CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Should take a 214x1 needle
  2. If your going to sew leather the Juki 1181 wouldn't be a good choice as the feed dogs can leave marks on the bottom of the leather where the 1541S with needle feed & walking foot the teeth can be polished off & as they are not needed .
  3. We've found on thicker leather do to nylon being stiffer than poly it sews better with less skip stitches.The poly doesn't make a good loop for the needle to catch.
  4. 92 will be hard to thread on a #16 needle.
  5. Yrs ago we used to use air pump pulley off Chevy engines,the water pump pulley will work too it's offset,you drill holes & bolt it on the the original pulley.
  6. On another topic, I hear Sailrite now makes a smooth feed dog for these machines. It's nice to have it so it won't mark on the bottom but,I wonder if that would give consistent stitch length when sewing leather?
  7. You would also get a lower speed since the motor pulley would be smaller than the one on the machine,so a motor with 200 rpm low speed would be 100 or less @ the machine on a standard setup.
  8. A smaller thread like size#69 will look better in thin leather like this & give a better looking tension too.
  9. FWIW Industrialsewingmachineman is a drop shipper,he doesn't stock anything so since Cobra is shut down he won't be able to send one either.
  10. The smallest Singer in the front dates to 1958 the next one is 1864
  11. We've tried getting this type of machine to use #138 & it just won't work no matter what you do you just can't get enough tension to make it sew properly.
  12. It's an Adler 267 & a very good machine.
  13. The only way to get all the parts you will need is from another machine Singer has discontinued them a long time ago.I've done them using parts from broken machines & transferring parts but it is alot of work.
  14. Yes,he's been fighting cancer & sold his business last year,the new people don't know machines like he did though from what I've heard. You can give condolences on his FB page https://www.facebook.com/stephen.bonnett.39/posts/1851831321621762
  15. @ConstabularySteve passed away earlier this week.
  16. The roller foot will work good with stiff leather,soft thin leather will lift & cause skipping.A walking foot attachment won't hold up on this machine since most are made out of plastic & even break pretty quickly on the home machines the were designed for.The width of the foot is pretty wide also & will hinder you from getting close to an edge as most leather sewers need to do.
  17. No,the 88x1 are shorter & will not work,someone must of adjusted your machine to use the 16x257 which are easier to get & even available with a leather point.
  18. The 135x5x7 are round points for cloth & vinyl,the 135x8's are D point (diamond) for leather.If you use or were to use the longer 135x17 needles they would break easier since this is a needlefeed machine,that's why it came from the factory with the shorter needles .
  19. It is best to start with a simple thing,when was the last time you cleaned in between the tension discs?Alot of the polester thread is fuzzy & the lint builds up after while. It's real easy to take the nut & spring off,then the release washer,then take the discs out & look in between them for lint & sometimes there might even be grooves that the thread wore into thereby not allowing them the grip the thread like they should.
  20. Looks like the right side of the foot got bent down,try to straighten it by bending it up.
  21. @Desircustoms Here's a manual for it. Rex,Chandler 26-188 A@ manual.pdf
  22. On a 111w you should get it back as far as it will go but not beyond the edge of the table top (in case you put it against a wall) so this way your motor won't be in the way when you mount your knee lift.
  23. I wanted to use a size you could buy over there! Yes,there's alot of things in metric here & you almost have to try & put a wrench to it to find out !
  24. We call these carraige bolts here in the US,they are a M8 x 75mm long
  25. Be sure to let us know what you think of it after you get it sorted out.
