CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. You can probably use steel wool & polish that plate up real nice.We use a wheel in the grinder & it does a great job but costs around $50.00. We also stock the plates & etc for the 31-15 too.
  2. That's the way they usually look when we get them too.Then here's an after pic,I think the machine gray looks better.
  3. Yes,the D point will make quite a different looking stitch than the S.We don't sell the D's anymore at all. The S points sure will make a nice looking stitch.
  4. Hello Mary,Ok,I'll try to explain the best I can. Any machine that has a speed reducer on it will always turn harder because your turning the motor 5x faster because of the speed reducer.The way to run it is when you get to the end slow down & learn to leave your foot off the pedal when the needle starts to go up so the needle will be @ the top so you can pull out your leather. These new style of motors have an electronic not mechanical brake,there is no adjustment on them. The stop when you take your foot off the pedal. #2)The plug @ the back of the motor is for the light. #3)Are you sure the thread is around the second tension on the side 1&1/2 times? P.S.you don't need to stop to put it in reverse(if you don't want to),you can do it when you see the needle going in the leather @ the last stitch(rumnning slowly) & then push the stitch length lever up. I'll give you a call today & we can go over this with you today. Bob
  5. Welcome aboard,I also am from earth pretty nice here huh??
  6. Wiz, They can jam alittle easier than a machine w/a horizontal hook esp if you don't hold the thread like you should.but some like them better because of the larger bobbin.
  7. Years ago we used to rebuild aot of them & make them a high lift1"so they would sew 3/4" & also put reverse on them.As they come from the factory they will sew 1/2",they also take up to 415 thread w/o any problem. Alot of parts are still available for them.
  8. Welcome,I'm glad you found this site it's great!! It's great your Dads been in business so long & that your helping hom,my son & I work together too!I've been through Medina a couple of times & don't remember seeing your Dads shop.Maybe I'll look alittle harder next time. Bob
  9. Welcome aboard!! Great looking straps you made.
  10. Welcome it's great to see another Buckeye!
  11. I think the problem Wiz had with his machine was there's 2-springs that hold the stitch length foward & when one breaks that's what'll happen.They are great machines & will handle up to 3/8" max,so they are good for chaps,upholstery sewing. We rebuild & sell alot of them they are alot like the 226 Consew & what's nice about them is the feet are cheap since so many other machines use them. So don't be afraid of it,try it out,if it's a 563 that's a good price!
  12. Glad to have you aboard!You can learn alot here!
  13. It's great to have you aboard!! Your project looks great too!
  14. Oldtimer is correct you need to use the 794S point,that is our biggest selling needle for leather.They will make a real nice looking stitch because they make a cut in the leather that's in line with the stitching.
  15. Hello, We have had this problem before when we have rebuilt these & we have found that soaking really doesn't seem to help much.We clamp it like you have it & take off the 2-screws & washer at the top & get a brass or aluminun bar & hammer it out the bottom.You don't have to hit it real hard.What happens is the old oil dries up almost glueing it together. Good Luck Bob
  16. Great looking work there!
  17. Great job on the holster!
  18. Great looking work!!
  19. Great looking work!
  20. You found a great site here.
  21. Great looking work!!
  22. Knut, We used to get it in a gallon container.If they have any try the CRC 556 it works 3x better than WD40
  23. Knut, We've used the CRC power lube before & it is good oil for a machine,it is alittle heavier than standard oil.
  24. As the others have said DO NOT use WD40 as a lubricant,I would only use it on rusty bolts to free them up even then there's alot better lube to use than WD.I think the confusion comes from the can it's self,as they write lubricates ,penetrates,protects on the side. We have the sewing machine oil in 2-grades standard stainless(clear) & a heavier oil that isn't clear for heavy Industrial machines.And that's what we recommend to use. Bob
  25. #1 you could have the foot presuure to tight.#2 When does the inside foot come down?The needle should come down just slightly before the inside foot comes down on the feed dog. Bob
