CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Looks like a nice machine,someone put a larger handwheel on it which will help it to run slower.@handstitched that type of pedal just sets on the bracket & probably fell of during the move.
  2. Good buy,but you should consider size 138 as the largest thread & use#92 in the bobbin.
  3. Yes,as Wiz said get the Singer parts & feet are alot cheaper since they are used in many different brands.
  4. A Singer 42 class has the same upper arm as a 16 ,so yes a 16 class or 31-15 roller will fit.
  5. I know him,he's been collecting for years & has a bunch of machines I remember him telling me 15 yrs ago he didn't have much room left for more so I supposed these just popped up & he doesn't have room to store them.Good deal for someone!
  6. The answer is NO,this machine was made to sew slightly over 1/4" & mainly designed for shoe repair.It has no feed dogs & uses the upper foot to pull the leather but it has teeth on the bottom that will mark the top of the leather.
  7. What type of needle are you using?
  8. It is possible with using just the hand lifter that your not getting the full lift,for max lift you need to use the foot lifter & make sure there isn't much slack in the chain.
  9. We have been pulling the hook on every new machine & checking this screw since we found out that the hook factory wasn't tightening them as tight as they should.
  10. Yes,you just need a spring & nut for alittle pressure so it can grip the shaft,don't oil the shaft where this fastens on or it'll slip & not lift the foot like it should.
  11. Just use sewing machine oil,WD-40 is NOT a good lube!
  12. That's great you found the problem! Sometimes the simple things take hours to discover.
  13. I'll have to agree with both the above posts,get the Juki there's more feet available @ 1/2 the price of Pfaff feet & way easier to get them & any other parts you might need.
  14. Jude, Uwe makes these up.https://uwe.store/collections/featured-items/products/ux441-manual-foot-lift-extension-lever Or you could just always use the foot lifter which works easier for me.
  15. Alot of times the hole in the end of the needlebar gets elongated,loosen the needle set screw & see if it moves left to right,if so get a new needlebar.Alot of used machines we get in need them changed so it is a common problem.
  16. You can loosen the screws that clamp on the back pressure bar & rotate the shaft counter-clockwise will fix it.
  17. And you wonder why did a Japanese company design it that way?Which is nice since they are more in common with alot of the Singer screws.
  18. You will have a very hard time trying to find feet & some of the other parts for the 78 ,the 111w is no problem.
  19. It makes a regular lockstitch. Parts will be very hard to find if needed for it.
  20. Ok, put your stitch length on zero so the feed dogs aren't moving & measure the distance from the needle plate opening to the feed dog on both the front & back they need to the same distance.Look @ the hook position on page #2.In this manual.Note to everyone NEVER USE CAM ON TOP FOR HOOK TIMING! 441 Engineers manual.pdf
  21. This screw is still tight on the shaft & this adjustment does not need to be made.If it was my machine I would leave it alone.There is also 2 other larger screws that hold it tight to the shaft so it should never move.
  22. This is NOT where you time these machines!That adjusts when the hook starts it foward motion in relation to the needle. Look behind the round front plate on the lower rightside,you turn the machine so the needlebar is about an inch into the material & you'll see a 6mm allen in there.THIS is the timing adjustment for the hook.Lower the needlebar down all the way & turn machine handwheel towards you until it rises 5.5mm the the point of the shuttle should be @ the needle & approx a good 1/8" above the top of the eye of the needle.Like Rockyaussie mentioned check to see if the bar got pushed up first b4 you start adjusting the hook! Look @ screw #2 in the attached file.This is the one that is attached to the hook driver & the only way to adjust the timing.So re-tighten your other screws ,your machine should be OK & just use this method for re-timing. CB441 manual pg8.pdf
  23. You might want to check these out. https://www.tolindsewmach.com/thread.html
  24. I think the best thing to do is loosen the screws that hold the cam in place,each screw has a locking screw,so loosen the locking one first & then you can back the other one out 1/2 a turn,do this to all 4 & it should break loose.It would be pretty hard for any penetrating lube to get into the correct spot ,so this will work.Then of course you'll have to snug the screws back down & re-tighten the lock screws b4 you run it.It looks like your machine has allen screws in it.
