Everything posted by dikman
Pfaff 145 h4 and New Tech servo motor
dikman replied to seamsperfect's topic in Leather Sewing Machines
As Uwe said, that servo is probably pretty generic judging by the control box. If it's working and runs for a few minutes then it should be ok. Ideally you would want to get the "handbook/manual" with it so that you know how to adjust the settings if needed. As for power etc. it should be more than adequate for your needs. A quick search doesn't bring up that name, which isn't surprising as if it's an older one that brand name probably doesn't exist anymore. -
COWBOY CB4500/441 NARROW FEED DOG + NEEDLE/THROAT PLATE???
dikman replied to RockyAussie's topic in Leather Sewing Machines
I think you'll need to use abrasive (stone) bits to open up that hole. Even carbide can have issues if the steel is good stuff that has been hardened properly - which this obviously is. -
You must be feeling pretty pleased with yourself . It wouldn't take much to open out that screw hole with a Dremel and a grinding bit. -
The decal-setting solutions are used by plastic modellers, if you have any hobby shops nearby that sell plastic model kits they may be able to help. As for cutting a stencil and spraying the name, that would be a lot of work and may not look as neat, particularly on a rough surface.
Looks a lot better than when you got it, Jeff. Nice job.
TOMAHAWK SHEATH
dikman replied to Dave Richardson's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Ok, thanks Dwight. I still wouldn't mind trying to make one sometime, could be an interesting project. -
TOMAHAWK SHEATH
Do the different tribes have their own pattern? I always thought that the Indians used whatever they could get hold of. Looks like I'm about to learn something new..... -
Ballu, be patient regarding replies as you may have to wait overnight for answers due to time differences. I don't know anything about those machines other than a google search, but the Adler is considered a very good machine from what I can find out. Either would be better than what you've got as they're both walking foot. You need to define what you mean by heavy thread? Up to #138 or heavier? If heavier then you will likely need a bigger machine than these.
Have a look at this post - The Consew P1206 mentioned might be worth considering BUT if you want to use heavy thread you will need to go to a much bigger machine. You won't be able to use anything like the Ritza or Tandy thread in such a machine. As northmount said, there is lots of good advice already posted, with many asking similar questions to you.
Is the thread coming off the bobbin in the right direction?
Most dangerous way to carry a gun!
dikman replied to Mattsbagger's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Is holster the right word to use? Certainly be cheap to make, no wet moulding, no stitching, minimal amount of leather required..... -
Machine for mostly canvas, some heavier stuff
dikman replied to mwpdx86's topic in Leather Sewing Machines
I reckon you've made the right decision, as I said it looks like a nice machine. Let us know how you go with it as it will be useful info for anyone else considering buying one. -
Thanks guys. It does use the cylindrical bobbins, so that's one big negative if it doesn't come with extras, and 24 mm (1") of leather is putting it into the realms of the Cowboy 4500, and it definitely is not in that class! That info. I printed comes from a Singer publication relating to the 42 class. Mike, that ismacs listing also says it is for "saddle stitching", whatever that means. I think the reason that the 42-7 isn't in that parts list is because it doesn't have alternating pressers so is different to those other models.The guy wants $400, and it's been listed for a while so I don't think it's going anywhere soon. Based on what Wiz has said unless it was virtually being given away I don't think I'll touch it. Besides, I've just been spending quite a bit recently getting my bike (2005 Bonneville) up to scratch, plus I've just bought an 1866 lever-action rifle (lots of $$$!), so I think maybe I'd better stop looking - unless a machine pops up as too good to resist!!
Just curious. Someone is advertising a Singer 42-7 and claims it can sew two layers of 12mm leather (which I find hard to believe). I can't find out much abut this model, other than Can anyone shed any more light on this one?
Home Grown Burnisher
dikman replied to Dwight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I would hazard a guess that tapping into the wood was slightly askew? At least, that's what's happened to me when I've used a similar process. -
Sounds like a good deal, I'd say you've done well. They are a nice solid machine. I ended up replacing the handwheel on mine with an 8" pulley, might look funny but it can go slow with lots of torque. Now you just have to buy lots of needles and lots of thread .
Good one. That's what it's all about . As for the "orbital action" I'm sure the leather won't care! -
Yeah, looks good, no paint wear on the baseplate that I can see. Slowly rotate the wheel by hand to make sure nothing is binding and everything is moving as it should, if you feel any tightness stop and find out what it is. Remove the bobbin and make sure it's all clean in there. As Constabulary said, get a manual, must have a manual! As to what to avoid - DON'T start loosening screws until you understand what you're doing.
Jeff, screw threads on Singers are often proprietary (i.e. their own weird thread) so the chances of getting them local, other than at a sewing machine place, is probably nil. The foot that you bought, does it fit except for facing the wrong way (screw hole lines up)? If it does can you rotate the mounting bar 90 degrees? They are often only held in place with assorted clamps.
No worries. Normally shipping from China to Oz takes anywhere from 3-5 weeks, this one came in just over a week!
That's bizarre! Looking at the exclusions it seems like most of the world is excluded!!! If you look on ebay there are others who sell these things, I'm sure some will post to the US.
http://www.ebay.com.au/itm/Drawing-Ruler-Template-Drawing-Round-Circle-Quilting-Patchwork-Stationery/132252951069?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Got it slightly wrong, it was $2.90 and it's now gone up to a whopping $3.80 (Aus). I did find others when I was looking, this was the cheapest then but prices do fluctuate on ebay. 480volt, those are very classy.
In another thread Red Cent mentioned he used a Quilter's template to aid in making his stitching pattern. Seemed like a good idea, but when I finally found one it was a tad expensive (over AU$30), so I spent some time on ebay and eventually found this - $2 shipped from China. Good enough for me. Max. diameter is 120 mm, about 4 3/4".
If you're making clothes, making/repairing rugs, sails, tarpaulins etc then a flatbed on a large table will make it much easier to handle the material. For what we do a cylinder arm has a bit more flexibility, but it's not essential.Many on here are happily using a flatbed for their work. My suggestion is to read as much on here as you can, looking at which machines members are using and what works for them. You will see that the same brands/models often tend to get mentioned. Make a list of what will suit you and then start looking to see what's available.Sometimes it can take a while until the right machine appears (unless you're very lucky, occasionally we've all had that happen ).
You've sort of got it right with your photo, basically there is the needle bar, an outer foot and an inner foot. You can do belts on a cylinder arm. Some people make a small table to fit around the arm so it acts as a flatbed. There are photos on the site showing these (Uwe makes a really nice one). Either cylinder arm or flatbed will work for you, it's a matter of what you can find (and afford). For most of us this is only a hobby, although it can get expensive if the "machine collecting bug" bites!
