fredk
Contributing Member
Everything posted by fredk
  1. All the crystals I have have short stems, good for just about 1.5mm, 2mm max leather. I would put the rivets on strip or strap of the thickest leather that can take them then glue & sew the strip to the main collar leather. Just working the other way round; thin backed by thick rather that thick backed by thin
  2. I was using the word 'liner' in a general sense, that its not the main construction A simple fix; get a thin piece of leather, if this is on the outside; leather of contrasting colour, like red, stamp it either with an impression or with ink, a design of your liking or initials, or for the inside leave plain. Glue that piece of leather over the bad part; well beyond its ripped edges and over the belt edges, then sew it to the main belt. Making a feature rather than trying to make a hidden repair
  3. I think I may have come across belts made like this one. The lining is PVC. And that is near impossible to repair. But it can be patched. A new piece of PVC would need to be vacuum formed on to the belt with special bonding adhesive
  4. 1. Find someone who does 3D printing and designing. I know a chap who does and he made me some different sized ampersands. He drew them up and then printed them for me. Charged me not a lot. With 3D printed stamps once you have the file you can print out at different sizes. You need to use a press with these stamps 2. I get brass stamps made by one of a few different Chinese makers through ebay. Their prices are reasonable. With brass stamps you are stuck with one size. You can heat them to burn the design on. You can use a press or a mallet with them
  5. fredk
    Manpurse
    Most excellent. You captured the Nordic, aka 'viking' decoration very well. That interlacing, also used by Irish Celts is extremely difficult and you have done it very well
  6. Most excellent. Thanks for 'reporting' back in with your news
  7. I've not used pens for antiquing but I use them for other lining jobs, such as letters. Gel ink pens work best but need care as the ink is not waterproof. Brushing on a sealer over the ink can smudge it. I dab on a light first coat of the sealer, then a heavier coat Pens used on a number of these and some coffee cup cuffs
  8. I checked mine last weekend and yesterday No change. Nowt happening in way of mould/fungus or bad smells. All pieces are getting a wee bit darker on the grain side but I think thats because they're getting direct sun light on them. All pieces smell faintly 'leather', with just a hint of the stronger oils on those pieces A proper detailed check this weekend
  9. a. the few knife sheaths and sword scabbards I've made I've just rubbed in plenty of beeswax on the inside part
  10. Just think; someone's therapist knows all about you
  11. I keep sniggering. A 'hot box' means somat else here Another way is for your 3 year old daughter sneak it off your work bench and hide it amongst the tomato plants in your green house, and you not find it for 3 weeks, long after you've made another for your friend No 3 year old handy? plenty of parents will lend you one for a day Sorry, I'm just being silly
  12. Nice looking shootin irons easy-peasy to make holsters for dem Ya gan doit lad
  13. Very nicey indeedy You're very good at these caricatures
  14. Almost 2 weeks ago I went looking for a large plastic envelope containing nearly 50 A5 sized sheets of double-sided sticky. I had used a few sheets just a few days before. I spent a few days looking for it. I looked in the usual places and even in the unusual places. I couldn't find it so I ordered another 50 sheets which arrived last Thursday. On Friday I started a search for my set of chopped-off fingers to get my hat band ready for this coming week. Even though I'd set them out early last week I couldn't find them.As I looked for the fingers I found the envelope of sticky sheets. Late on Saturday as I was putting some hardware away I found the fingers Then I went to put the new stock of 50 sticky sheets in with the old stock - but now I can't find them! Hat is ready though;
  15. I too missed this one Its very nicey indeedy. An unusual pattern for it. Not seen anything like that afore
  16. Interesting Good find
  17. I use a beeswax mix rubbed on and burnished. Others on here use Gum Tragacanth
  18. Its a very nice set. Clever idea using elastic on the bottle sleeve @Klara they have to cover the label cos they don't have real whiskey ( but think tantalus) I've seen plenty of bottles of whiskey. I wanna see a picture of the Rodeo Queen,
  19. Same thing in three different countries
  20. I don't think it would work on trolleys here. They have a plastic slide in tray in which you put in a coin or token. Pushing in the tray releases the chain on the other end. But mostly we have gone coin-free, with auto-lock wheels on the trolleys
  21. If it helps you decide; I've seen restoration 'tags' on everything from old shotguns, vintage car engines, vintage car upholstery, old buildings, especially old churches or community halls and all sorts of things even on old aeroplanes If your work is good and you are proud to stand over it, then imo, put your restoration tag on it. And keep a record of what you did on it I found an old and corroded 'rebuilt by....' tag on my vintage car engine. The company was long gone by the time I got my car but a previous owner had contacted the engine rebuilder and got a copy of the works sheets which specified what had been done. It might be the same with a saddle; in the future an owner may contact you to find out what you had re-furbished
  22. KAM is the name of type of snap/popper They come in different sizes and a multitudinous of colours The most common size is T5, which I use most of of but there are many sizes. The next main size is T16. T5 are about 12.5mm across the cap and a 5mm post. Its only good for thin leather, up to about 1.8mm thick. T16 are 16mm across the cap with a 8mm post. There are variations but are hard to get You need a special tool to squeeze down the central post on the caps A full set of several hundred T5 snaps in different colours and the pliers can be bought for under or about 15 E T16 can be bought for about 6E per 100. The same pliers tool works with them. It usually comes with the necessary parts, as seen in the picture above eg; https://www.ebay.co.uk/itm/364488348551?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749387&toolid=20006&customid=GB_14339_364488348551.146494749527~1869017347642-g_CjwKCAjw-eKpBhAbEiwAqFL0monctUkpe5DA2IkEdCAx9rn7xBA-i5-OHL4MsITycXFfb9qgPohu5xoC8bEQAvD_BwE I use them all the time on thin leather goods, like the key-ring purse or these pen cases
  23. Try asking at a general automotive supply shop for those connectors. I've seen similar in SAAB and BMW cars
  24. My NFO is quite thick, until its warmed up considerably. You'd need to thin the NFO quite a a bit, especially for the finer airbrush But there is car equipment for spraying heavier oils. There is a car under body protective called Waxoyl. Its very thick and you can get spraying equipment for spraying it on to the underneath of cars. Your compressor needs to be powerful though eg.
