Bolt Vanderhuge
Everything posted by Bolt Vanderhuge
Both holsters show some nice clean work. I am not seeing any sight channels on them. This may be ok for Glocks and others that have very low profile front sights. It would not be good for many other guns, however. I would recommend adding in sight channels to your future builds.
Floral carving off the bench.
Bolt Vanderhuge replied to BearMan's topic in Floral and Sheridan Carving
Amazing work. -
Looking forward to seeing your next revision.
Here is a holster with ostrich leg. This has a good amount of detail molding/boning. This should give an idea what is possible with good veg tan under the exotic. I shoot for roughly 1-2 oz thinner veg tan, depending on the exotic thickness, than my non exotic holsters. This one look like it might be the same color ostrich leg as yours.
Ostrich leg is easily molded when laminated on veg tan leather. You may not have a thick enough layer of veg tan to hold the molding. You could try a smooth lining with veg tan instead of the suede. This will provide a thicker piece of leather and can hold molding better.
Instead of water use Neatsfoot oil to wet form it. You will want a generous amount of NF on the flap enough that is will remain soft in the bend area. After the NF has soaked thru all the fibers you can start forming it to the bend you want. When straight there will still be a little bit of leather that bunches up but it does not look as bad nor does it creat any long term cracks that tend to form over time when water is used to wet form it.
Cow and Bison backpack
Bolt Vanderhuge replied to joelpete's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That is some great work. -
My Flagship Holster
Bolt Vanderhuge replied to fallequinox's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That looks very nice. How was it working with stingray? -
colt officer dummies
Bolt Vanderhuge replied to JLSleather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Like I said earlier just sand it down the tiny amount. This is a very fixable issue. -
Ok I measured a few more. Mold gun is 1.544" (39.22mm). Para officer 1.543". 4" Springfield 1.534". 5" Colt 1.530". Colt Defender 1.520". Ruger commander 1.530. 5" STI 1.510. Dan Wesson CCO (the earlier gun) 1.524". A second DW CCO 1.525. DW Guardian 1.531". DW vbob 1.522". 5" Sig 1.515". Sig commander 1.515". Rock Island commander 1.507". My other 2 officers have tri-topped slides from the factory so they have different slide top dimensions. But even so, they do not wiggle in my holsters. The transition lines from the slide top to the sides is still in the same place so it still has a contoured feature on the top and bottom of the gun that matches close enough to that of the mold gun. But then again my mold gun is the same size as the gun at the top of the size range from the 13 I measured. Yours measures 1.563" so it is a slightly larger difference. It is 0.056" taller than my shortest one and 0.20" taller than my talest one. -
I just measured mine at the front of the dust cover and mine vs the same 1911 as earlier. The mold is 0.02" bigger. Not sure if you are aware of this but 1911s vary by similar tiny amounts due to the multitude of different manufacturers. 0.060" is only 1/16". Take some sandpaper to the underside of the dust cover and sand it down to meet you needs. It shouldn't take much time at all. -
So it is a penny too tall, is what you are saying? Build a test holster and try a real 1911 in it. See if you are ok with the fit or not. Maybe the one you got has issues. -
I have no problem with my RIA Cooks mold gun. Like I said earlier, it works perfectly for my officer sized 1911s. Take some calipers and measure it. What is the slide width and any other dimensions that you think might be off? I just measured the slide width of mine and it was 23.40mm. I then measured one of my 1911s and it was 23.40 as well. That is and exact match for my mold gun vs real ones. -
Yes it is the RIA. It is the correct size for a 3.5" officer 1911. -
I have the Cooks non prepped officer mold. It works perfect for all three of my officer model 1911s. None are Colts but my 3" Colt Defender fits in them well other than being 1/2" short in the slide area. I like that Cooks have the safety in the engaged position if there is one for a particular gun. In case anyone does not already know.....Colt does not currently offer an actual officer sized gun. It is not very common to even see an actual Colt officer either. -
Orders to ship
Bolt Vanderhuge replied to Mattsbagger's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
These look great. I really like show brown, keep up the great work. -
I see more fibers than I would want to see. If it were mine I would sand the edges with some 400 grit then burnish then sand with 600 grit and burnish again. The sanding should be quick. For a wallet it should take about 1 or 2 minutes to go around the whole thing.
Your example of 30cm (12") even at 17 cents per inch would only be $2.04 us. That would not be much at all here in the states. If that is a lot where your at then it could be worth it to you, It would not be worth it to me that is for sure. I would be more inclined to mirror chrisash's suggestion above.
Watch this little video: "Blam"
Bolt Vanderhuge replied to Dwight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I say this a while ago on 1911forum. It is hard to read the last digit of the year. It looks like it says 12/05/2018 but obviously that is not possible unless the camera system has the incorrect date. She certainly did a good job. -
A few recent orders
Bolt Vanderhuge replied to Jbrandon's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like all of your items from both threads. I really like the spine piece on your notepad portfolio. You are already doing good work. If you can get your stitching and edges smoother flowing/straighter and their spacing to be even it will take your work up another notch. Keep up the good work. -
Glue on edges squeeze out, won't burnish well
Bolt Vanderhuge replied to AllanD's topic in How Do I Do That?
It sounds like you are applying too much glue. As well as not letting it dry to a tacky state like Stetson mentioned. When you apply the glue brush the glue onto the leather then keep brushing until the glue is flat and thin. If you can get it to a point were it looks like the leather is wet with nothing on top of it. Then let both sides dry to a tacky feel.
