that sells them. You'll get a good idea of what size they need to be .....then come back to your shop and get busy making one. ths straps are not hard to make. also here on the L W do a search for Guitar Straps you'll see plenty of photos. Hope this helps you to get started.
  4. The finest Book of patterns these eyes have seen...........
  5. Whitt30 Buy the book "MAKING HOLSTERS" by AL STOLHMAN at Tandy .
  6. Check at your local Gun Shop for "Cold Blue" or the "Browning" solution.
  7. Your Glue Pot needs cleaning.......... I prefer Masters Cement, it is a little thinner. but i do have the same problems as you do. Yes i add the thinner like you. What i use it the plastic container tha i got at Tandy, is seems like i can get a better air tight seal with it.
  8. exqusite piece of workmanship......Knife & Sheath.
  9. SPARKS I NEED TO BORROW THE LOCK COVER...QUICK and A HARD HAT. ( yes those white spots on the ground are Hail Stones)
  10. the one in it is pretty small., i 'm sure a larger bobbin could not fit. Thanks I do beleive that you solved your own question...............
  11. Ray there are a lot of good machines out there and this is one of them........ clinder arm.....servo motor.....flat bed table attachment, if and when i need it. also it has a compound walking foot. the machine is set up for 69 size thread or can be re set for size 138 thread in a jiffey. try the Juiki out.
  12. Doug just do a search for "turtle feathers " paint
  13. Tom Sweed......You have came a long way, and i would like to say "its a pleasure to know you and to stay abreast of your Leather Work " The straps are awsum
  14. Jack i wished i could be of more help to you, what i would do is to buy a pair of leather gloves that would fit the hand that you need it on, and then take leather away or add to it. hope this helps you.
  15. If you dont like the Fiebings Dyes Take a look at the Anglus Dyes there might be a color that will match what you want.check the web site "www.turtlefeathres.com" By all means go for the Air Brush, also try the Prevail sprayer that Tandy sells,
  16. Sooo... Thats what you Buckskinners do when you cain't leave the camp on a rannie day. That is a good looking item, i'm thinkin i need to make me one of thoes..... Sparks you done well & you'll go far.
  17. also when you buy the new snaps get THE STAINLESS STEEL ONES.................
  18. In the Building supply dept. look for a "sheetrock" framing square.....
  19. IF IT IS CRACKING ...........IT'S GONE..........
  20. Joker great looking seat......H will be Pleased with it......... Question: what did you put on the Edge to finish it with ?
  21. You can do the repair yourself.... But use Barge or Masters Contac cement. I wouuld open the lining up some and apply the patch, sew the lining back up, weare the jacket and enjoy the $$$$$$$ that you saved....
  22. one set on holster making , it contains 3 discs.. when you see him sewing the loops, you'll be amazed.........
  23. Joker , check this product out. MELTONIAN....nu life... Color Spray.I have used it with good results. You can probably get it at your local shoe repair shop.
  24. Buy the Bianchi DVD you'll never regret it, it has been very helpful to me. Yes he will teach you to make Gunbelts, No he won't teach you to use the Bag punch to cut slots for attaching the Bullet loops . He will teach you to ues your sewing machine for that job.
  25. Nice looking strap.
