alexitbe
Contributing Member-
Everything posted by alexitbe
If you want to sew veg tan leather that keep the singer 45k.... It will go through anything you are likely to want to sew.... The singer 29k is a patcher machine and is really only meant for thin leather, which you would find on boots and shoes... The Allbrook is a fur sewing machine and is not much use for anything else...It produces a chainstitch which will completely unravel if the thread breaks... It does not break with fur coats or hats because the thread is protected by the fur itself and the lining... I would get rid of that if you have no intention to sew fur gloves,hats, etc.... Note that these raise quite a bit of money in Europe. Maximum 400 Euro.
I would keep the pfaff 192 since its specifically for leather and its a post bed which are not cheap to buy. You can convert it to a flat bed sewing machine by maying a simple raised table for it... However, its probably not strong enough for veg tan leather you might use for belts... However, for bags and everything else ts extremely flexible
The leather should be between 1-1.5mm thick for shoe uppers... Typically 1.2 mm is used.... There is the expression that the leather should be tight to the toe, which I believe means that the stretch on the leather should be across the shoe and not along the length of the shoe. So lay your vamp and quarters on the leather with this in mind.... However, I have seen old pictures of laying out the pieces on a hide and they haven't followed that rule.... So take that for what its worth.. Alex
Well, just giving some feedback.... I have bought two pieces of leather from Adrian, recently. One was half a skin and the other was a belly. I found the half skin to be really good quality and the belly was pretty good too. His initial postage quote was very expensive, but he was flexible enough to allow me to organize the courier and the postage dropped from 40 euros to 16 euros. So do not let the postage put you off. I am so pleased with my order, I am waiting to order again. Although it seems Christmas is a busy time for him... So I would say, that you can order with confidence from Adrian Hope that short review helps other people make their decision Alex
Thank you very much... I am trying to make shoes too and it would be nice to be able to do simple broguing Your shoes look like they are coming along nicely... I am folling this thread with interest. Cheers alex
Hi HaloJones, Can you give a link to where you bought the brogueing tool? It looks quite a useful tool... I bet it saves lots of time Thanks alex
pfaff 345 2 new old pfaff 345 in the house...
alexitbe replied to BoRo's topic in Leather Sewing Machines
I would say you are probably in luck... I guess they have the same hook as the pfaff 141 series of sewing machines. There should be a number on it somewhere... Please let us know and then we can probably help. Well done alex -
45-50mm pulley for Reliable servo motor
alexitbe replied to shoepatcher's topic in Leather Sewing Machines
really, I found the best place was ebay or aliexpress... -
I like to have my machines on a treadle despite having servo motors... They are so easy to control for the hobbyist and dirt cheap... The patchers can still be bought with a treadle... Since our sewing with leather does not typically involve long runs of fast stitching i believe there is little benefit with a servo motor of a treadle
Got to agree with... They rank as badly as CNN
Hi Adam, can you describe how you sharpen and what you should look out for? Its something I will have to do soon... Thanks alex
- 18 replies
- skiving machine
- skiving
(and 1 more)
It was no problem to do, I am happy to help if I can... Its a shame that interest is so low... Thanks for the advice on the skiver. Your are right, it has not been used in a very long and I have never used one personally... It is something I will work on after I fixed my Pfaff 193-5 shoemaking machine... The skiver is for shoemaking too, but everything is taking so long to find and then repair...Oneday, I will have a workshop that works.. Enjoy what remains of the weekend. ALex
Here are measurements for a Fortuna DRP... Its very old so may not be relevent... But I think many of the skivers are based on this old model so maybe it helps
With regard to stropping the blade: do you add any polishing compound to the leather or is the leather enough...? If I were stropping a skiving knife I would use sole veg ant leather to strop on... Would you use 2mm veg tan here or a chrome leather? Thanks Alex
haha.... Lucky guess! But since I started skiving by hand I have come to realise how important removing the burr is...
I don't know anything about this machine, but is the scraper at the correct position and angle to the knife? Is it possible to vary these? I would put the scraper either just after the leather has been cut by the knife or at 6 pm on the bell knife after gravity has collected all the leather from the cut... I guess there will be an optimum angle too... Have you thought of replacing the scraper with something that doesn't let things gather under it.... say something like an angled rod (like a finger stuck inside bell knife) that presses into the bell knife... It would remove the big pieces of leather, which presumable take the littler pieces with it... alex
Could there be a burr left after grinding which just needs removing? Alex
Setting feed dog gap side & front to back. Pfaff 145
alexitbe replied to Devo's topic in Leather Sewing Machines
Thanks Bob.... I see now its a walking foot machine, it makes sense. Cheers Alex -
Hi Bob, I know, you know your stuff, so that is why I am asking... I don't understand how the green screws on his picture will allow you to move anything to do with centering the needle in the needle plate. I understand the mechanism alters feed dog position, etc.... I am confused, if you have time can you explain? Thanks Alex -
Well I have been recommended to not use leather thicker than 1.4mm for the upper, as a beginner... I think that is less than 8 Oz.... If you are using 8 spi, then maybe 10 spi is reasonable for me... Thank for your response Alex
Does anyone have any experience with sewing shoe uppers by hand? What spi would you recommend? I am thinking of 10 or 12... and slanted saddle stitch... Thanks Alex
as ledermaschinist said... It will be easiest and probably best to bronze or even silver braze... Its not difficult to do.... however, other types of welding take much more skill and knowledge... Regarding it flying apart at an inconvenient moment.... Why would it? There is no torque on that part of the fly-wheel... Its the rim and there is no leather drive band...
open with paint software (all Windows computers have that) and reduce size to 25% and save. Your photos should then be small enough... Alex
Glenn and Constabulary helped me out too... They are good guys and very knowledge... Don't forget to share your knowledge too, whatever it may be... Cheers Alex PS you have one of the best patchers out there!
