Bolt Vanderhuge
Everything posted by Bolt Vanderhuge
New Work Boots
Bolt Vanderhuge replied to Tim Schroeder's topic in Shoes, Boots, Sandals and Moccassins
Those look fantastic. -
A shooting buddy recently picked up a FN40. Here is the holster set I built for him. I had never handled an FN before so I had to make a couple test holsters to get the gun pocket and the detail work sorted out to my liking. I should have done the same for the mag pouch. Then I would have discovered that the wings should have been about a 1/2" wider on each side before the straps. This pattern is good size for single stack mags though. The build is using Hermann Oak 8/9oz leather dip dyed in straight black Feibings Pro Oil dye. Stitching is by hand using 1.0mm Tigre thread. Finish is two coats of Angelus Satin 605. The holster is flat backed but the mag pouch is not. The straps are part of the back piece of leather for both as opposed to being separate pieces. This was my second test holster. You can see in this one that the gun did not sit all the way in like it does in the finished product.
Sandwhich the top between two pieces of thinner leather than you would be using normally. Or use a liner and put the top between the liner and the outer leather piece. Same effect either way. Also try using a bottom post vs a top post as the bottom post is usually flat vs the decrative dome that a top post usually has. In this pic I am referring to the one on the left as the one to use vs the top post that is on the right side. Some of these are flat and featureless unlike this one in the pic. But hopefully this helps anyways.
Recent Builds
Bolt Vanderhuge replied to IngleGunLeather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice work. -
The leather likely stretched as you bent it. So now you have extra leather with no place to go but out leaving you with the wrinkles you have.
Did you bend the belt while the leather was still moist? That could be from oiling or, dying, glueing or wetting.
Second attempt at a holster
Bolt Vanderhuge replied to DocDaddy's topic in Gun Holsters, Rifle Slings and Knife Sheathes
For punching two layers try punching your outside panel before attatching it to the inside panel. Then after they are attatched you will find it very easy to punch thru the second layer. Also the surface that you are punching on should be solid. Too much give or softness below your project will absorb some of the impact and reduce the effectiveness of your blows. GumTrag is for getting fibers to lay down and stay down. It will do nothing for the seam that you are asking about. You need to get both panels to be even whether thru slicingshaving or sanding.- 15 replies
I do none of what alpha mentioned yet I get very nice edges without a seem. The glue that you use though could cause this issue like alpha mentioned. I use Tandy's Bond contact cement and brush it until it is wet leather so there is no extra glue. After letting the glue set up I put the two panels together and run my hands over the glued area to make sure they make full contact. But I do not add weight, clamp, or hammer the panels together. After that I use a razor blade to trim any hang over of one panel over the other. I make sure that both panels are now exactly the same before moving forward. When beveling the edges I again make sure that the panels are even by running the beveler over the edge seem after beveling. After dying and burninshing I will run some 320 or 400 grit sandpaper over the edge then redye as needed. Then burnish again and then sand again if necessary. Repeat if necessary. Once satisfied I then apply my finish. When the finish is dry I burnish again. All my burnishing is by hand but I only have to spend a couple minutes each time to get good results. The prep work of making sure the panels are even and smooth really cuts down on the rest of the work. Oh I should add that I dye my edges, I do not use edge cote. This first pic here the holster is lined so it is 4 layers of leather. If you look at the flash lit area you can kind of make out one of the seems.- 15 replies
Gap? can you provide more info and pics of the issue?- 15 replies
You are welcome.
Dot fasteners sells all parts separately. I use these caps with pull the dot one way snaps. They have other colors and post lengths. They also have actual marked pull the dot caps on another page. Look around the site. They probably have what you need. http://www.dotfasteners.com/durabletm-caps-2162.html
I am not quite sure what snap fastener rivots are but these guys might have what you are lokking for. They have each part and you can buy just the items you want. these are their Durabell caps but if you search the site you will find many other items http://www.dotfasteners.com/products/?wfc_product_brand=898&wfc_product_type=703
While the plates are the desired part of the leg, I can't imagine wearing a watch with a band wide enough for the plates. I personally would utilize the wrinkly sections at the start of the plates for a small item like this. As for weither the plates would stay down or lift I can't say. They stay down on the holsters I have used them on. I have ran the perpendicular to the gun on flat backed holsters where they go up over and down and they stay flat. But these do not get flexed and bent like a watch band does.
It will burnish exactly the same.
Flat backed for a GP-100
Bolt Vanderhuge replied to Josh Ashman's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks good Josh. Fiebings tans and browns do that to me too. I have had it happen regardless of dying before or after. I dip dye and the color looks perfect until I get it wet for forming or from applying the finish. Some only have a few darkish spots and some will be marbled all over. -
Sig p938 Holsters
Bolt Vanderhuge replied to Bolt Vanderhuge's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thank you guys. Yes that is elephant. -
Sig p938 Holsters
Thank you Matt. -
Made some new holsters for my p938 Sig. Both are smooth lined inside. Leather is Hermann Oak with inside and outside leather combined to be 3.6oz - 3.8oz. Cant on both is 25* and the ride height is mid-lo. I love how thin this gun is.
Crocodile edges. Can you burnish them?
Bolt Vanderhuge replied to Leahlovesleather's topic in How Do I Do That?
I have only worked once with Caiman tail. No other variant of croc/gator though. I did not have any issue burnishing the edges but you might be working with thinner stuff which adds to the difficulty level. I treated my edges like normal using black oil dye on them and a standard hand burnisher. I also found that the caiman tail, although being cognac in color, was able to take dye easily on all of it. The raised sections and the edges of each row ended up darker than the rest of the plates/scales. -
Springfield Leather no longer accepting PayPal?
Bolt Vanderhuge replied to BHPshooter's topic in Suppliers
Side note post here I transferred my funds right after the above post and in less than 12 hours the funds posted in my account. Wow. That is quite an improvement from up to 4 days like it used to be.- 10 replies
- slc
- springfield leather
(and 1 more)
Noticed that too this past week. This also reminds me that I need to transfer the funds in my Paypal account to my bank account so I can buy some things from them.- 10 replies
- slc
(and 1 more)
Ostrich leg Ruger holster
Thank you gentlemen.
