Everything posted by Instinctive
Are you looking for a belt pouch for trap and skeet shooters that can carry live and spent shells?
@Uwe Your mounting instructions for a swing away edge guide were extremely clear. Did this to my Consew 226 following your instructions. Very simple process with good preparation. Thanks.
- 10 replies
- 111w155
- stitching guide
(and 3 more)
Finished Sheath for Customer!
Instinctive replied to YinTx's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Great job on the sheath. Your client is so going to hate that handle design. It's a real pain to put the flap through the hole in the handle in a real world carry situation. I just built a new sheath pouch sheath for a guy who had a similar concept.- 36 replies
Horizontal Knife Sheaths
Instinctive replied to BillinTR's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I pretty sure the short answer to this is no but there should be a simple solution for you Harward stores like Home Depot, etc. sell nylon nuts and bolts. You should be able to use a standard chicago screw and just purchase a nylon nut that slides over the screw post. Should be about the right thickness too. You may need to drill out the nut. Hope that's clear. In the future likely better to have posted this as a separate question. Things can get buried in these post easily. -
Edge Guide for Consew 225 (and clones)
Instinctive replied to KeithHideWorks's topic in Leather Sewing Machines
My question is, where do you get that little spring clip holding the slide plate in place? My Consew 226 does not have this. -
Consew 226 Presser Feet Height Adjustment
Instinctive replied to Instinctive's topic in Leather Sewing Machines
Thanks. That is the same manual I have. Diagrams are really bad but thanks to a good setup video for a Juki LU-563 I found and that manual, I think I have been able to sort it out. Was able to get the clearance I need for 3 layers of 8 oz leather. When doing that it seems that I would need to readjust to do thinner material. Is that the norm? -
I am setting up my first sewing machine, a Consew 226R-1. Sews really well with 3 layers of 8 oz leather and 138 thread. It came from an upholstery shop so was basically set up for thinner material. I understand the machine presser feet can lift up to 1/2". Right now the presser feet lift about 3/8" and when sewing they walk with a lift of about 1/4". Old manual and my unfamiliarity with these machine have me handicapped to make the necessary adjustments to raise the feet for better clearance. Can someone advise me the proper procedure for: Increasing the stationary lift of the presser feet to 1/2". Increasing the walking lift to provide clearance for the thick sewing if that is possible. Thank you.
Black Mountain is owned by Devilhide Leather (Instagram @devilhide_leather). He is using Shopify for the tools sales site. Shopify is a Canadian company which would explain the Canadian IP trail. I donlt know anything about the quality of what he sells on this site and from a marketing perspective, always good to have more comprehensive information about your company including a physical address and phone number.
Thanks. Crazy Horse Water Buffalo. Love working with the stuff and the pull-up look is fantastic with it. I don't have a Becker myself. Just 4 knives from local makers :-) -
One I did for a Becker BK-16 but with a removable can pouch. Customer requested design that allows for a left or right carry by re-configuring (belt loops, pouch and knife strap are all connected with chicago screws -
No problem. Just be sure to print with no scaling and let me know how it worked out for you.
Mountain man inspired sheath
Instinctive replied to Stetson912's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Really nice and a great looking knife too. Good luck on not having a welt. The stitch style (which I really like) should make it easy to install one if the knife works it's way through :-)- 12 replies
- damascus
- drop point
(and 3 more)
Weaver leather supply also sell them https://www.weaverleathersupply.com/catalog/item-detail/01144-sb/1144-collar-fastener-set/pr_1730/cp_/shop-now/hardware/specialty/miscellaneous
If anyone remembers Mick Foley, aka "Mankind" from WWE/WWF wrestling, he wore a unique leather mask (google it). Been ask if I could make one. Anyone have a pattern laying around? Trying to avoid a a "face fit" session if possible.
- 3 replies
- leather mask
- mankind
(and 1 more)
@howlback Your comments are right on. I finally applied it with a the recommended damp sponge and found exactly the results you describe. I too like a little bit of a "dirty" antique look or my leather to look like leather when I'm done. I have been spraying a 50/50 Resolene/water mix before antiquing (usually 2 or 3 light coats). Never tried the Tan-Kote but I will put that on my list. Do you cut it for spraying?
- 3 replies
- fiebings
- pro resist
(and 1 more)
Tool handles are too small. Head over to the nearest Home Depot, Lowes or whatever you have near you and buy a 1-1/4" hickory or other hardwood dowel. You can usually get a 6' piece. Cut it into 24" long pieces and make your legs.
I am certain you will find this helpful. https://www.leathercraftlibrary.com/p-1123-lacing-and-stitching-for-leathercraft.aspx It has very good pictorial instructions for several different styles of lacing, how to start, how to splice and how to finish. I keep it beside me when I'm lacing, mostly to make sure I get the finish right. Tgis is an example of typical double loop lace on wallets.
Weaver Leather has a nice little video on cutting clean filigree.
For those looking for a pattern, this is mine. PDF down load attached. Print on 8.5x11 paper with no scaling on the print size. I found 24" legs with hinge point 10.5" from the top works well. I use #9 copper rivets for my assemblies. Stool Seat PDF.pdf
Anyone have experience using Fiebing's Pro Resist and can you cut it with water to apply with an air brush like Resolene? It's seem very thinck to apply it as supplied form. Thanks.
- 3 replies
- fiebings
- pro resist
(and 1 more)
Need ideas for deer hide sheath
Instinctive replied to archeryrob's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks. That is very clear. -
I have apiece 6 oz milled and was wondering what to do with it. Did you wrap it around a liner to give it some body?
