wizard of tragacanth
Contributing Member
Everything posted by wizard of tragacanth
  1. Fiebing's probably changed the name from Pro Oil Dye to Pro Dye in order to eliminate the general confusion of people thinking that the "Pro Oil Dye" was oil based. Regardless of the formula and percentages therein, there is a significant difference in performance between the Fiebing's Leather Dye and Fiebing"s Pro Dye. Most pros and many rank amateurs, like myself, use only the Pro Dye because it is superior. nick
  2. That is an interesting design and I like the color, and I am sorry to be critical but I would have put the maker's mark on the back. My stamp is similar to yours. It is a utilitarian stamp, not a work of art. I would not put it front and center. If anything, that is where the owner's initials belong, and yes, I know you are the owner! Anyway, that's my thoughts. Again, sorry to be critical. BTW, I'm an ol' Missouri boy, myself. Been in living in the desert for the past 40 years though. Missing the Ozarks... nick
  3. I could be wrong, and frequently am, but I think you are going in the wrong direction with this project. Instead of paint and Resolene, you should be using dye with a flexible top coat, such as neutral shoe polish or Snow Seal. However, you will also have to totally change your design concepts. You will not be able to use colors which are lighter than the leather that you are using and you will not be able to make small design elements shown in your example because dyes bleed. Hey, I just had an idea! Try using some felt-tip pens for your design elements. I have never used them, but I think that they should work. I just tried a black Sharpie on a scrap of leather and it went on very cleanly with a crisp edge, no bleeding. Make sure that they are "permanent" markers. nick
  4. YinTX, I consider that bend a stroke of luck. I would like to have this on all of my belts. It makes for a more natural fit, right out of the box. Old belts eventually assume this shape but not as elegantly, because they have to scrunch up on the top edge and stretch on the lower one, in order to accomplish this. Years ago, I paid extra to have a custom belt cut on a curve, made for me... back before I go into leather work. It was made by Erik Little of Rafter L, leather, Buffalo Wyoming. He is, or was, a member on this forum, I believe. He also introduced me to the idea of seven holes, spaced 3/4" apart, rather than the traditional 5 holes, spaced at 1". It was a great belt, but I make my own now! nick
  5. Nice project. It looks great! So, how did you fix this? USMC Black gives a very deep black but it leaves a great deal of particulate on top of the leather. It must be buffed off before further treatment and it takes a great deal of work, feeling like it will never end. Fiebing's Pro Oil should also be buffed after applying, but there will be very little rub-off. Also, you may notice that USMC Black and all of the non-oil dyes really tend to dry out your leather and make it very stiff. Sometimes this can be an advantage, as in a holster that needs to maintain it's shape. Still, I cannot put up with the rub-off with those dyes... drives me nuts. BTW, the general rule of thumb on applying any kind of liquid top-coat is to go with very thin applications. You can do multiple applications but make sure they are thin, every time. You could use neutral shoe polish and not have to worry about it. nick
  6. That is ingenious!
  7. Well, I'm curious... did the vinegaroon work or not? Did it blacken the leather at all? nick
  8. I think that you would be wasting your money on another set of chisels. There is nothing to be gained by it. They all have the same problem with sticking in the leather. Just suffer with the ones that you already own. We all do! Polishing seems to help a little but not as much as you would hope. Same with bee's wax. I am usually going through two layers of leather that add up to 8mm thickness, and that is right to the top of the tines of the chisel. I put wax on the tips of the tines, tap the chisel in about half-way, take it out, wax it again and then go all the way through. Using a wood block helps but even with that, if I didn't wiggle the tool to get it out, I would never get it out. The only way to make it easier is to use chisels with fewer tines. I would not even think about using a chisel with more than four tines. But that is from an old man who doesn't have much grip strength any more, YMMV. nick
  9. LOVE IT! Gorgeous! Man, I really envy your skills.
  10. All Hand Stitched... amazing... Auto CAD... even more amazing! Love your brand "Barely Civilized". Very nice.
  11. BTW, a good resource for some of the things that we use, like belt loops, various hardware, gun molds, vacuum presses, mechanical presses and foams, can be sourced from www.knifekits.com nick
  12. Which finish or top coat to use is a long standing debate. The ingredients seem to be a secret and none of them have the degree of water proofing that we really would like to have. I use Satin Shene. It is not as glossy as Resolene but you will have to do your own experiments to determine what is best for you. Looking at that dauber in the top pic makes me think that you put the Tan Kote on too thick. Thin coats work best with these products. Air brushing seems to be the best method but I have never used it. If you cannot use an air brush, probably the next best thing is a lint-free cotton cloth, like an old t-shirt. I just wrap one layer of cloth around my fingers, trying to avoid over-loading the liquid. Apply a thin coat of the product and wait for it to dry before adding another (if needed). Buff. Some people just use neutral shoe polish. I have never tried it, thinking that it would not be a lasting finish. BTW, the leather around the belt loops is looking rather thin. I think I would want at least 1/4" or preferably, 3/8" around that area. This is going to be carrying the weight of the gun and is therefore important to the integrity of the holster. That is the wear point of the holster. It must hold up to the tension of the belt. This looks like it was made for a Taurus Judge, which is a big, heavy gun. Keep in mind the size of the weapon when making design decisions. It will dictate how thick the leather should be, and whether you might double-stitch it, etc. You still need to bring your stitching in closer to the gun. Look at other maker's work to get a feel for what you should be doing. nick
  13. Well, that is really darn good for a first holster. Far better than mine was! That was very clever to make it so that it can be worn as a belt slide or IWB. As Tony suggested, you need to have the stitching right up against the gun. It's not too late to ADD that. Also, there needs to be more room for a full firing grip while the gun is in the holster. That's not as easy to fix now. Next time, leave a little more room. Your art work is nice. nick
  14. Thanks for sharing those. Nice!
  15. This is one of those things that has always bugged me. Why in the World doesn't any manufacturer make a punch that is more appropriate for belt slots? Cutting belt slots by hand is a real pain and, for me, it often ruins the look of the holster. A die is essential for a decent look. I searched all of the familiar tool makers and none of them had one. The dies were too long, too short, too narrow or too wide. I finally gave in and ordered a custom made die in 1 5/8" by 1/4". For me, it is perfect. Ordered it from Texas Custom Dies. I don't remember how long it took to get it but it was relatively quick... within two weeks, I think, maybe sooner. nick
  16. Sorry Kirby, my mistake. I am a "beginner" myself. I thought that you were using veg tan for that project. I have only used veg tan, so you may be right! I should keep my big mouth shut!
  17. Hey... keep going Kirby! Your stitches look pretty good on the checkbook cover. IMO, the corners are too square. Also, you may want to learn how to sand and burnish the edges. Burnishing the edges would definitely take this project up a notch. On your next project, consider burnishing the flesh side before assembling the pieces. It could be done on this project but not as easily. On this project, just round off the corners, sand and burnish the edges. Well, that's what I would do anyway. To round the corners, start by cutting off just the tip... one cut at a 45° angle. Don't take off too much, just a little, then round them with sandpaper, 120 grit or finer. nick
  18. dougfergy... that is a very nice color and a beautifully made holster. I aspire to your skill level... may never get there!
  19. I did not buy this from Herman Oak but ordered from another supplier. It was listed as using a "special" leather from Herman Oak. I just thought that they were saying that Herman Oak is "special" leather. They did not mention any kind of texture. I don't want to pay return shipping for a $17 item, so I will just use it. Not happily though. I will be more careful in the future. I had no idea that HO would add a texture. Seems crazy to me. I was wondering if it was corrected grain. It's ugly. nick
  20. I use Fiebing's Pro dye. I always give my projects at least two and maybe three applications. I want to load it with color, until it will not take any more. I just give it a minute or two between coats. When it starts "standing" on the leather, I know it is done. Of course, this results in the darkest rendition of whatever color is used, but it IS even. If it is not even, then perhaps the leather had some oils or waxes on it which prevented absorption.
  21. I have only tried Angeles one time. It was their Navy Blue. It required LOTS of buffing. I decided, right then, that I would be sticking with Fiebing's Pro Oil from then on. But that's just one person's experience. nick
  22. I didn't want to buy a side of leather to make one belt for a relative, so, I bought belt blank. I have never used a belt blank before, always cut them myself. So, I ordered a Herman Oak belt blank. The drum dyed one. I was quite surprised when I saw it in person. I was expecting a smooth finish but was rather, well... I don't know... grainy? textured? too perfect? It is difficult to describe, so I included some pics. I have never bought any leather that looked like this. What is going on? nick
  23. Could not get pic of my 5 year old holster to upload on my last post. Here it is. Like I said, almost daily wear for 5 years. This was done with Gum Tragacanth and probably a coat of Satin Shene.
  24. I have had great luck with bare wooden slickers. I have a holster that is at least 5 years old, used almost daily and the edges are still shiny. But, I agree with your wife. In fact my mind has really changed on this lately. I know that many people like shiny belts and holsters but when I used to wear boots, I preferred rough-out or nu-buck. It's just a personal thing. I have been going for a semi-gloss or matte finish on my holsters, lately. So, I am doing the same with the edges. A plastic slicker will do that... a smooth, barely glossy finish. I have never used or even experimented with any kind of cloth.
