maxdaddy
Everything posted by maxdaddy
  1. That's great, thanks for sharing. I assume that the stitching holes are burnt with the laser as well?
  2. @fredk That's awesome. A guy in Ireland in 2021 watching 1950s American TV shows about cops. Cheers! I do love seeing the classic cars in those shows. I'm not a holster guy either but I had ever seen anything like that before so searched around and found what I think you're looking for. Seems like they were referred to as Safety Speed Clamshells. Check out the full article: https://revolverguy.com/fighting-leather-clamshell-holster/
  3. Nice! I like everything about it.
  4. Thanks for creating and sharing that video!
  5. THat's way cooler than carrying them in a plastic bag, for sure!
  6. That was probably more fun than yard work. Those came out great. (Just added to my list of future projects.... "make some cast-iron pot handle covers")
  7. You've obviously done a great job of integrating it into your workflow. Thanks for the details. Will the Glowforge also burn the stitching holes? I've had a Cricut Maker for about a year and I should probably start working it into my projects using a similar approach. I'll need to 'outgrow' the Cricut before I can justify the expense of a Glowforge.
  8. Gray, I've long admired your work. Can you describe how the laser is used in your belts and strap projects?
  9. I'd call that a big success. Looks great!
  10. That looks great. What stamps did you use for the weave design?
  11. THat's nice. How about making a matching belt-worn shot bag to go along with it and hold the ammo?
  12. Meaningful Christmas tree ornaments are some of those things that have very long lifespans. I bet that the folks who receive one of them will still be hanging it on their tree with pride in 20-years. I still use one every year that I made in Sunday School when I was 4 and I'm 55 now.
  13. In the time you've been gone I've made this forum a part of my daily routine. Hopefully you'll be able to integrate a fun and creative outlet into your daily routines now. It certainly sounds like you've had 8-years of daly routines that were anything but fun and creative. Welcome back!
  14. That's a great idea and I can see where it would speed up straps as well as wider cuts. I would think that the wood channel in the base could be a problem with thinner leather. Like the leather would be pressed into the channel instead of lying on a flat surface. I have a paper cutter around here that works similarly and it's quicker than breaking out a square every time I need to cut paper.
  15. That came out great. I've got a side of the Tandy Sabana leather that I am planning make into a bag after Christmas. Did you put feet on the bottom or is it flat? https://tandyleather.com/products/sabana-sides?_pos=1&_sid=4168d5fb5&_ss=r
  16. A few years ago I started using vinegroon to make all of my strap handles black. It's a very forgiving, cheap, and fast procedure... Basically I can dump dozens of straps in a plastic bin with the 'groon and swish them around in it for a minute or so. Then lay them out for a few minutes on a flat surface. I see them turn dark black quickly and after a few minutes I rinse them en-masse in a water/baking-soda bin for a bit and finally rinse them in a bin with clear water. Start to finish in less than 15-minutes and I can do *lots* of straps at once. After they dry, buff a little and apply oil and you're good to go. The oiling takes much longer than the rest of the process since it is done with a dauber. Vinegroon may not be the best solution for this particular project but I recommend that you try it just to judge the range of possibilities.
  17. I assume there's no hole on the flat side to accept a rivet?
  18. Nah, since the formula is vinegar plus iron plus time, I'd say just keep it onhand. I keep a gallon of it brewing at all times in a big pickle jar. The longer it sits and ‘cooks’ the better. While it’s fermenting it will bubble off gasses, so don’t seal the lid of the jar tightly, rather, leave it covered loosely just to keep out large debris and bugs. Since it will smell like a festering bottle of vinegar, and looks nasty, you’re not gonna want this mixture in the house so hopefully you have a safe place away from your normal living area where it can sit. Every few months I'll feed it another handful of nails or steel wool to keep the chemistry going. I don't even worry about straining it anymore either. I just pour it in a plastic container for dipping or if it's going to be used as an edge treatment I just scoop a little pill bottle amount out to dip a small brush in.
  19. The stitching and molding looks great! Is it designed to clip to a belt for easy on-off?
  20. Apply oil after the 'grooning. I always have a gallon or so of the stuff cooked up in the corner of the shop and there's no faster way to make a bunch of small to midsize pieces black, in my opinion. I think that the smell is weaker with older vinegroon than new vinegroon. I haven't tested this hypothesis scientifically though, so I'd be interested in your thoughts after a few months of using it on various projects. Be careful when attaching metal rivets, d-rings, conchos, etc. to the 'grooned leather pieces as certain metals can corrode very rapidly from direct contact.
  21. Wow, that's intense!
  22. Epic!
  23. Thanks for sharing the video and pictures here. Looks great. I think that the square patch covering the outside of the magnetic fastener would have been a good place to incorporate one of the interior colors, though. Maybe a yellow tassel as well? Like a tease of what to expect when you open the purse.
  24. The bungee idea is great. I assume you then trim flush and leave the bungee inside the handle?
