Constabulary
  1. You did not say what needle size, needle tip and thread size you are using. Just from looking at the pictures and since almost all knots are flat on the bottom side I would suggest you try a needle 1 size larger or the bottom thread 1 size smaller. Or maybe reduce the bottom tension. Maybe you need a heavier beehive spring in your tension unit.
  2. I had to google what an MBT thread #5 is - seems it is about 138 thread https://districtleathersupply.com/products/vinymo-mbt-size-5-0-6mm-polyester-thread-full-spool So for 138 thread you should use a needle size #22 or maybe #23 if the thread is thicker than 138 (see link)
  3. The tone seems to be ROSEMARY, right? I cannot find it on my side of the pond - maybe DanishMan has more luck.
  4. I haven´t seen any paint that is close to the brownish original Pfaff hammertone - at east on "our side" of the pond. If you want to use Hammerite (as a brand) I would probably choose gold. But you never know how good (how golden) it turns out at the end. So my preference is silver hammertone, that always looks good.
  5. Where do you live? Helgoland, Uzbekistan, USA, Kamchatka, Australia, Falklands, Nowaja Semlja, Europe? Its easier to support you when you add your location to your profile. The Forum is very international.
  6. I know that Adler 30 patcher are sometimes equipped with smaller 90Watt right angle gear motors and they er controlled by foot pedals as you find them on domestic machines. But they cost a lot more than a simple servo motor but they really work well but they have no brake. If you want to use a servo motor remove the accelerator unit from the bracket put a plain foot pedal on a wooden board and make a bracket for the accelerator unit and mount it onto the wooden board... ya know what I mean?
  7. its a "quick change" slide plate for all kind of sewing devices / sewing guides. You find them more often on double needle machines than on single needle machine. You have no manual - look for a Singer 112w139 manual - should be a quite similar machine. Or maybe JUKI LUH-521.
  8. As I said, I know JB weld very well and I´m using it A LOT (just as you do) - but keep in mind that you are threading the needle bar with a metal wire and the edges of the threading wire will wear off the epoxy sooner or later because it is "rubbing" exactly where the thread is running. So the groves in spring and needle bar are the result of the thread but also a result of the rubbing threading wire. I don´t think this tiny amount of epoxy will last for a long time. Just my 2 cents.
  9. I know JB weld very well but I would not use epoxy on such a small "blemish". Not sure if it really would "stick" in place for a long time or how fast it will wear off again. How deep is it 0.2 mm? File it down - done. Really not a big deal.
  10. I´m using heavy cast iron pedals too. My accelerator lever (JACK SERVO) has 2 notches for the spring, I simply set it to the grove further away from the pivot point - problem solved. If there is no 2nd grove just make one.
  11. I do not know the output numbers. I´m "a bit" Singer crazy but I´m not really a historian. I know some facts but not really all details. I hope I can do the guided tour again one day. The tour guide said there are still old tunnels they have used for moving parts / machines between the different sections of the plant and they want to make them public one day - if possible (and safe). I have used an external picture host (https://postimages.org) and have linked the pictures here. That was the fastest and easiest way to post a large number of pictures and that way I could put them all in 1 post. BTW - found this picture on Wikipedia - seems it is pre 1928 because I cannot see the clock tower. Pic give a good impression of the size of the plant: https://de.wikipedia.org/wiki/Nähmaschinenwerk_Wittenberge#/media/Datei:Wittenberge_Singer-Nähmaschinenfabrik.jpg
  12. It does but I think a skilled seamstress is faster. And you still need someone in front of the machine (whom you have to pay) who "feeds" the machine. Maybe you have less output rejects with this machine - maybe not... However - still a very impressive machine.
  13. How about bookbinding board / grey board / pulp board / cardboard. You know what I mean? The material beer coasters are made of. I think its available in different densities but I´m not sure. If you have old books use the book covers. Thats a lot more environmentally friendly than foam sheets - I mean if you trash it anyway... just a random source: http://www.bmpaper.com/sale-10023646-chemical-pulp-raw-material-grey-board-sheets-1-5mm-cardboard-wrapping-paper.html
  14. Patchers - they can be a lot of fun but even more a pain - sometimes. Ouuuuh yes, this little annoying thingy can be a pain and is the last thing you would think of. Not sure if it is mentioned in the manual but you can also move the needle holder a bit sideways (by loosening the upper screw) when the hook will not grab the thread. As Wiz said - you can also use 135x17 (or 135x16 for leather) they have the same length as the 29 needles but have a scarf above the needle eye. I´m using 135x16 / 135x17 needle only in my 29K71.
  15. Imagine your opportunities.... smart home sewing machines.... ALEXA - sew that fxcking holster! I need it done when I´m back home. and there will be a day when you no longer can get updates (an parts) - hope there will be an XP mode then... ah well, maybe you can hot wire em. Will Ctrl-Alt-Delete work?
  16. I have reworked the PDF and made it a bit more printer friendly and left out blank page and some rather "unimportant" pages but file is still to big to upload. MikeSC - do you want me to send you the file? Seems you can upload larger files.
  17. Pfaff 145 / 545 / 1245 binding bracket work for the 345 as well - guess how I know But you also need the feed dog, throat plate and matching foot set. https://www.ebay.com.au/itm/Binder-Bracket-Walking-Foot-Needle-Plate-Feeder-For-Pfaff-1245-Binding-Sewing-/293054013906
  18. 5K for a bag? NUTS! when the binding stretches and stitches become shorter you most likely have too much friction between binding material and binder meaning binding material is too thick I would say. I had this with some vintage vinyl binding material which I wanted to use in a double fold binder - did not work though martial is very thin. I dropped the project cause it´s not worth investing in a custom binder for s single project. You can try to increase the foot pressure of the outer foot, that may help but I think binding material is too thick for the binder - but hard to tell from the distance.
  19. I´m not sure what your intension is - do you want to sell them to overseas customers - you are talking about 20 machine heads...? Or start a sewing business? If you want to sell them keep in mind that shipping + proper packaging + import tax + custom fees (depending on country) will probably make the these machines rather unattractive for an overseas customer. If you sell the head for $200 the customer may end up at $350 - $400 and that is not really a goo deal considering the shipping risk and the fact that these are old machines in unknown condition.
  20. Don´t know how this buckle in real life looks but maybe an option: https://shop.bucklesinternational.com/catalog/BUCKLES/WEB_STRAP/SPRING_BUCKLE/105;jsessionid=0A6BF0428EC276EE8E98146447631257 Or maybe try Ohio Travel Bag
  21. 2nd what Gunnarsson said. If you run a "sewing business" with lots of output some electronic or computerized feature are probably nice and time (money) saving and machines are often written off after 5 years. If you have a small business or you are a hobbyist keep the things simple. Simple things are living longer most of the time and cause less trouble - often you can fix the simple things by your self and the more complicated the things (sewing machines) are the more you have to "outsource" the service and repairs. KISS - keep it stupid simple!
  22. it came with a instruction sheet and technical drawing looks like it has 8 KN at 5 Bar ex factory - but I´m sure you can run it with more than 5 bar. I don´t think will blow off at 6 or 8 bar. So the idea more or less is a pneumatic clicker and maybe a riveter for larger copper rivets. The arbor press idea from the video is least and interesting idea if you have space issues or are on a budget but having multiple tools makes life easier IMO. You do not need an accu drill when you have an electric drill but life is easier if you have both. Most people just want ONE sewing machine but life is easier if you have several (depends on your work of course). And as a wise men said "It's Better To Have It And Not Need It, Than To Need It And Not Have It!
  23. Vicky Pollard - is it you? No rather Whoppers. Mac´s are too dry IMO, you know?
  24. Aaaall right... so my mouse is black and so it the keyboard
  25. Old manuals are often more precise reg. oiling - maybe this 153w manual (that's what your 227 is based on) should gives you an idea. Singer 153w 1 54w101.pdf
