ha ha ha - yes, Indeed a German Singer man but that just happened - I never really had the intension of only owning / buying Singers. I have tried many machines (lots of trial and error). I just kept what suited best for my needs and one reason for keeping a machine always was (and still is) the availability of spare parts w/o calling dealer all over the the world. And thats a big advantage for the Singers or their clones. For all machines I own a good number of spare parts are available for reasonable prices. And so far all after market parts I have bought are of good quality (with two exceptions - a 133K tension release disc and a 29K shuttle carrier spring). The only exception is the 307G2 but I figured a lot of parts from other Singer machines fit. (hook, feed dog, throat plate....) But everybody has his preferences and meanwhile I really like the the "idea" of old Singers. But I honestly don`t care of who copied from who. I just don´t think the 45K is an Adler 4 / 5 clone. I`m also convinced that the Adler 4 is the better built machine. Some of the last Singer industrial machines are indeed made by Adler or copied from their machines like 45A, 169, 220 and I think some other Adler machines with Singer labels. Belief it or not - a couple of weeks ago I have seen a Claes / Textima patcher (one of the latest models) and it had a Singer decal on the upper arm. Nothing is impossible in this business....
It obviously needs some TLC but when the machine is functional I´d say for $200 I think is not too bad. But maybe you can beat down the price a little bit. You probably have to invest in a new servo motor and maybe a speed reducer. The machine has no reverse. I would guess it can sew 7-9mm thick (I have a 111G156 and it sews 9mm w/o problems). The max. stitch length usually is 5 SPI on these older 111 machines. I can sew up to 207 thread with mine but usually they are set up for 138 with a size 22 needle. Check the condition of the timing belt. Replacing it causes a lot of work but it is doable. Always test a machine before you buy it!!!
Glen, I have found another patcher brand GOERICKE, Bielefeled (once again a CO. from Bielefeld) also sold a Duerkopp type patcher The writing says "GOERICKES ORIGINAL SCHUHMACHER MASCHINE" GOERICKE was known for bicycles and motorcycles (at least in Germany)
I personally would not buy this machine form Ebay not only because it is dead ugly! Gump already hit the nail on the head. Check with Toledo Sewing Machine Co. There you get approx. the same machine (but with 1/2" foot lift) for $30 more including a 3:1 Speed reducer a much larger machine pulley / balance wheel (as it seems) and with great support and warranty. And I would assume it is even better built but I don´t know for sure. Add $300 and you have a reverse Add another $300 and you have a 441 type machine with walking foot mechanism with all advantages. Check out Toledos CB3200 I think in the long view this is a much better investment than this ebay thing. http://www.tolindsewmach.com/cb3200.html
I don't agree with this theory (Class 4 + 5 >> 45K). As far as I know Singer already produced 45K´s when Adler was still producing the Class 3 which is the predecessor of the Class 4. 45K flat bed and Adler Class4 are a bit different - the 45K´s are shorter than the Adler Class 4. Therefore I´d say the Class 4 is rather an improvement of the 45K. I don't think Singer would produce shorter machines when they copy something. But thats just my theory w/o proof.
Messenger Bag
Constabulary replied to opus56's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
many thanks to tboyce (for all your pattern work) & opus56 (very nice and simple design - very cool!!!) -
or buy a new one: http://www.ebay.com/itm/SINGER-111W-HOOK-DRIVING-SHAFT-LOCK-STUD-PART-240244-/120926491847?pt=LH_DefaultDomain_0&hash=item1c27c7d4c7 As far as I know Consew is using the same parts as singer so this one should be the one or this one http://www.ebay.com/itm/SINGER-111W-FEED-REGULATING-STUD-PART-240235-/120926491836?pt=LH_DefaultDomain_0&hash=item1c27c7d4bc
Sewing Through Thick Spots With Juki 1541S
Constabulary replied to flipperjoint's topic in Leather Sewing Machines
maybe the foot lifts not high enough - can you adjust the foot litf hight on your machine? -
you are welcome. Of course youtube.... I wasn´t thinking. So your machine is running now?
- 19 replies
Material Guide For Juki Lu-563?
Constabulary replied to MadMorbius's topic in Leather Sewing Machines
I have added one to my Singer 111 a couple of weeks ago - they are great! Mine has two changeable guides - one roller and one straight. -
Messenger Bag
Realy A Cool Bag - guess your daugther is pround of it! Will you share the measures or pattern? -
Me too - its a hobby for me and I absolutely understand your point - It´s not that I haven´t had this idea but I honesty don`t dare to order from China! I´m not a mechanical embryo but setting up this type of machine from zero isn`t something I would dare! I´m sure I have seen a video where Steve was explaining several adjustments on the Cobra 4 but don´t know where it was. I remember he explained something like how to line up screws with markings or so (view from the backside) but I honestly don´t know where I have seen the video.
- 19 replies
Yah - the different needle systems suck - I fortunately can use 135x17 / 135x16 on all my machines except the 133K. The 135x17 (for fabric) or 135x16 (for leather) are slightly longer that the 135-34 so you probably have to rise your needle bar a tiny bit if the machine is setup for 135-34. Well it is possible that your 267 is setup for 180 needles but I think they are factory set to 140/22. When you are using thicker needles you may need a feed dog with wider hole (because of thicker needle + thicker thread) and maybe have to move the hook saddle a tiny bit to the right to give the thicker thread more space to slip through the gap between the small tongue of the bobbin basket and needle plate. You know what I mean? Maybe the former owner has set it up for 180 needles already - I dunno. I´d also check the setting of your bobbin case opener. It ensures that the thread can slip through w/o problems. EDIT: TROX used Tkt 15 thread - that is about 207 in the US and this thread needs a 160/23 needle. You are using a 180/24 needle so I´d say it is too thick for your machine. Try your 130/21 needle with a 138 or 92 thread - maybe that works better.
Direct from China? Seems you have learned the lesson the hard way (no offence). I think Leather Machine Co. has a Video on Youtube on how to adjust the Cobra machines. Maybe this will help you.
- 19 replies
Are you probably using the wrong needle type? Adler 267 needs 134-35 (DPx35) needles afaik. A size 180/24 needles is too thick I´d say. I think 140/22 is the max. recommended by Adler. I have not worked on a 267 yet. The 1.6mm above the needle eye is where the hook meets the needle scarf on 111 and 227 (Singer 153) type machines with a 135x17 (DPx35) needle in general. This describes the point where the hook catches the loop approx. at its widest point. The rise after BDC at 111 and 227 machines is usually is 2.5mm. I don´t know how much internal technical difference is between the 111 and the the 267. But seems your manual says 1.8mm - 2.00mm after BDC so I would assume the needle is the problem.
Help I Think I Stripped A Gear Or Something?
Constabulary replied to Carrieanna1172's topic in Leather Sewing Machines
Check if one of the set screws is loose and rubbing on a gear. Turn the fly wheel by hand and watch the gears. If not I would say Pcox is rigth -
Advice On Heavy Duty Sewing Machine In Europe
Constabulary replied to bikemaniac's topic in Leather Sewing Machines
Yeah the current exchange rate really sucks! (Sorry Steve) Ckeck with Sieck: www.sieck.de They are located in Bayreuth - maybe not too far away from you. -
25,4mm = 1" 25.4mm : 3.38mm = 7.5 I´m not good at math but it should be 7.5 SPI - or not?
I don´t have a 441 but I think the wedge on the lever should be aligned with the the "0" marking for zero feeding? And from there on back and forth stitchings should have the same length. If they don´t I would assume something is wrong with the machine - or not?
- 19 replies
The current €/$ exchange rate is quite bad for imorting goods from the US - unfortunately! Keep in mind that you have to add import taxes and VAT (21% in Austria as far as I know) to the total amount including the shipping costs!!! Sewing machine + shipping = invoiced amount + imoprt tax (3.7% afaik) + VAT = total amount http://ec.europa.eu/taxation_customs/dds2/taric/measures.jsp?Lang=de&SimDate=20150307&Area=US&Taric=84522900&LangDescr=de -
Do you have a website? The one you linked in your profile does not work.
- 5 replies
- setting snaps
- custom logo snaps
(and 1 more)
Buying First Sewing Machine...need Help!
Constabulary replied to signaturetack's topic in Sewing Leather
I don´t think you will be happy with this machine. It is not "that certain type" of walking foot leather workers are talking about usually. The Juki DU-1181 has top and bottom feed but no needle feed. When Leather workers are talking about a walking foot machine then triple feed, compound feed or unison feed is meant. That means the material is feed by feed dog (bottom feed), the needle (needle feed) and a presser foot (top feed) synchronized all at the same time. Toledo Sewing Machines explains this system on their website: http://www.tolindsewmach.com/walking-foot.html My opinion is that you don`t have to spend $1000. You CAN find good used machines for way less on craigslist or so. Often enough older machines are not too badly worn but you of course can`t be sure. There are many examples in the forum where member have bought good used machines for fair money. But here are of course members who had less luck with their machine but as far as I remember the majority have not failed with their used machines. Most of the time the needle hook timing is off and that often enough is an easy fix. I´m one who never has bought a new machine. I bough all machines used and have restored them (more or less) and they all work very well and I´m not a sewing machine mechanic! My oldest machine is from 1932 and sews absolutely perfect! But it is true that you have to invest $250 -$300 for a new servo motor and a speed reducer and maybe some extra $ for some parts. But I´m convinced that you can save money when you buy a used machine but be aware that it often enough means that you have to rework them a little bit before they work properly. You will get a a lot of support in the LW forum when you have problems with your machine (no matter if bough new or used). Anyway - if you don´t feel comfortable with the idea of reworking a used machines by your self you should buy a machine from one of the dealers who have their banners on top of this website. They all have a good reputation and I think they all have new and used machines to choose from. They will guide you when you tell them what you are planing to do. -
Many LW member also have DIY speed reducers made from a shaft 2 pulleys, pedestal bearings or something likely. Depends on your access to proper parts, tools and skills. I´m sure you´ll find some nice ideas when you search the forum for speed reducer. Just an idea...
I personally think a smaller motor pulley (2" or smaller) and the addition of a speed reducer is the best way to slow down sewing speed. You also have more torque when you add a speed reducer.
Leather Sewing Machine Suppliers Uk
Constabulary replied to rjqhall's topic in Leather Sewing Machines
http://www.anglosewing.co.uk/index.html http://www.dcrmachines.co.uk/index.html http://www.ebay.co.uk/itm/Juki-441-Cylinder-Arm-Walking-Foot-Extra-Heavy-Duty-Industrial-Sewing-Machine-/171595954070?pt=LH_DefaultDomain_3&hash=item27f3ea7796
