Dwight
Everything posted by Dwight
  1. If you cut the belt blank, . . . then roll it from end to end around a 3/4 inch dowel, . . . flesh side inside, . . . you will be amazed at how soft and pliable they become. My belts all get this treatment before I pass them on to my customers, . . . everyone appreciates it. The amount of oil you have to put on a belt to "soften" it, . . . will also ruin it. May God bless, Dwight
  2. Years ago, HondoMan, . . . I saw your problem. I gave up on Edge Coat, . . . instead, I went in the "edge dying" direction. Didn't take long, . . . decided on ending that relationship as well. Now I just burnish a little harder, . . . using either a Dremel tool, . . . or an electric motor I've outfitted with a burnishing wheel. It darkens the leather while it polishes it, . . . and I get a really good looking product, . . . without the hassle of doing the edges a separate color. May God bless, Dwight
  3. I have a BSBA, . . . have never had any problems reading and understanding cursive, printed matter, union contracts, legislative mumbo-jumbo, etc. But my friend, . . . quite honestly, . . . I have read your post several times, . . . and still have no real clue as to what you want to accomplish other than a strap will be sewn to the front, sewn to the back, secured to the side, . . . and finally attached to a D ring in the back. If you were to include another 2000 to 4000 words (picture is worth a thousand words), . . . OR, . . . 3 or 4 pictures that actually show what you are doing, . . . one of us may be able to help you out. May God bless, Dwight
  4. Actually, . . . MikeRock, I've been using mine for over a year now, . . . never a problem with it, . . . but that does sound good for any long term shut down we might do. May God bless, Dwight
  5. For years I have used the pint can of Weldwood contact cement for my "go to" container. It sits nicely wherever I needed it to be, . . . I could use any of my brushes with it, . . . and it sealed somewhat fairly well. My problem was it didn't seal well enough, . . . and I found myself having to add thinner to the liquid as it got thicker through evaporation of the solvents. Tried something different, . . . figured I had nothing to lose. Poured it into a Skippy Peanut Butter jar (creamy at that). One of the best tricks I've learned in a year or two. The lid fits great, . . . solvent doesn't boil out, . . . if I get any on the sides, it don't stick and / or build up, . . . it all slides back down into the liquid, . . . I can tell at a glance how much I've got left, . . . and all my brushes fit the mouth of the jar. Just a tip I'm passing along to any and all who can use it. May God bless, Dwight PS: Buy the jar, . . . feed the peanut butter to the squirrels if you don't like it, . . . but keep the bottle. It's well worth the price of the peanut butter.
  6. Well, honestly, . . . I had to go check mine, . . . and I was sure I was right on mine. It has a thin strip of leather working in place of the bias tape on fabric, . . . it wraps around the edge, . . . showing on both sides, . . . stitched all around the outside of it. I've done similar, . . . not as intricate, . . . on a bag I made for a lady once, . . . spent hours and hours on it and gave it to her for a wedding gift, . . . she dropped it off at a flea market. Just don't get discouraged, . . . it can be done with a good sewing machine and a bottle of Weldwood contact cement. May God bless, Dwight
  7. It is a common technique in fabrics, . . . it's called bias tape, . . . this is just the leather version. It will of course, . . . have to be contact cemented or glued together before it is sewn, . . . otherwise it would run away and look some kind of ugly. Go to a Joann Fabric shop and let one of the ladies in the sewing machine dept show you how to to it. May God bless, Dwight
  8. I wanted a small clicker die for a key ring tab, . . . Weaver Leathercraft made it for me for less than $80 if I recall correctly. I would never have cut out that many by hand, . . . you can be assured of that, . . . the clicker "does the job", . . . May God bless, Dwight
  9. Great looking holster, . . . Sig 365 is one big pocket gun in my estimation. My son has one, . . . and outside of my Vietnam jungle jammies, . . . ain't got no pockets that big. May God bless, Dwight
  10. Used to stitch, . . . went to staples, . . . punch holes, . . . bend over with pliers, . . . no problem. May God bless, Dwight
  11. The worst thing you will wind up with is a good lesson, . . . so go for it. I'd wet the bottom half of that until it was some kind of soaked, . . . then take my thumbs and flatten out the outside piece. It will take a while to get it "flat" flat, . . . but if you mess with it a bit it will get to where you can hand sew it. Then you finish getting the rest of it wet, . . . allow the whole thing to dry down to a good "case" and re-do the molding. Then put it in front of a heater, . . . or in a cool oven, . . . keep it below 140 degrees, . . . the molding should take, . . . and you will have the sheath you wanted. May God bless, Dwight
  12. Absolutely NOTHING you will do will STOP leather from attacking any metal it comes into contact with, . . . with the exception of Gold. All others will at one degree or another be attacked by the chemicals used in the tanning processes. Copper is at the top of the list for getting funky fast, . . . iron right behind it, . . . then steel and then brass and aluminum. You can mitigate it to a certain degree with various coatings, . . . but just remember that you are not going to STOP it altogether. May God bless, Dwight
  13. The 50/50 beeswax and neatsfoot oil is an old, . . . old, . . . recipe from what I've been told. I got it from the Pacific northwest, . . . believe the lady said her grandfather or father gave it to her. Been using it for over 10 years, . . . no complaints so far. May God bless, Dwight
  14. I think if this stays here long enough, . . . someone will chime in with "You can also use coffee to stain leather, . . . don't ask me how I know". May God bless, Dwight
  15. Since I have a 6 inch jointer, . . . I can make boards any thickness I want. I would build a "pocket" in the top of the work bench that the stone would slide down thru with maybe 1/8 of an inch clearance left/right and front/back. That pocket would be the 3 inch deep, . . . depth of the stone, . . . and the bottom of it would be bolted solid up thru spacers that make the pocket 3 inches deep. I would also leave a 1 inch or so hole at each end, . . . in the center of the stone, . . . just in case some day I need to push it up and out of the pocket. May God bless, Dwight
  16. bcraig, . . . Yes, . . . rougher side is the flesh side and the smoother side is the hair side. Avoid buying any leather that has a "really" rough back side to it. Generally it is not worth taking home as you will have to sand all the loose pieces off of it yourself, . . . and they in general do not produce good or good looking projects. The holsters you see in the enclosed pictures are good examples of the lines and shapes I use for my business. But to answer your question with a number, . . . there is always at least 1/2 inch of leather between the stitching on the holster and any belt slot I would cut. The two holsters you see here, . . . they are closer to one inch of leather. The holster with the black outside is a 4 layer holster as I told you about earlier, . . . 4 layers of 3/4 leather, . . . two layers bonded together for the back, . . . 2 layers making up the front. You can see the inside picture, . . . and count the 4 layers, . . . 2 black and 2 natural. The other holster shows you the flat back that would be made if you use the method I described earlier where you form the two outside layers, . . . let em dry, . . . then bond them with contact cement. ( That particular holster is made of one piece in the front one in the back, . . . it is 6/7 oz leather. ) You then insert lay the gun down on the back, . . . outline it with contact cement, . . . put contact cement on the corresponding places for the front, . . . glue em together, . . . stitch it tight, . . . cut the slots, . . . voila, . . . you have a holster. Using the 4 piece method produces a holster that is rigid beyond most folks wildest dreams, . . . that particular holster could knock a person out if thrown at their head with any force at all, . . . it is that rigid. Single layer holsters are just easier to make, . . . that is why you see so many more of them. I noticed JLS's post, . . . and he is right, . . . that is a bunch of cash for questionable leather. If you are only making a holster for a Bersa Thunder .380, . . . decide which way you want to go, . . . I'll see what I have here, . . . may have just what you need. Just PM me and let me know. May God bless, Dwight
  17. The holster you want to make is somewhat tricky, . . . especially with the laser, . . . BUT, . . . using 2/3 leather, . . . glue two pieces, . . . flesh side to flesh side, . . . for the back. Wet form another piece to the Bersa, . . . hair side down, . . . carefully form it as close to the Bersa as you can. Let it dry. Place a piece of saran wrap over the last piece you did, . . . then carefully form another piece, . . . flesh side down, . . . let it dry. Contact cement the last two pieces together, . . . sew the whole thing together. THEN, . . . dip it in water, . . . wrap the gun in saran wrap, . . . and final form it to the weapon, . . . cut the slots, . . . enjoy. May God bless, Dwight
  18. I have done this for any number of projects, . . . holsters, . . . cheek risers, . . . platforms, . . . etc. I always use solvent based Weldwood contact cement. The most important thing to remember and do here, . . . take a wire brush to all the pieces on the hair side, . . . scrub it real good so it is scuffed up enough to hold the contact cement and you will be all right. You do want to be in a place with good ventilation, . . . I just open the door if I'm doing a serious bunch. You can't see the end of the shaped piece in the picture, . . . but it has at least 5 layers in it, . . . contact cemented into shape, . . . then final formed on a big disc sander and a small belt sander. May God bless, Dwight
  19. The difference between 6/7 and 8/9 is at the very least 1/64th of an inch, . . . and at the very greatest, . . . 3/64ths of an inch. You can have some success adding 3 oz leather, . . . but not much of anything any thinner. Remember that each "oz" is 1/64th of an inch, . . . take a pair of calipers to the store where you buy the leather, . . . measure the pieces and get one of the thicker ones. That would be my solution, . . . other than using the 6/7 an using several coats of resolene to stiffen up the final product. May God bless, Dwight
  20. Make him a double layer 4/5, . . . it makes a pretty holster, . . . and a tough holster. Honest to goodness WW2 holsters I have seen were all in the 8/9 weight, . . . and were unlined. They only had an oil finish, . . . some were dyed black, . . . most were some shade of brown to darn near black. None had any finish other than oil from what I could tell. May God bless, Dwight
  21. Why do you want to put a smartphone in a wallet?? Phones belong in a pocket, purse, or phone carrier, . . . wallets are for money and credit cards. May God bless, Dwight
  22. In a one word answer: no. I have not done this, . . . but leather is very similar to soft wood, . . . your bit MUST BE very sharp, . . . recommend BRAND NEW. But then again, I've never done a belt like that If I did, . . . I'm a lazy rascal, . . . and I just will not take the long, rough, hard, intensive road for anything, . . . just my nature. I'm constantly trying ways to make things easier for this 74 yr old coot, . . . and after giving it some thought, . . . looking at my available tools, . . . that was the idea I came up with. It will not, I am sure, work on anything thinner than 7/8, . . . and that belt looks more like 11/12 leather. I would also cut the blank as high up on the side of leather as I could get. Leather nearer the spine tends to be denser and harder than belly leather. If it is a 1 1/2 inch belt, I would cut my blank probably 2 1/2 inches wide, . . . soak it good and when it gets back to a good "in case" do the stamping in the middle 1 1/2 for the belt, . . . then lay it out to dry. It will harden as all veggie tan does, . . . and then you glue it to the plywood and go for it. Knowing me, . . . I'd take a 12 inch piece of leather and try this first, . . . get the knack of doing it by practice, . . . and then hop on it. I think it would make a fantastic looking weight lifting belt or something like that. May God bless, Dwight
  23. Tandy often has some sheep skins with very short fibers, . . . like maybe 3/8 inch, . . . I've gotten them for projects, . . . and they were not that expensive as I recall. Been a while, . . . though, . . . There is also a synthetic sheepskin, . . . I''ve seen a few of them, . . . they would work. May God bless, Dwight
  24. Being an old wood worker, . . . I would stamp the letters in the belt blank, . . . then rubber cement the leather to a piece of 1/4 inch mahogany plywood. Then I would clean the bottom of my router off real clean, . . . put in a 1/4 inch bit, . . . and hog out the biggest parts of the areas, . . . then switch to a 1/8 inch cutting blade, . . . finish up the cutting out of the letters. Up at the top and down at the bottom where the straight cuts are, . . . I'd use a wood chisel, . . . it makes really nice straight cuts that are super clean. Pull the leather off the plywood, . . . and like Hildebrand said, . . . glue it to a contrasting backer, . . . sew the edges, . . . and you are in business. May God bless, Dwight
