Constabulary
  1. The tension unit remained the same so it is the same on all 29 / 29K machines at least on the most common ones that I have seen. More pictures you´ll find in the thread I have linked in the 3rd post above. I no longer have this 29K1.
  2. I´m not 100% sure but could be that Singer 45K bobbins fit - I´d compare the measures. https://www.ebay.de/itm/143603147753
  3. well, the tension unit looks odd too.... I cannot tell what the silver parts are but they do not belong there.
  4. a few things I noticed... The thumbscrew + lock nut for the foot pressure leaf spring are missing. You have a plain screw instead which for sure is too short. So you cannot adjust the foot pressure. I think (!) you have a wrong foot lift lever on your machine. I think (!) your machine should have the "push down lever" - not sure if you know what I mean but some of the early 29K had a different lever for lifting the foot that you have to push down instead of lifting to lift the presser foot Some one cut a slit in the slider or modified the slider somehow. There should be just 1 slit for the leaf spring and that the is the lower one. The slider also looks modified. the lower end should be squared and not rounded. Usually here should be a spring that hold the "push down lever" in place IMO I think some one tried to fix the machine and made is worse. Please post pictures of the front side. Not sure if you can get it to work with the wrong & modified parts but 1st thing I would try is to place the leaf spring the in lower slit of the slider. BUT I think then the leaf spring will not hold in place because you do not have the correct thumbscrew + lock nut installed. So wrong / missing and modified parts are the main reason why the machine is not properly working. Long time ago I restored a 29K1. You find some pictures that show how the correct parts are positioned in this thread: Hope this helps
  5. Please post pictures of your machine then we know if it the 1st or 2nd type 51w
  6. looks like a clone of the Singer 45K21, drop feed with roller foot.
  7. I´d choose the BROTHER - clone of a Singer 153w (but with reverse) or the later Seiko CW-8 and / or Consew 227R. Its a Singer based machine and parts will be available probably for ever and the accessories like presser feet sets are cheap.
  8. Is it a synchronized binder machine? If yes you may need a fixed (not moving) arm plate. Most likely you will have to modify the hemming attachment and maybe plate to make it work. Please post pictures.
  9. If it was me I would use heavy Denim or Canvas with some leather application (for pockets and straps).
  10. if it has to be a left stand machine look for Pfaff 24 or 27, Adler 49 . alternatively Singer 17, Pfaff 28, Adler 48 (all right stand)
  11. I only see one picture and that looks good to me except that you have not insert a needle . Sewing machines sew better with needles **kidding**. Have you checked the manual? Thats usually the 1st thing I would do.
  12. I have seen Frobanas in slightly different color shades. Maybe that is because of their age or if they were exposed to different "environments". The latest I have seen where hammer tone silver.
  13. are both of them piping feet and are they for the same piping thickness? I think feet for thicker pipings are probably shorter but it´s a guess.
  14. If your motor is an old clutch motor you will not have much fun with it (often too fast and noisy). Better replace it with a modern servo motor and maybe add a speed reducer. Or check this thread maybe this motor is a good option for you
  15. Unfortunately Pfaff has no "counterpart" and you have to use their gauge parts. When you want to change the needle distance you need a complete gauge set that includes presser foot, fed dog, needle plate and needle holder. Pfaff gauge sets are hard to find and even when you find them they will be quite expensive. When it comes to double needle machines I´d recommend a machine that is based on a Singer machines, like Juki, Seiko, Consew and so forth. Singer based gauge parts are available everywhere and they are cheap. Check the list of manufacturers in the description here: https://www.ebay.de/itm/142635430976
  16. I would check for SUTTON or McKay stitchers, IIRC Pederson models are sometimes very similar if not identical. Just what I have observed from the shoe making guys. Maybe even BUSM / British United Shoe Machinery, MOENUS, ALBEKO or PROTOS.
  17. Is it just test sewing what we see or is it a piece of a product you are sewing? Why should a post bed machine with a single row feed dog and a roller foot sew a fairly large piece of material straight when not guiding the material with your hands? What product do you want to produce? Maybe wrong machine for the job? You do not give us many information...
  18. G is made in Germany W is made in USA otherwise the same machine (depending on sub class) and interchangeable parts.
  19. when I have learned something in "my sewing machine years" then it is never take it apart fully when it is not absolutely necessary even when you think you know a lot about sewing machines. Obsolete parts can break in worst case. Even on "simple" machines like patchers things can go wrong when you strip it fully and you are f...ed when you but back the cams the wrong way.... You name it. Just don't do it for just for learning or cleaning. I know this does not help - just my statement. Hard to tell what you did wrong w/o having followed the process. Maybe a short video would help.
  20. I´d rather check with the manufacturer
  21. it probably depends on the subclass of the 1245 machine whether it has an oil reservoir or not. I can Speak for the Singer 211 series and they came with different size hooks and some of the hooks had oil bath others don´t depending on what subclass the machine has.
  22. Have you googled the number? First find was in AU https://marfar.com.au/pa/collections/parts/products/spring-412201 I know AU - Denmark but still an option. Alternatively I would check parts lists of similar machines like Seiko LSW, Brother LS2 or similar, also look for similar Consew models. Just a guess, I don´t know if they are all the same underneath the flat bed. If you find nothing, check with some of the known Chinese sewing machine parts dealer on Ebay and ask if they can get you the spring. I did that before and they came up with what I needed. That probably is the cheapest option. Just some suggestions.
  23. BTW - seems your machine has no oil drip pan.
  24. tilt the machine back its just below the flat bed right in front of you.
  25. Please post more pictures of your machine. Its hard to imagine what you mean. Pictures tell more than 1000 words.
