Dwight
Everything posted by Dwight
  1. I know this is different from what you described . . . but this is how I make a minimalist wallet with money clip. Please note that I don't have a beautiful picture . . . just my original sample . . . My last customer for this brought his very similar one that was seriously falling apart at the seams . . . and he wanted it replaced if possible. His daughter had bought the original one and he just wanted to keep that style because of her tie to him. His was 15 years old . . . May God bless, Dwight
  2. Actually . . . I make a similar sheath for a lot of my friends for our cell phones . . . and it could be easily redone for a knife. Don't bother with the outside piece of leather . . . just make the back piece long enough . . . and the interior wide enough . . . that you can fold the back strip down inside the sheath . . . between the knife and the front of the sheath. That will also allow you to fully carve and / or decorate the front of the sheath with whatever stamping or carving would suit your fancy. I ride my zero turn mower with my phone in such a case . . . it stays put . . . May God bless, Dwight
  3. These folks . . . https://www.knudsenhats.com/good-bad-ugly . . . have what they claim to be a correct version on their website. For sale of course . . . May God bless, Dwight
  4. Thanks, Chuck . . . I sat and pondered white or black stitching . . . finally decided I'd do it white . . . if he wanted it black . . . he can come down to the house and dye it to suit himself. But after seeing the white . . . I think it'll stay that way. Thanks for the good words, Bladegrinder . . . May God bless, Dwight
  5. I had similar problems with some of my holsters . . . a friend suggested that I give it a light coat of neatsfoot oil . . . on the hair side only . . . allow it to rest for 24 hours . . . then dye the project. It worked like a super champ . . . I do everything like that now . . . VERY seldom have a dye problem. I do however . . . dip dye about 99% of my work . . . and use a brush or dauber for the rest. May God bless, Dwight
  6. Thanks for the good words . . . the whole belt was first swivel cut and hand stamped . . . then I got my really little brushes out . . . and hand painted with Feibings black dye . . . all the very small areas surrounding the oak leaves and the acorns. The two ends were then dyed with a small dauber . . . the two pieces were then glued together with Weldwood comtact cement . . . sewed . . . two coats of Resolene . . . May God bless, Dwight
  7. Thanks, Pastor . . . for the kind words . . . Actually that was not done with an embossing wheel . . . it is a little 10 inch or so piece of clear plastic that has the ridges that can be pressed into the dampened leather . . . giving the outline of the impression. Then get out the swivel knife . . . mallet . . . stamping tools . . . and dedicate about 3 hours of your life and a pot of coffee . . . plus a half dozen little chocolate covered doughnuts to the process. I'm not really very good at stamping . . . but I was happy with this one. May God bless, Dwight
  8. A number of years ago I bought an acorn and oak leaf belt embossing pattern from Tandy . . . figuring I would make that belt for myself. Fast forward 20 years or so . . . decided to make it for my son's birthday . . . plus I cleaned up a Ruger .22 pistol and holster that both went through a house fire. These will be his birthday presents . . . May God bless, Dwight
  9. If you have a small piece of marble . . . put it on the table . . . and put a couple pieces of scrap leather under what you are punching. Wood is not good as eventually you will have cuts in it that will cause your punch to cut ugly holes . . . plastic cutting boards will destroy your tool . . . teak cutting boards are mainly for salmon, bass, and bluegill (just kidding) . . . they seriously should not be used with your tool. Use the leather . . . when you think you are pretty close to going thru . . . tip it over and see . . . that is exactly what I've done for 20 some odd years . . . works great. May God bless, Dwight
  10. Absolutely a nice job Jarhead . . . but me and Doc are a lot alike. It would take me all of one morning to have that place looking "otherwise" to squared away. My storage idea is while I'm looking for item A . . . I'll see B, C, and D . . . then tomorrow while looking for B . . . I'll remember it's with C and D . . . so if I find any one of them . . . B will show up. Then I only have to remember what the heck I did with A . . . It's worked for me for 50 some years . . . why change now?? May God bless, Dwight
  11. I made a plain one several years ago for a Bersa Thunder . . . as my hands are long and skinny . . . sure helped on the grip. How did you attach your edges together? I laced mine with really thin thong material. And as you can see . . . it was destined to be functional and not necessarily a beautification process . . . lol. May God bless, Dwight
  12. The dye job you get also depends on how you do it. The three levels of dye depth are airbrush . . . daub/swab/etc . . . or dip dye. I won't waste good leather by airbrushing dye on it. If you do a belt or holster or purse that way . . . and if it rubs up against something fairly heavily . . . it'll scrape that leather and the interior leather will show thru every time. Daub / swab / etc generally will give a "non even" coat . . . unless you go over it several times. If you want even and deep dye penetration . . . dip dying is the only way. Mix your dye 50/50 with dye reducer . . . dip it . . . wipe off any dripping excess . . . and lay down to dry. Hanging it up will allow the dye to migrate from the top to the bottom of a holster or purse . . . and even worse on a belt. That will give you an uneven color from one end to the other or one side to the other. It took me a couple years to finally figure this all out . . . and even though I've heard some speak to the "savings" they get on the amount of dye used . . . I just chalk it up to being cheap . . . and quite honestly . . . producing a cheap product. May God bless, Dwight
  13. I'm not particularly a dog lover . . . but I could feed her some kibbles and laugh doing it. May God bless, Dwight
  14. Thru the years . . . I've never found any veg tan leather that really dyes great unless I do one little thing to it first. I give it a light coat of neatsfoot oil first . . . and on the hair side only. A 1 inch or so bristle brush dipped and stroked across the leather until it is all coated evenly . . . and the emphasis is on a LIGHT coat of oil. Then the dyes all seem to be much smoother and more even. The one exception to this is black . . . I don't oil before I dye black . . . black dyes black . . . period. I then buff the heck out of the black . . . and oil it then. All of them then get at least 24 hours afterward for dying . . . and another 24 for finishing. Like Tsunkasapa said . . . deglazer is worthless for virgin veg tanned leather. Just another product you buy that is never needed or useful. May God bless, Dwight
  15. Yep . . . I make a lot of mine . . . those look real good . . . personally like my .22 auto for copperheads . . . May God bless, Dwight
  16. If the holster is an IWB . . . I'd probably use it . . . OWB . . . it won't work. IWB relies a lot on the friction created by the human body and the belt . . . so even if it is a bit loose thru the molding . . . body pressure might make the difference. Plus you could always just run your stitch line a tad closer. May God bless, Dwight
  17. Best way is to put said gun in a sandwich or freezer bag . . . wrap it in the leather for the holster that is the next thing to sopping wet. Stick it in a vacuum bag . . . turn on the vacuum pump . . . use your fingers to mold it as tight or as simple as you and your customer want. That's how I do all my holsters. May God bless, Dwight
  18. Looks like someone is planning on having a lot of fun. May God bless, Dwight
  19. I have two steel wire brushes . . . one standard size like painters use . . . another about the size of a toothbrush. That toothbrush size gets used a lot . . . can't recall when I used the big one last. Both work great . . . would not use anything else. May God bless, Dwight
  20. My Tippmann Boss will also sew pretty much that thick. In over 20 years . . . only had one job that needed that thickness . . . a very special .22 pistol holster . . . it was for a handgun with a scope on top of it. I used the machine to punch the holes . . . then hand sewed the 35 or so stitches. It was a fun project . . . but I'm sure glad I have never had to make a bunch of them. Now however . . . with the Cowboy . . . it would not be as hard. May God bless, Dwight
  21. I agree completely. Clean em up . . . inspect em . . . sell em. May God bless, Dwight
  22. If blue dawn dish soap won't take it out . . . my guess is you are out of luck . . . but I'd just bury it for a week in a box of baking soda first. That may do it . . . if not . . . dawn and hot water . . . will probably deface the leather some . . . but some oil back on it and massaging it . . . you might get it back. I have an outdoor cat for very similar reasons. May God bless, Dwight
  23. It is not glue . . . it is contact cement . . . he folded it . . . it stuck . . . contact cement my friend. May God bless, Dwight
  24. Actually the Boss . . . is only 1000 bucks brand new today. There is not a sewing machine out there for double the price that will do everything it will do . . . unless you steal a used one somewhere. I did belts and everything on mine for 20 years . . . wasn't always happy with the cowboy rigs . . . especially when they were of the "jumbo" size . . . but they paid the bills . . . May God bless, Dwight
  25. Honestly . . . if you used good contact cement . . . applied properly . . . that would probably work. However . . . and this is just a "ME" speaking . . . I'd probably stitch it with some bright white stitching just to frame it. But in answer to your question . . . I'll sometimes take a piece of veg tan that is on the stiff side . . . lay it hair side down . . . and curl it up over a 3/4 inch wooden dowel and pulling it . . . curl it over the dowel all the way down. With a long enough dowel . . . it can do a fairly large piece. It loosens it up a bit . . . makes it a lot more flexible. I especially do that for every belt I sell that goes out of this shop. Most are double layer . . . and just that one treatment makes it feel like a belt you have had for months. May God bless, Dwight
