glamb
Contributing Member
Everything posted by glamb
  1. Which handle do you use that pinking blade in? Really nice chinks!
  2. Search real hard on here as someone had a press he was trying to sell. I believe he was on the east coast. He was moving and not wanting to take the press with him. It was all setup to use as a clicker.
  3. glamb
    Biothane
    That picture above is a bit used to lace rubber belting. Look for them from someone that sales conveyer belts. You should be able to get them 1/4" - 3/8"
  4. Thanks for sharing.
  5. On wood they cover the board with diluted Elmers glue and then paint . I've never tried it though??
  6. 1- make sure your air pressure is not too high 12-16 psi 2- are you letting your leather dry after your last application? I would bet you drying it out before hitting the leather with too high of air pressure.
  7. Buy plastic bottles on amazon with brush adjustable in lids $7.00
  8. I use a new 5 gallon bucket with some gamma lid ( that's a screw on lid.) I leave it loose. Gets low add another gallon of vinegar and steel wool. Keep it under my bench which is living temp of the house. When do you guys rinse and neutralize the conversion dip?
  9. Found domed rivets in Tandy catalog, gold star tools.com pg26, Ohio travel bag of 5. About 7.00 #100
  10. I just looked and they are in Tandy catalog. Under rivets
    Read more
  11. I can't believe that you haven't found them rivets yet. I have bought the for Tandy the last time. Also bought domed rivet setters 4 mm through 12 mm. I believe they are also sold as mushroom rivets. Did you find anything o. Gold Star Tools?
  12. Try gold star tools
  13. Standard rivet, Tandy, springfield leather, check zesty or eBay.
  14. It's just a domed rivet isn't it?
  15. Try just going around once instead of twice on the tensioner you went around twice on? Try it?
  16. Just skive under it a little so that the post comes through farther.
  17. Thanks !
  18. glamb
    air brush
    Amazon you can get complete kits knock offs of iwata now Master brand ,including compressor ,airbrush $70-$80 bucks. If your not going to detail much get the brush with .08 needle.this is a gravity feed brush. Works great.
  19. Did you search this one?
  20. Is this machine still available?
  21. Is this machine still available?
  22. Why put anything? The scabbard I prefer when on a horse is unlined. It seems any lining in time starts catching a hold of sights or scopes when using linings. Just my 2 cents.
  23. Thank you very much. Glamb
  24. Use golf tees and grind off the point. You can get them in plastic or wood cheap! Teather them with small piece of leather.
