Dwight
Everything posted by Dwight
  1. Welcome, WillieO, . . . Hey, . . . what you are talking about is in fact a very smart way to use your leather. Flesh side out in leather lingo is "rough out", . . . and if you have ever seen any of Clint Eastwood's spaghetti westerns, . . . in most of them (if not all) his holster and gun belt were roughout. John Wayne also had a roughout money belt he wore in a western or two. Using full grain leather with the rough side out, allows you to rely on the strength of the hair side to maintain the item's basic shape, . . . yet have it appear to be suede. You can finish suede with several different products, . . . I use Resolene in a 50/50 mix with water, . . . it will stiffen the leather at first, . . . but it can be "broken in" to about any flexibility you want just by manipulating it. May God bless, Dwight
  2. I don't remember where I got it, . . . but I understand that some of the old cowboys of yesteryear would punch a hole in a silver dollar, . . . and use it for the rowel in their spurs, . . . that way they always had 2 dollars on their person. When I looked for different rowels for mine, . . . "IKE" dollars were just the right size, . . . and you guessed it, . . . Dwight has "Ike" dollar rowels in his spurs. Hang in there LTC, . . . if they come and get you, . . . they'll probably already have me in the wagon, . . . we can chat till the lawyers get there May God bless, Dwight
  3. My only problem with doing it by pants size, . . . I had a feller one time ask me to make him a belt. i asked what size, and he said he wore size 36 Wranglers. Being a bit cautious, . . . I measured his belt, . . . and found that the hole he used most was between a 39 and 40. The 36 Wranglers had "stretched" so to speak. If I had made him a gunbelt based on his say so, . . . it would have buckled only in the very first hole on the billet, . . . if at all. That is the reason I insist on a belt measurement, . . . but if the other one works, . . . that's great too. May God bless, Dwight
  4. I actually have a 2 piece "pattern" I use. I made it so that it allows for a 4 inch additional length, and is marked for waist size. One piece is the billet end, the other the buckle end, . . . they come around together to form a pattern for the belt. I directly trace the belt blank off this pattern. I can measure the buyer's belt he is wearing today, . . . (say a 38 waist), . . . set it at the mark for 38, . . . it will lay me down a pattern for a 42 inch belt. It already has the hip curve, . . . holes punched for tongue and billet, . . . makes life easy. Guy comes in wanting a cowboy rig, . . . if he has to turn around in my driveway before leaving, . . . I can have the pattern set for him before he is on the road, . . . 600 feet away. And so far it has only had one problem customer, . . . he gained 2 inches while I was making his rig. I would imagine Jim's is similar, . . . but just make sure what you do works, . . . and when you get it working, . . . write it down, make a pattern, take copious notes, . . . so you won't forget by the next one you do. Now "YOU" may not have to do that, . . . but this old redneck would forget most anything not done in the last few days. May God bless, Dwight
  5. Although we all love leather, . . . (obviously ), . . . and other natural materials, . . . it is a given that pretty much all natural materials will soak up oil from any source, . . . and any metal firearm will have oil on it in varying proportions. Since you will not be able to see in this thing, . . . it could become a trap for oil, . . . then dust, . . . creating a bad environment for really fine weaponry. If it were mine, . . . I'd make sure the lining was one of the plastic fantastic man made thingys that does not absorb oil or other liquids. That should be a very positive protector for the contents of the bag. The alternative would be a leather only bag, . . . and hand wrap the contents with a clean rag / cover / whatever. May God bless, Dwight
  6. An inexpensive, yet useable tool I sometimes use: take a piece of steel tubing about 3 inches long (in this case, 1/8 inch tubing). Lay it against a sanding wheel, . . . sharpen the outside edges of it like you would do sharpening a pencil. Put it in your 1/4 in electric drill, . . . drill your holes. I usually do 5 or 6 holes, . . . take it out of the drill, . . . use a wire to push out the pieces, . . . Every other hole or every 3rd hole, . . . touch the tip to a block of beeswax or parrafin, . . . makes the going through a bit easier. May God bless, Dwight
  7. Hey, . . . there's one just like that one over on CASCity........... Still good looking though, . . . even on the second go around. May God bless, Dwight
  8. Your only concern really, should be sunlight, . . . and/or salt spray, . . . seeing as where you are. If your booth is out in the sunlight, you may want to use a finish with a UV blocker (Resolene is one of them), . . . and salt spray will definitely put the hurt to leather goods. Those would be my secondary concerns, . . . pilferage at outside booths / fairs / shows is my usual first concern. May God bless, Dwight
  9. I have a piece of a broom handle, . . . about 10 inches long with a round piece of wood on it's end, . . . and a piece of rubber floor mat tacked onto the round piece. I can take both hands on this baby, . . . lean my 180 or so pounds into it, . . . and it is very seldom that I do not get it to come off. I always use this first, . . . and in some cases, . . . I'll nudge the concho with a whack or two from a small rubber mallet. As a last resort, . . . I have a special pair of pump pliers that I just barely catch the outside edge with the flat lip and break them loose, . . . then to the broom handle tool. I hate seeing bent up conchos where some hooligan took them off without using any real care. May God bless, Dwight
  10. For just about any chain made, . . . they also make what is known as a repair link. You basically put it in where it is needed, then bend or peen or snap it into the desired shape or place, . . . they work many different ways. But, . . . they work. There are many motorcycles zipping up and down the streets with multiple repair links in their chains, . . . as well as chains on trucks, cars, etc. A really good hardware store will have them, . . . or maybe google them on line. Depending on "the" chain you are using, . . . you may opt to use a different style repair link, . . . but it will look uniform if you have one on each side, . . . matching so to speak. May God bless, Dwight
  11. Actually, . . . he always wears a shirt or a tee shirt under his holster, . . . just like I do. I had thought of not stitching through it, . . . but my Tippmann pulls a pretty tight stitch, . . . and I got a bit concerned about the thread laying across the back of the kydex, . . . going in and out of the adjacent holes, . . . and was a bit worried about any movement causing the kydex to sever the thread. That was the precipitating thought that made me decide to stitch it all the way through. Kydex in my slim experience with it, . . . doesn't do well with contact cement, . . . and I was afraid that slight movement could cause it to fail. I see Jim at least once a week (one of my church elders), . . . so I'll be able to update as needed. Again, thanks for the design idea. May God bless, Dwight
  12. I've never heard of any issues with silicone, . . . (other than the initial stink while drying out), . . . and I've used it for 40 years on every conceiveable project I've been involved in. Never one issue. Paint does not stick to it, . . . so I would doubt you would have any issues with stain and stuff, . . . finishes, . . . waxes, . . . and I've molded it to fit where ever needed with my right index finger so many times it isn't funny. It is a pain to get off the finger, . . . but it was always worth it. May God bless, Dwight
  13. Stitch Dex, . . . OK, . . . you got my curiosity up, . . . a friend came to me a couple weeks back, . . . needed an IWB for a Bersa Thunder 380. I had to scrounge, . . . found my one and only piece of Kydex, . . . and remembered this thread. Mine is not as good looking as yours, . . . but just for kicks and giggles, . . . I made him an IWB using your technique, . . . and I have to admit that I am far more impressed with hybrid holsters now than I was before I made that one. It is comfortable, . . . and for now we are awaiting the "show and tell" after a couple months of use. Again, thanks for sharing. May God bless, Dwight
  14. Jimbob, . . . I picked up my cowboy making from John Bianchi, . . . off his videos. Using his ideas, . . . I set the buckle so that the inside edge (where the face of the belt rubs) is even with the end of the belt (see picture). I set the tongue of the belt so it is also at the end of the belt (see picture). With a 2 3/4 to 3 inch setback to the first hole, . . . it makes the thing come together well, . . . rides good, . . . and I've never had but one complaint. I made a 55 inch gun belt some years back (it took several weeks), . . . customer took it home, . . . called and said it was too small. I adjusted it for him, . . . but always wondered how many doughnuts it took to add 2 inches to a 55 inch waist. Anyway, . . . those pictures are from the very first one I ever did (for an old uncle who as since passed on and it was returned to me as a gift after his passing) and the only thing I have added is that I use 7 holes in the belt now instead of 6 as in that one. May God bless, Dwight
  15. The question is do you want to be Neimus Marcum or Walmart? It's your decision, . . . you have to make it. But I will tell you this, . . . if you are turning out higher numbers, . . . you are turning out more flaws. The more time you spend on an item, . . . the less chance the customer will be dissatisfied, . . . and generally he'll be more "proud" of the product. I am personally a craft guy, . . . making one at a time, . . . for one person at a time. YMMV May God bless, Dwight
  16. That actually was one of the patterns that didn't pan out, . . . least not for me, . . . but thanks anyway. Still hoping for someone with a tracing that they will share. May God bless, Dwight
  17. Sometimes, . . . a guy has to know when to hold em, . . . when to fold em. I'm looking for something similar to trail boss Gil Favor's chaps in the Rawhide show, . . . pattern, . . . tracing, . . . picture, . . . anything you have to help will be much greatly appreciated. I've done a lot of leatherworking, . . . this has just about beaten me up, . . . I've tried a couple of times, wasted some precious material, . . . just can't get em to fit, hang, and feel right. Again, thanks folks, may God bless, Dwight
  18. Skald, . . . I think you very probably have the process down well enough. Your product is what is causing the problem. Put the Barges up on the shelf for making waders or something like that. Get some Weldwood Contact Cement, . . . and follow the directions fully. Coat each piece, but not "liberally", . . . just a thin but fully uniform coat. Allow it to dry. Make sure it is DRY. Next put the pieces together, . . . use a rolling pin (belts) or a small wallpaper roller for holsters and the like. Sand it flush (I use both a round and a belt sander, . . . far prefer the belt). Edge it, . . . and burnish it. May God bless, Dwight
  19. Tree Reaper has the right idea. I would first mold the pocket, half circle, pouch, . . . whatever you call it. Add the fastener and all the snaps, . . . glue and sew it to it's base, . . . making the thing all done except for the final cutting. Then I would stain the thing and get at least one good coat of resolene on it, . . . making sure it is dry as can be. Then I would cut out the lid, . . . but I would use a coping saw, . . . but that is me, . . . band saws are too fast for my reflexes. You could then touch up the edges of the cut pieces with dye and more resolene. Good luck, . . . looks like an interesting project. May God bless, Dwight
  20. You may also want to contact someone like Weaver Leather who make the cutters used on clickers. I am sure they could make one for you. If you are somewhat handy with tools, . . . buying punch ends from Tandy, . . . drilling and tapping a piece of 1/4 steel, . . . you could make your own clicker plate. Doing it that way, you could take out some or add some, . . . depending on today, . . . what you wanted to make, . . . size wise. May God bless, Dwight
  21. Most of the time when I have a dye job that went south, . . . blotchy, . . . spotty, . . . uneven, . . . etc. It can usually be traced at least suggestively to moisture. I have since made it policy that water is used in some parts of my process, . . . but never around the dying, . . . as I do not use water based dyes. Think about this: putting alcohol or oil in a jar, . . . then adding water, . . . what do you get? A stinking mess that is good for nothing. I apply that same reasoning to alcohol or oil going on my leather and adding water. May God bless, Dwight
  22. You might also want to put an extra coat of Resolene on that inside face. I'm a person given to very heavy perspiration, . . . and while my Cactus holster only has one layer between me and the 1911, . . . I don't find any evidence of moisture, . . . most of the time. When I do, . . . it's on the dust cover, . . . up near the rear sight, . . . and equally spread around, . . . I've always considered it condensation. Good luck with your project, . . . keep us updated. May God bless, Dwight
  23. If you want to take on the aggravation of trying to dye the front without touching the edges, . . . have a wonderful time. When you perfect the technique, . . . you can make big money selling a book on how to do it. If you dye the front, . . . and the edges, . . . any bleeding dye that would come from the back, . . . will also come from the edges. Long and short, . . . dye the whole thing, . . . save yourself some grief. I have yet to have a customer who even mentioned it, . . . much less wanted it dyed just on one side. May God bless, Dwight
  24. Probably told to you by some tree hugger trying to sell you on the water based stuff. No, . . . it does not bleed if it is properly applied, . . . properly sealed. The single, one, and only bleeder I ever had was from a bottle of the old Tandy water base stuff. I made myself a shoulder holster for a .380, . . . wore it to a funeral, . . . came home and threw away the tee shirt it bled all over. It was their black dye from 5 or 6 years ago. May God bless, Dwight
  25. PM sent May God bless, Dwight
