fredk
Contributing Member
Everything posted by fredk
  1. They are indeedy very nice but. . . .but. . . . but. . . . . we need details!! Leather thickness, dyes used, finish used, plain back or other material on the back side???
  2. I would imagine; starting at the left most stitching, across, round the knife, across the back, around the spike sheath and back to the left line of stitching and then carrying on to the right line of stitching. One piece of leather. This would give 3 layers of leather at the stitching area. Skive the two ends and the place where they meet on the back piece and you can get it down to just over 2 thickness worth
  3. First reckoning is what you want to make with it. Shoulder is fairly stiff but not as stiff as back bone part of a butt, a shoulder is not very wide, not wide enough nor thick enough for a man's belt but you can usually get a woman sized belt out of its width This chart done by Tandy is handy. It is a guide only, you don't need to stick to it absolutely For a first leather I would, and did, select a 2 to 2.5mm leather. Its a good all rounder and you can thin it if necessary. So that would be the 026 I've dealt with Le Prevo for about 20 years. I've not dealt with any others mainly as none would send to me in N.I. Email or phone Jan or Stu at Le Prevo. Tell them what you want to make ask for their advice & suggestion. They will help you choose ** be aware that Le Prevo prices need 20% VAT added plus a delivery charge & 20% VAT on that too PS. Look in Le Prevo's Clearance Offers. There might be some cheap-ish leather there.
  4. copied from some sellers lists; Size 1 54.5mm length x 1.0mm diameterSize 2 54mm length x 1.05mm diameterSize 3 53.5mm length x 1.02mm diameterSize 4 48mm length x 0.9mm diameter 1/0 (18) 57mm long x 1.09mm diameter 2/0 (17) 60mm long x 1.42mm diameter 3/0 (16) 62mm long x 1.63mm diameter ***Size 4***: 50mm length x 0.86mm diameter***Size 001***: 55mm length x 1.02mm diameter***Size 002***: 55mm length x 1.02mm diameter***Size 003***: 55mm length x 1.02mm diameter***Size 1/0***: 57mm length x 1.09mm diameter***Size 2/0***: 60mm length x 1.42mm diameter***Size 3/0***: 62mm length x 1.63mm diameter
  5. try old fashioned shoe polish - the wax based stuff in a tin
  6. Try sealing what you have done with two coats of 'Pledge with Future Shine'** polish which is actually a thin acrylic varnish. No more than three coats as it will start to be thick and become inflexible ** or what ever it is currently called - they keep changing the name!!
  7. Can you tell us where you are located? then we might be able to advise you of a source near to you
  8. I'd use pigskin suede, glued to the main leather
  9. Not always so lucky. I'm now waiting 54 days for thirty special Chicago screws I want to use on a project. Estimated last delivery date, June 24th
  10. yeah, I noticed that after but cudnae edit my post. Have had stuff from both places, its fine Its ok, these Chinese bods have warehouses in Eire and UK now. Same-ish situ, bought some oval hole punches last week. Sent from warehouse in London, 3 day delivery. We will see when I get these, thats the pudding
  11. Time to add something Whilst browsing ebay I came across these: 20 stamping tools for under £9. Quality? I'll know when I get my set. As the Tandy tools are made in Taiwan same as these are I see no big problem. I reckon they are cheap enough for a beginner to use to try out the art of stamping or in my case to take a grinder in my mini-drill to reshape some of them https://www.ebay.co.uk/itm/20pcs-Carving-Working-Saddle-Making-Tools-Leather-Craft-Tools/273593838549
  12. Most excellent What size is it? what is it on? eg, a book cover, a box. . .
  13. Not recommended at all
  14. Here's how I would tackle this; Veg tan leather, use a swivel knife or even a very sharp craft knife to cut into the grain side the pattern required - just a very shallow cut. Apply main colour dye in areas not to be painted. Thin the paint, to milk like. Apply paint in several thin coats, allow the first, second and even the third coats of thinned paint to soak into the leather, let them dry a bit, about a 1/2 hour between coats. Further coats just to get the colour density, not too many more coats. Let everything dry for at least 24 hours in a warm environment. Then apply thinned Resolene or Super Sheene. Let first couple of coats dry as per the paint. A couple more coats [4 in total] should have it all sealed. Allow to dry for at least 24 hours in a warm environment, then let it cure for at least another 24 hours - there is a difference between 'dry' and 'cured'. Resolene is an acrylic finish which needs time to cure. Thats just the painting bit. Hardware attached and edges bevelled and slicked before painting and after pattern cut. My old favourite; this painted knife sheath. Painted with modellers acrylic paints. Lasted about 8 years in and out of a box full of chainmaille armour and other stuff. Never looked after. Still a little bit presentable but needs a repaint - when I find it again in my 'to do' boxes! New; Later:
  15. I reckon you'd need to PM a moderator or Joanna
  16. you need to use sewing machine oil. Try a local knitting/sewing shop.
  17. I can't access that picture
  18. First questions; do you thin the paint before application? allowing the first two or three coats to soak into the leather then building up the colour with more applications of the thinned paint?
  19. I have some basic starter kits left over from some classes. They have most of that kit but at 1/10 the price I don't want to put them up here but if you PM me I'll send you the list of items and price
  20. Nice tute. Is that an oil can you use as a glue pot & applicator?
  21. I concur, probably finger nail scratches. Ways to remove? burnish with a flat piece of glass which has a rounded edge. These are sold as burnishers; example - https://www.amazon.co.uk/Leathercraft-Glass-Slicker-Burnishing-Leather/dp/B004JAOB2K You can get these cheaper than this or you can make your own. For small nicks and marks you can generally reduce them with a spoon end modelling tool or even a teaspoon, but for large areas like this you need the glass plate Ways for it not to happen? cut finger nails close, be careful or give up leather work.
  22. I used two needle files on the inside, one round rat-tail for the ends and a flat for the sides. I only gave the insides a bit of a wipe with them after I went round the outside with a flat diamond plate and some fine whetstones. The files were wiped over the inside lightly to remove any burr raised
  23. I find that indelible marker ink is alcohol based. I remove it with meths. I can also get it in every colour. I use them for fine 'painting' on leather. Sometimes the markers are sold as 'paint' pens but they have ink in them not paint.
