Dwight
Everything posted by Dwight
  1. If you make a wooden form the shape of the inside of the quiver, . . . vegetable tanned leather can be wetted, stretched, and formed to the shape of that form. Vegetable tanned leather can be shaped into some unbelievable shapes, . . . decorated, . . . and used for all sorts of things: bags, boxes, purses, holders, etc. Actually making the leather part of the quiver is probably one of the easier parts of replicating that rig. May God bless, Dwight
  2. In picture 9130379, the one in the upper right hand corner, a billfold with flowers (top row, 2nd picture) Bottom row, right hand picture, the belt / key case. I would be interested in those two, . . . but not in the rest if you decide to break up the group. May God bless, Dwight
  3. Electrathon is correct, . . . you will have color issues later on if there is any wear or flexing of the stitches. Belts for example, . . . will lose some of theirs, . . . but most holsters don't lose a lot of it. It depends on what you are using it for. May God bless, Dwight
  4. Ahh, . . . yes, . . . welcome back kind sir. Doctors can be good, . . . really good, . . . or bad, . . . or really bad. I've had all four, . . . and like you related to the old ticker. Don't take no for an answer from them, . . . I did and it could have turned out really bad. Anyway, though, . . . welcome back, . . . keep grumpin and hand stitchin, . . . May God bless, Dwight
  5. Having worked as an electrician for almost 50 years, . . . I can say with some experience that you need to get your friend involved. He will be the key to getting the right one done correctly. The reason I say that is that my tools, . . . another electrician's tools, . . . and your friend's tools will not be the same, . . . because of the type of electrical work each does. I was a maintenance electrician for the most part, . . . and carried upward of 20 pounds on my right hip in my prime days. That included at least 4 screwdrivers, lineman pliers, dikes, BX stripper, needle nose, wire stripper, screw starters (2), open / box end wrenches (1/4 through 5/8), roll of 3M black tape, roll of rubber tape, hammer, spike, wiggy, flashlight, and some few things I cannot think of right now. Generally, . . . the pouches I found at places like Walmart, Graingers, ABC Electric, were all designed by some jaybird accountant who worked in a leather company, . . . and was trying to sqeeze every bit of profit out of each pouch. Enclosed is a little sketch of my favorite pouch I ever had. Bought it at an air conditioning part supplier in about 1970 (?) and if I remember correctly, . . . paid $18 for it. That was expensive then, . . . as I was making just over $3 an hour, . . . about $2.40 take home pay. Anyway, . . . good luck, . . . have fun. May God bless, Dwight
  6. Your period perfect holster is found on page 31 of a Tandy Leather book about making holsters, . . . book # 40. The pattern is on page 31. Keep in mind that period perfect for 1912 would have been a revolver, . . . and it would have been carried with the muzzle pointing down. The Jackass rig carries the weapon with the muzzle pointing directly behind the carrier, . . . and is not really a "novice friendly" design. That design didn't make it's debut until 1970 or somewhere thereabouts. In fact, . . . shoulder holsters in general are not novice friendly. Getting one done and done right takes experience, but this particular pattern will be a real good one to learn on. Let me also suggest you use some of the heavy duty naugahyde from some one like JoAnn fabric (about 18 bucks a yard, . . . 45 inches wide, . . . 1/2 yard will give you plenty to play with) as it will simulate what you need, . . . you can make minor changes to match your model, . . . and you won't be butchering up a bunch of leather at $6 a sq foot. May God bless, Dwight
  7. Looks to me like you are doing it right. That is more or less my process, . . . 24 hours. You also mention an oven/dry box, . . . and there was a thread on here a few months back, . . . I glanced at it, . . . but didn't get involved because I don't use anything but a fan and the sun (wood stove in the winter). One of the things I hope you don't find out the hard way, . . . but dyeing a holster while there is still excess moisture is a recipe for spotty, . . . blanched, . . . ugly junk that goes into the "I should have known better" bin and the profit takes a serious hit. Same for the oil, has been my experience. May God bless, Dwight
  8. That is very similar to a Galco Jackass rig, . . . you can google the two words with shoulder holster, . . . should get you some pretty good pics. Most important thing needed, . . . what kind of weapon? And will this be a prop type holster for a costume, . . . or the real deal where someone's life might depend on it being done right??? All of this makes all the difference in the world for the pattern. May God bless, Dwight
  9. I have to admit to having never seen that problem with my Tippmann Boss. But, . . . there is help for you. Get on line, go to the Tippmann website, get their phone number. When you get them on the line, explain to them you have a question for Ben. If anyone on the face of the earth can walk you through it, . . . he should be the guy. But, . . . first let me tell you how I backstitch with no problems: 1. First I make the stitch I am going to backstitch over, . . . and completely raise the needle up out of the leather to the top of the stroke. 2. Gently squeeze the handle, releasing the foot just enough to be able to pull my work back to me the length of the stitch. 3. When it is approximately in position, . . . ease the needle down into the stitch hole. 4. As the needle begins going through, . . . release the handle, . . . allowing the foot to go down flat. 5. Continue with the stroke completing the "backstitch". 6. I then will backstitch two more holes, . . . giving a total of 3 backstitched holes to prevent the thread from coming undone. Again, this is my proceedure and I do not have any problems with it. May God bless, Dwight
  10. Dwight
    IMG 4751
    As others have said, . . . great work. May God bless, Dwight
  11. Not meaning to slam anyone, . . . but Law Enforcement Targets have always done well for me, . . . went out of their way a time or two, . . . and their phone reps are knowledgeable, friendly people. Plus, . . . I've found no one, . . . zero, . . . who beats their prices. May God bless, Dwight
  12. Good job, Lobo, . . . that's the way I do mine, . . . like you said, . . . a little practice and it doesn't take long to do one. May God bless, Dwight
  13. Since you are treading in uncharted waters, . . . if I were you, . . . I'd look at one of the super special undershirts sold to the military in the sandbox. Most military suppliers (such as Quartermaster.com) would have them. You should have enough material there to make several, . . . couple for practice, . . . couple for production. Might even give someone like JoAn Fabric a shout, . . . if you get a knowledgeable sales person, you would probably make out. If not, . . . wellllll................. May God bless, Dwight
  14. I suppose you could, . . . I've never done it, . . . But you cannot mold most of the harness type leather I've seen the way you can veg tan, . . . nor stamp it as well, . . . nor edge it as well, . . . nor burnish it as well. Plus, . . . if it is properly done in veg tan, . . . there is a better than even chance you will "outgrow" it one way or another, . . . long before you wear it out. Post pics of your rig if you decide to do it, . . . I'd be curious to see one. May God bless, Dwight
  15. Email sent
  16. If you are going to do a 2 layer holster, . . . why not leave the inside natural? Dip dye the outside pieces, . . . but leave the liner natural. I occasionally do a black cherry holster, . . . . and I think that would really look awesome. Leaving the inside natural, . . . with only a coat of neatsfoot oil, . . . there should be nothing to harm those grips. And if I may, . . . I'm a Vietnam vet, . . . and if I owned that handgun, . . . you can bet your last bippy that I would be darn seriously unhappy if anything happened to it that could have been avoided by someone taking a little extra care. May God bless, Dwight
  17. Good looking work, . . . May God bless, Dwight
  18. You didn't say what the project was, . . . which could make a huge difference in what is used for final finish. But in answer to your main question, . . . yes, . . . apply oil before the final finish. The only thing one should ever do after the final finish is perhaps apply a wax / polish, . . . but again, . . . that is only like polishing a pair of shoes, . . . something done long after construction is finished. My personal favorite is Resolene. It's a water based acrylic finish that is fairly hard, . . . has a good gloss, . . . and can be easily applied. I use a cheap 1 inch bristle (pig hair) brush, . . . stay away from the nylon ones, . . . mix up the Resolend 50/50 with water, . . . wet the brush and begin applying the finish, . . . brush up / down / left / right / all different directions, . . . you use enough to work up a foamy froth on the leather, . . . hair side and flesh side. Once you get the froth built up all over one side, . . . go to the other side, . . . (oh yeah, . . . wear a latex glove on the non-brushing hand, . . . and keep your fingerprints off the outside, . . . pretty part of the project, . . . hold it by the buckle, the inside, etc.). Froth up the second side (for holsters, . . . I always do the inside first, . . . then stick my fingers in there to hold it). The trick is to keep brushing that froth until it literally goes away. Then hang it up to dry. It takes a bit of practice, . . . but it gives a really nice finish, . . . and you can do more than one coat, . . . just don't get carried away with it. There is a level that gets too thick and it will crack and break. May God bless, Dwight
  19. Your holster is called a "roughout", a style made famous by Clint Eastwood in his spaghetti western movies. I've made a few, and they are fun. I normally do not put a piece on the front in a roughout, but that is just my way. I normally do put them on the others, most of the time. It can be both a piece to stiffen the front of the holster, . . . and it can be a billboard for decoration, . . . tooling, . . . etc. Like chiefjason said, . . . I cut, . . . form, . . . and then dye my holsters, too. Just a little nugget for you, . . . if you are making a pancake, . . . do all the sewing for the leading edge of the holster, . . . wet form it around the weapon, . . . gently remove the weapon and let it dry. When it is fully dry (no less than 24 hours later), put the weapon back in the holster, clamp it tight with your left hand, and using your right hand, mark your sewing lines for the trailing edge of the holster (around the trigger guard, barrel bottom and rear slot). This will give you a good tight sew line if you do it right. Trying to guess where the stitches should go has about a 1 in 10 success factor. May God bless, Dwight
  20. There are two schools on dye and the liner, . . . the A school dyes the whole belt (I'm there, . . . a "dip" dyer guy), . . . and the B school who leaves the liner natural. I personally like both ways, . . . but my process is easier for me & quicker, . . . otherwise, I too would be a B school guy. May God bless, Dwight
  21. Look on Craigs list, . . . Ebay, . . . and used furniture stores, . . . don't forget yard sales. I've seen any number of super sewing machine tables given away to get rid of them, . . . in fact I have one in my living room that meets that criteria. You don't need castors, . . . you need 2 wheels about 3 inches in diameter. Put them on one end or the other only. Then tip up the other end and roll it where you want to leave it. If it is on 4 casters, you will have to buy the locking kind, . . . otherwise the thing will roll all over the place while you are trying to use it. The locking kind are in the neighborhood of 6 to 12 bucks EACH. With only two wheels, . . . the other end will hold it in place while you use it. May God bless, Dwight
  22. As a soldier, I always carried my bayonet or kabar on my left suspender, . . . upside down, . . . Still carry my hunting knife that way, . . . I like the way you tucked it into the sheath with two straps, . . . if one fails, the other should catch it. May God bless, Dwight
  23. Leather is no different from any other business. Go where your talents and interests lay. Above all, consider leather work as a custom business, . . . not a retail business. For now, . . . I would look to your buds from the renfair, . . . what would they need? What would they like? Also, you may put your work on Ebay, . . . I've sold several pieces through them, . . . all satisfied customers, . . . and, . . . uhhhh, . . . yeah, . . . I spent all the profit. Look for renfair forums, . . . showcase your work on them, . . . make sure folks know you are available to do work for them. You are already one leg up on most of us here, as we have other pursuits, . . . mine is holsters and gun belts for the concealed carry crowd. May God bless, Dwight
  24. My alter ego is as the Centurion of Capernaum and I had to make armor for "him". I used 12 oz vegetable tanned leather from Tandy's for the breast plate, back plate, cuffs, skirt, and shin guards. Vegetable tanned leather can be wetted and formed to just about any shape you would like (within reason) and armor works out real well with it. I first made a full sized replica of my upper body, . . . using a 6 foot 2 x 4 on a stand, . . . several pieces of 2 x 12 for the chest pieces, . . . took a smaller tee shirt, put it on the frame, . . . stuffed it full of old rags to get the "body shape" needed to make my armor fit me. You will need to be careful with the temperature, but in holster making, . . . you can make the leather "hard" by force drying it under heat. BUT, . . . remember that the MAXIMUM temperature is 130 degrees farenheight. An old fashioned trick that also works is to dip it in liquid parrafin or beeswax. Tricky, . . . but again it makes it very hard. I was fortunate when I was doing my armor to have a pretty good coach, . . . be sure to "round out" the neck and arm holes like the lip on a bowl, . . . it seriously prevents chafing, . . . and make sure the holes are big enough. Personally, . . . I go to Jo Ann's fabric and buy their naugahyde for patterns like this. Works really good I think. May God bless, Dwight
  25. I would suggest you simply stitch it up both sides (I'd do machine stitching as there is a LOT of sewing there) and burnish the edges just like it was a belt. That is how I did a rig for a friend of mine. He loved it, . . . still uses it in competition shooting. It had suspenders, a duty belt, pouches & sheathes, . . . all sewn and burnished where there were two layers or more. Non burnished edges look raggedy, unprofessional, . . . and as though they were imported by Walmart from west of Honolulu. May God bless, Dwight
