Beast? Heavy? You will be surprised what "real" industrial sewing machines weight when setup with motor and so forth. The 127 is rather a dwarf compared with "real" industrial leather sewing machines.
Need Help With Cobra Class 4 ... Stiching Issue
Constabulary replied to RoosterShooter's topic in Leather Sewing Machines
I don´t have a cobra but sometimes needle bars start rising a little bit. If it was me I´d check the NB height and maybe would try to lower the NB a little bit - maybe 0.5 -1mm. Just to start with... -
maybe... not a machine I would use but if it works for you - why not.
Cool find! Never seen before. Dedicated binder machine and w/o reverse I guess.
Domestic Singers sewing machines are not what I`m interested in so honestly I do not know. So wild guess - a Singer 216 maybe?
a walking foot / triple feed cylinder arm sewing machine maybe with addition of a flat bed attachment. Like Pfaff 335, Adler 69., Pfaff 345, Adler 169 or similar.... depends on what available on your local market.
What is the Consew 206 of straight stitch machines?
Constabulary replied to ensitmike's topic in Leather Sewing Machines
my opinion - basically all drop feed straight stitchers are quite the same. They may differ a bit technically (rotary hook, or CB hook... different type of thread take up lever...) but there is none really bad I would say (speaking of industrial machines not domestic / home sewing machines). I would look for one with reverse function (older machines sometime lack the reverse function). And if it was me I would look one with for a wider feed dog like Singer 20U or its clones, Pfaff 138, Bernina 217, Adler 1217, Singer 457 (industrial not domestic), Singer 307G2. BTW - all mentioned machines have zig zag too - could be useful too but depends on your needs. The Singer 457 is a machine with excellent parts situation - you get a lot of different parts and accessories for this model. BTW - I have a 307G2 and I´m very pleased with it. -
Pfaff 335, Adler 69, Seiko LSC-8BV and to my knowledge all cylinder arm machines with horizontal hook (bobbin loading from the side) have a plain back and forth going feed dog which is not oscillating. They are all in the same class. They all can be set up as "plain sewer" or binding machine. Some come as plain sewer some come set up as binding machines. The differences are the arm cover plate, different needle plate / throat plate and a different feed dog + different presser foot set - thats basically the main difference. If the machine is set up as a "plain sewer" (not binding) its even better because the parts you need for setting them up as a binder machine are often cheaper and easier to find then the parts for setting it up as a plain sewer (f.i. for Pfaff 335 and Seiko LSC-8BV) Sounds stupid? But thats how it is. Feed dog can have different size needle holes. So when you are checking out the machines check the foot lift height. Especially the Adler could be of a subclass with lower foot lift. And check if they can handle the max. needle size and thread size you want to use - usually its 138 or metric #20 thread.
Question is what kind of leather work do you want to do? The 45K1 is a heavy drop feed sewing machine w/o reverse, it can sew approx 10-12mm leather. Its has an aggressive feed dog and the feed dog will leave marks on the underside. But hey - generations of leather workers have used this type of machine... So it depends on the product if these marks matter or not. I have a drop feed 45K too (cylinder arm 45D91 to be precise) and the feed dog marks do not bother me. But I mainly do rather "rough" leather work like leather handles for crates and the like or I repair vintage holster, military police equipment and stuff like that. Often you do not see the underside or it just does not matter cause the original leather item, (like military holsters) already has feed dog marks. So it depends...
Question is what means "the best around" and who is a specialist? People who own a Adler will tell you Adler it best, Pfaff owners tell you Pfaff is best. Seiko owners will tell you the same because most machine owner do not have a 1:1 comparison with other brands. You can be sure both machines will do their job as long as they are set up properly. A proper set up Seiko is better than a poorly set up or worn out Adler an the other way around. So its not only the brand or the workmanship you also have to consider the grade of wear and if the machines have constantly been serviced. I have owned beautiful 1950´s Adler 69 and I can tell you it was not possible to get the forward and reverse stitch length equal - I know there should be and eccentric behind the lock lever for this adjustment but there wasn´t one. Why? Because (I think) it was a dedicated binder machine for some sort of special binding operation. Don´t ask what operation in particular, I was not able to find out even Dürkopp Adler did not know the subclass anymore. So I was not happy at all with this machine. But that does not make the Adler 69 a bad machine in general - it was just the wrong machine for the job. So - we all do not know how your machines look like and how they are set up so my statements is rather "general". Adler parts and accessories are very expensive sometimes. And the Seiko´s are mainly based on Singer machines and they share a lot of parts and accessories. That makes the parts a lot cheaper. Other brands like Juki, Consew, Mitsubishi and many of the nowadays Chinese made machines are using Singer parts as well. So parts are rather cheap and easy to get. And that makes the Seiko the more economical machine in the long view. So basically there is no answer to which machine brand is good or bad - question is are the machines set up for the job and how is their condition. So the Adler will not disappoint you if properly set up / set up for your job and I can make the same statement for the Seiko. Best advice is to test both machines and then decide which one works better for you / the job. Sometimes it´s just a feeling that makes the difference.
Yes, greater ratio between motor pulley and the larger hand wheel pulley slows down the sewing speed.
agree with what Cobra Steve said in the linked thread - SEIKO parts are cheaper and the LSC-8BV is using Singer 111 presser feet which are very easy to get and fairly cheap often. Many other parts are Singer type too like the tension unit and so forth. So If I had to chose I´d take the Seiko.
some of the Chinese made Singer 29K closes have a grove in the hand wheel. check pictures here https://www.sewtex.de/Ledernaehmaschine--Sattlernaehmaschine--Schuhe--Schumacher-Naehmaschine--Schaerfmaschine--Pelz--Leder-Naehmaschine/Long-Arm-Patcher---Shoe-Repair-Machine-2973--Adler-30-7--Schuhmacher-Reparatur-Naehmaschine--Saeulenmaschine---Leder---Schumacher---Schuhenaehmaschine.html just to give you an idea - not sure if that helps...
Gritzner Frobana Outsole Machine
Constabulary replied to alexitbe's topic in Leather Sewing Machines
technically it seems to be the same thumbscrew but your machine is probably the earlier model I think. But the manual seems to be right for your model. Manual is on the way. -
There should be a thumb screw under the front lid with this thumb screw you can raise and lower the head (the thing that looks like a fulcrum beak) It is like the presser foot on regular machines it puts pressure on the materials and w/o a certain amount of "foot pressure" this machine will not sew properly. If you have problems adjusting the head height turn the small checkered wheel (looks like you have a wheel instead of a lever) a bit to the left while turning the thumb screw. Do you have a manual for your machine - if not send me your email address by PM Can you post a few full view pictures of your machine? -
It is an M6 x 1.0 screw, 33m long shaft with 4.5mm x 15mm end w/o threading - see picture I have no spare - sorry! -
Laser cleaning rust off machines
Constabulary replied to chrisash's topic in Leather Sewing Machines
How about dry Ice blasting? Always wanted to test it. We have a dry ice blaster Co locally but never really checked with them. So far my "simple" restoration techniques worked well for me. Laser rust removal for sure is interesting but nothing for DIY people like me I think. Agree with Don - quite dangerous if something goes wrong. -
cant find the mounting screw 50632 in the parts list. Is it for mounting the head to the casting or the casting to the treadle base? Do you still have the drawer? I`m not sure but I think Singer used different drawers & brackets. Could be that I have a drawer bracket and screws.
we all learn something new everyday
It for sure depends on how your product is finished but maybe a soapy water solution? Maybe use medical soap or curd soap? https://www.nationalgeographic.com/science/2020/03/why-soap-preferable-bleach-fight-against-coronavirus/ or ask trxmp seems he is the most advance virus expert of our time
and keep in mind - there is not only the classic LR tip needle for leather there are a lot more. I prefer S-Tip needles To give you some ideas check the below links. 2nd link is a download link from GROZ BECKERT https://www.schmetz.com/en/industrial-needles/needle-compass/cutting-points https://www.groz-beckert.com/mm/media/en/web/pdf/Point_styles_for_leather_processing.pdf
Thats the point! Different material density, different material thickness, different needle size, different needle tips (probably), different thread size, different thread material like nylon, polyester, Linen - in variation of bonded, waxes, oiled, or untreated... looots of variables. I usually set the bottom tension very low the way thread has a little bit resistance (but I still have to feel it) when I pull out the thread. The rest is top tension. And only when I need a tighter stitch I readjust the bottom and of course top tension accordingly. However different machines many need different tensions too. I have more tension (top and bottom) on my Singer 45D91 than on my Singer 111G156 even when I run the same thread. Its probably a different story when you set up a factory line with 20 similar machines and they all do the same work day in and day out...
- 24 replies
- thread tension gauge.
- thread tensioner
(and 3 more)
Pfaff 335 came with different size hooks, the new type is using larger bobbins. I think both have approx 22mm diameter but the new bobbins are a bit higher by afaik 3-4mm or so. So I think neither L nor M - rather G I´d say but not 100% sure of the exact type
I never understood why I should use / need such a device - I never had serious issues with adjusting the tension. Silverd - can you explain why you think you need one?
- 24 replies
- thread tensioner
(and 3 more)
Well the textured paint (VHT wrinkle) just looks cool I think and yes it covers pits and chips very well just like the silver hammer tone paint. The silver hammer tone silver always looks "fresh" I´d say. I really like both! On the 108w20 I only have touched up some on the larger paint chips the rest is still the original paint. I have not primed the machines I just clean them with pain thinner and sand them with 240 grid before painting. I do not buff the parts (I do not have a buffing wheel). What looks like rust often is just dried oil and dust. Often a hot washing soda solution can wash down this gunk. The really hard necking stuff on certain parts I remove with a round wire brush for electric drills. I`m also using electrolysis for removing paint and dirt sometimes.
