Everything posted by Thor
Messenger Bag
Thor replied to opus56's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That is one very nice looking bag! -
Sorry, I don't get it. This will just stay as is, right? Lots of detail in such a small area. Good job. What did you use, just a ball point modeler?
Very nice chaps. They will sure last you a long time. Wonder what they look like being put on.
R.c.m.p. Notebook Cover
Thor replied to Manypawz's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Hope you're a member of the Go Rent a Cop party :-) Nice work though. -
Thanks camano. Mike you wouldn't believe how many products I went through in the local building supplies. None of them contained it. Sometimes it's really hard to find an equivalent. Wouldn't have thought that it would be found in a bee's keeping supply shop. However, thank for your help. Problem solved.
Sometimes it can be tricky to get the stuff you need and sometimes you don't get it at all. Later one in my case. The local pharmacist is unable to get it. Therefore I'd like to know if there is any other method of getting rid of them nasty spots on the leather. Would acetone work as well? Just for reference, here are two threads covering the topic with oxalic acid. http://leatherworker.net/forum/index.php?showtopic=25558&hl=%2Bremove+%2Bblack+%2Bspots http://leatherworker.net/forum/index.php?showtopic=21788&hl=%2Bremove+%2Bblack+%2Bspots I've seen the lemon juice idea, but haven't been able to reproduce.
Fishing/camping Chair
Thor replied to wantedleatherworks's topic in Furniture: Inlays and Upholstery
Haha and I was going to ask for the treasure map. Now you'll have to add that it'll be found under the seat.- 15 replies
- bushcraft chair
- camping chair
(and 4 more)
Thanks folks. I'm not very good at painting and would hate to ruin it. So I guess I will get myself a hairline tool and add some more detail. Troy I was stuck and needed some input. As always it's just a prototype and a training piece on the way to becoming a saddle maker. I will post some pictures when it's completed. Still haven't decided what the carrying strap should look like...
Can Anyone Identify This Sewing Machine Brand Name?
Thor replied to llucas's topic in Leather Sewing Machines
Looks like a German Pfaff. There should be a model or type decal somewhere on the bottom or so. It could also be an older Juki. -
From the album: Messenger Bag
Here I would need some input. To dye or not to dye, that is the question. The whole bag will only be oiled and sealed with a finish cote. So the options would be to dye the edges in either black or brown or just leave it as is. Please ad your 2 cents. Thank you! -
The dark areas are from the leather still being wet. It's still missing the carrying strap and I'm wondering if I should ad some more detail to the feathers which I didn't want to in first place. -
First Attempt At Carving-Please Critique
Thor replied to Jeep1967's topic in Floral and Sheridan Carving
You got it! Glad I was able to help. -
Except for the Cheyenne roll, this looks a lot like the saddle I'm thinking of making for myself. I might have a deeper pocket. Really enjoy watching your progress here and how the saddle comes along. Maybe you should make some sort of a brief tutorial at the end. With all the oops and yeah. Thinking of myself that would help me big time.
Wouldn't you achieve sealing with a couple of finish coats as well? If you rotate your stamp between your fingers from left to right and back you'll achieve the best result for back-grounding. I've done tons of it thus far and what I do is: holding the stamp about a 1/16" above the surface and let it rotate with each tap. In time this goes like a charm.
I'm interested to learn more about the history of the western stock saddle and of course came across these two titles: Saddles http://books.google.de/books/about/Saddles.html?id=lKYZy8dq8qMC&redir_esc=y They Saddled The West http://www.amazon.com/They-Saddled-West-Lee-Rice/dp/087033199X Since those 2 books are everything else but cheap I was wondering if someone on here has these books and could share his/her thoughts about them. If there's an online version of any of these books I'd be very interested to know. Also if there's an online equivalent to those books, or to start with, I'd like to know about. Thank you!
Well a detailed how to can be found in the Stohlman book How To Carve Leather. As for critique - I wouldn't use a checkered anything on the leaves etc. Besides that using a checkered stamp for the background and for parts of the pattern isn't very good. The eye gets confused. A smooth or lined beveler would be the tool of choice for the the leaves. Also where the leaf folds over an undercut would do a terrific job. Try to avoid walking marks. In some parts the cuts are deeper than you beveled. If you start the backgrounding process work away from your picture. Get yourself a tipped beveler (triangle shaped) F976, F910, F941 for example. Those are the tools of choice for the leaves instead of the cuts. Cuts really just go on the stem. I'm not doing roses all too often and didn't take a close up of my last one, but this might help a bit. The stripe is about 3" wide. One can tell, that the roses and leaves are not that big. I didn't smooth the blossom leaves on purpose as there isn't a straight flat leaf on a rose. -
@Calait, here's what you might need. The original Doodle page is currently for sale on ebay.com. If shipping to Germany wouldn't be so expensive I would just get them one at a time.
I agree with Troy doesn't look like the casing process was completed. You're definitely on the right track.
