Everything posted by mlapaglia
Anyone can claim anything they want on a website. Those dog collars would be more of a patent iss and not a copyright thing. It’s to generic an object to be patented any more. A design on the collar could be a copyright but not the basic collar. Consider the Kleenex. They copyrighted the name and the patterns but not the facial tissue it self.
Saffron prices at wholesale and retail rates range from US$500 to US$5,000per pound, or US$1,100–11,000/kg. In Western countries, the average retail price in 1974 was $1,000 per pound, or US$2,200 per kilogram. a bit much to experiment with.
Very nice.. I love the idea of the Para cord for the braid.
Have you tried a different bobbin? If the bobbin is wound too tight or inconsistently it could cause the problem you are having. Mine did that once and when I changed the bobbin it worked again. Also make sure the thread is coming off the bobbin the right direction. If its in backwards it will screw things up. It should come off the roll counter-clockwise. Let me know if that doesn't fix it. Michael
Why metal instead of a hardwood? Any special reason? Michael
That's how I do them. I also use an oblong 1/4 punch for the lace hole down the center.
We are sorry. We try not to seduce people in to the world of processed dead animal skins but it's difficult to keep some people away. Please ask your wife to forgive us and hopefully things will get better Until then all you can do is accept that you have been assimilated and go with the flow.
Never argue with a fool. It brings you down to their level and they will beat you with experience.
I understand you are trying to get away from veg tanned but what about Harness Leather? The grain will have a higher durability and be more water resistant than saddle leather. The only downside would be that it is not "rugged" looking. Just a thought. Michael
The red one can be purchased at Wal-mart or any store that has a sewing section. It's a standard seam ripper.
Reslone
mlapaglia replied to DuncanSinclair's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
90% or greater rubbing (isopropyl) alcohol will remove resolene. You might need to redye the leather after removing the Resolene. Make sure you cut it 50/50 with water and let the first coat really dry, over night, before the second coat. I use a damp sponge or cloth. works fine. -
Tooled Pancake Style S&w Shield Holster
mlapaglia replied to smusser's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Let your leather dry out a little more. It looks like it was too wet when you did the stamping. What do you have under the leather when you stamp it? It might be that there is too much flex when its hit. You have a good start and will do just fine with practice. -
Start with a quality piece of leather that has a smooth back. A little LIGHT sanding and a glass slicker and it will look really good. The other option is to use contact cement to hold 2 pieces together. I know you didnt want to use cement but a good contact cement along with doing a good job on the edges and you will not see a line along the edge. The contact cement will hold well and forever if you apply it correctly. YMMV
Reslone
Cut it 50/50 with water. I use a disposable foam brush to apply it. As long as you cut it you will not get bubbles. I put on 2 coats and it works fine. -
Moving The Shop Out Of The Home...
mlapaglia replied to cgleathercraft's topic in Leatherwork Conversation
Being a renter the only option I see that remains viable is the trailer. I'm not sure how advantageous having your entire shop at a show but it is an option. Thats my 2cents. -
Problem Saddle Stitching English Bridle Leather....help!
mlapaglia replied to Redhairing's topic in Sewing Leather
Yes they are meant to go all the way through. -
When you pull the belt through the buckle to get it tight enough to put the tongue in a hole are you bending the belt a lot at the buckle? Those kind of wrinkles can be caused by bending the leather backwards. This can happen when the belt is pulled through the buckle to tighten it. A roller buckle helps prevent this. Here is an example of a roller buckle
What dye are you currently using, which company and type? How are you trying to dye it?
First Post - Saddle Stitch Question.
mlapaglia replied to DeWayne Hayes's topic in Leatherwork Conversation
Stitch after you dye and apply the finish. Take a paper bag and wipe off the excess wax before stitching. Pull the thread between your fingers protected by brown paper bag. This removes the excess wax. Is that thread or Tandy's waxed Sinew? FYI, Tandy makes crap thread. -
From a weight standpoint the cast iron is heaver. The Aluminum version has had some updates to it over the years. There seems to be a nostalgia for the Cast Iron but I prefer the Aluminum version as it is a little lighter and tends to run a little bit better. Either one is a good machine. You can always get the Iron one updated at the factory. Its not that expensive. Short answer, The really isnt that much of a difference to make a person switch from one to the other. It's more personal preference. Michael, FYI I have had an AL one for almost 6 years. Love it.
Someone needs to sell a good one. Low price is not a large requirement. Using a Boss I need a good winder.
Rough out is also what you make when you cut a left hand pattern and you need a right hand holster. Ask me how I know
When I order a Herman Oak side at 8/9 the minimum thickness is 8oz and the Max is 9oz. There is nothing thicker or thinner than that. I have seen Tandy state that their light Saddle Skirt varies from 11 to 8 as they are not split to uniform thickness
