Dwight
Everything posted by Dwight
  1. Leather breathes, . . . and if water gets in it, . . . eventually it will dry out. Some synthetics can hold water and cause the knife to rust. Seeing the client is looking to protect his knife, . . . kydex is the best choice for THAT, . . . even if you cannot sew it. AND, . . . it can be riveted with only a few rivets. May God bless, Dwight
  2. Kydex would be my first choice, . . . I don't like working with it, . . . but it makes a good product when it is done. May God bless, Dwight
  3. Fredk's experience has not been the same as mine. Resolene is an acrylic finish, . . . in a common word, . . . plastic. If it is applied correctly, . . . it will totally cover and encapsulate the product. Think of putting something in a plastic bottle, . . . sealing it up, . . . then try to get it wet or dry, . . . See the problem??? If you want to condition and have it work 99% of the time like it should, . . . when you cut your blanks, . . . or at the latest when the item is getting ready for dye, . . . give it a light coat of neatsfoot oil with a bristle brush, . . . I only coat the hair side if I can reach it, . . . if not, where I cannot, I'll coat the flesh side, . . . but it is done sparingly because the flesh side will soak up the oil really quick and will take a lot of it. This will also tend to smooth out the color of especially light browns like Feibings Saddle tan. May God bless, Dwight
  4. Here is my brown one and my black one. The pictures probably tell you ore about it than I could write in a week. May God bless, Dwight
  5. I'm with Frodo, . . . two layers of 7/8 oz, . . . sometimes I'll shave one down so that the overall thickness is .200 or so. As far as the overlap, . . . you want the piece in your right hand to go under the part in your left hand, . . . and slip into a loop on the back of the belt, . . . so it stays even when you cinch it up. Cheap skates making Ranger belts leave the loop off of the back thinking they are saving something, . . . and it ruins the whole look of the belt if the wearer has it in the first or second hole. Looks like a leather tow rope holding his gut in. May God bless, Dwight
  6. Actually the loops and the belt are a very small part of the picture. They are much more for allowing the holster to be hidden by tucking in the shirt around the holster. May God bless, Dwight
  7. I kept trying to figure out why my sound wasn't working. One way or another, . . . I kinda shut it down in the late evening when the Mrs is in bed, . . . thought I'd really done it this time, . . . Finally figured there must not be a sound track. Anyway, . . . I figured it out without the play by play. Thanks, may God bless, Dwight
  8. Ummm, . . . no sound . . . May God bless, Dwight
  9. John Bianchi, . . . professional holster maker of some 60 years or so, . . . often used a bath of neatsfoot oil to finish his holsters, . . . and nothing else. He did a set of VHS videos featuring a western rig and it was done that way, . . . I like it myself sometimes. Otherwise, . . . Resolene is my finish of choice. May God bless, Dwight
  10. Tandy sells acrylics that have always done good for the few projects I've painted. Just remember, . . . nothing painted will always stay pristine, . . . I always go over my paint work with Resolene, . . . and I go over the painted part a couple extra times to protect the art work. Sadly, . . . using the leather object will eventually wear the finish, . . . and can wear it off the inside. In the case of a clutch purse, . . . holster, . . . or other such piece, . . . it can get wet from the inside, . . . but unless it gets fully soaked, you will usually be alright, . . . the finish itself tending to try to retain the shape. Personally, . . . I always seal the whole project, . . . inside and out, . . . and Resolene is my product of choice. EDIT: The one exception to sealing the inside is if I use a soft liner such as suede or pigskin. May God bless, Dwight
  11. If we lived close enough we could make a good living together, . . . I'd sew, . . . you'ld tool, . . . and we'd share the profits. Seriously, . . . really good looking work, . . . far, far beyond my present or anticipated skill level. Making holsters, . . . CCW belts, . . . that's my game. May God bless, Dwight
  12. I use a 1 inch wide Harbor Freight bristle brush, . . . they're about 50 cents each there. Never had a problem in over 15 years. May God bless, Dwight
  13. Mark, . . . do yourself a favor and when you remake this, . . . undercut the back side below the mag ejector button, . . . other paddle holsters as well as yours, . . . are only a nudge away from a lost mag, . . . tuning your fine firearm into a single shot. Mine did that to me one time when a coon was robbing my hen house. I learned a valuable lesson about holsters that day. May God bless, Dwight
  14. Not sure what you are attempting here, . . . Resolene is a FINAL, . . . LAST THING product. It is the cherry you put on top of a hot fudge sundae. There is no way it can take dye off a product that has been properly dyed and finished. May God bless, Dwight
  15. The same black grease I use on my tractor, mower, chain saw, etc. works fine on my Boss, . . . has for almost 15 years. When I don't have black, . . . the brown stuff fills the bill. May God bless, Dwight
  16. The first thing you need to decide, . . . what do you want to do with leather. The people making high end leather vests would not know most of the time where to start with a saddle. Many holster and belt makers would have a tough time doing a really nice ladies' purse. Determine what product you want to produce, . . . go to a local Tandy store, . . . tell them, . . . let them give you some good advice. May God bless, Dwight
  17. I like wrapped sheaths, . . . with a welt to protect the stitches, . . . looks like it would work for all three of em. Nice part about wrapped sheaths, . . . you can do it in two pieces, . . . the sheath and the welt, . . . May God bless, Dwight
  18. A friend had a pair of suspenders with these to protect the leather seats in his Mustang, . . . the others scratched the seats badly. He loves em, . . . so I made a pair, . . . mine are 1 inch wide, . . . no elastic, . . . and I have no problem at all with them. They are really comfortable, . . . but if I decide to re do them some day, I'll make them 1 1/2 inches wide, . . . as I have others that are just a tad more comfortable with the wider width. Mine were made with embossed veggie tan that looks like gator leather. May God bless, Dwight
  19. Look up on the top of the screen to the right, . . . little envelope, . . . you have a PM there. May God bless, Dwight
  20. I feel for you my friend, . . . as I often have the same problem with work gloves. And, no to akguy59, . . . larger gloves become more of a liability because your hand slides around in them. I mostly just soaked the gloves in warm, . . . almost hot, . . . water, . . . then wore them until they dried out. That usually cured the problem. But if you are sure you want to do this, . . . cut the seam going down the pinky finger, . . . then turn most of the glove inside out, . . . that should give you a flat surface so that you can put the patch over there where you want it. Make sure you glue it down with contact cement first. May God bless, Dwight
  21. As above, . . . thank you for your efforts and information. May God bless, Dwight
  22. Been doing belts the Lobo way, . . . John Bianchi way, . . . for over 15 years now, . . . never found a good reason to put a liner in one, . . . Probably wouldn't waste my time doing it anyway. May God bless, Dwight
  23. If you have never done a belt before, . . . you need to carefully measure the length you need, . . . by taking a belt worn by the customer, . . . measuring from the front edge of the buckle, . . . back to the most used hole. That is your belt length. I punch 7 holes in the belts I make, . . . so when I get to this point, . . . I will later mark that as the middle hole length. Then you work the end for the buckle, . . . do you have a pattern or template for that?? Do you also have a pattern or template for the tongue end?? When I cut the belt blanks, . . . I actually "need" right at 9 inches beyond the measurement for the belt length. I will cut 10 or 12 inches over, . . . just in case there is a flaw or something I need to work around. I make the outside piece, . . . and do whatever decorations are necessary, . . . I then lay the liner down on the belt with the buckle end folded over like it would be to put the buckle on, . . . measure and cut the liner. I use Weldwood contact cement to put the two pieces together, . . . Once they are together, . . . I even up the edges all around with a belt sander. Stitch the two pieces together, . . . bevel and burnish the edges, . . . punch the 7 holes at the tongue end, . . . dye, . . . finish May God bless, Dwight
  24. Yep . . . good lookin rig, . . . Go in hock, . . . get that other pistola, . . . it's worth it, . . . May God bless, Dwight
  25. I make and sell my CCW belts by cutting two consecutive strips 1 1/2 inches wide from 7/8 oz veg tan leather, . . . glue em together, . . . sand the sides smooth, . . . stitch the edges, . . . punch the holes, . . . dye and finish, . . . put on a buckle, . . . send it to my customer. That's the way I do it. May God bless, Dwight
