The 45K never had a walking foot needle feed like the Juki so they will not interchange.The back or outside foot has to be wider for the inside to fit into.
The 269 will sew thicker ,has a higher lift under the foot,will take a larger thread & has a larger bobbin than the 69,but at these prices I would buy them both.
We used to paint alot of machines & prepping as Trash Treasures says is very important esp washing off before you paint with alcohol when using the hammertone or you'll get big fish eyes in the paint .After they were done we would put them outside in the hot sun to bake or use a heat lamp on them if you have a garage or shed to bake them in the fumes are terrible.
Looping underneath is almost always either incorrect threading or upper needle thread too loose.Be sure to go around the 2nd tension on the side 1 & 1/2x ,also be sure to run through 2-holes on the spool pin on top.
Your Welcome.
It might help you sometimes if you fill out some of your profile so people know where you live.They can recommend a supplier to order from.
On some older Singers there's a tension release on the side,not in the middle,if you look in the hole after you take the tension out can you see the release lever back there? part # 20314 is the old style.
Do you know what might be the reason to instead opt for 135x17 needles? Are they more common/cheaper than 134-35? Yes,the 135x17 are easier to get .Another reason to go to a longer needle is with the slight rise of the needlebar will allow you to sew thicker before the needlebar hits the foot.
Like others have said make sure there's no play in any of the parts.Then we used to drill a hole just beyond the bottom of the slot & take a file or grinder & open it up so you have a longer slot & this will make the stitch length longer.
Just to clarify the 135x17 measures 38.9 & the 134-35 is 38.1 that is 0.8 mm approx 1/32" difference.If the machine is already tested for the 134-35 then the 135x17 will also work.We sell alot of the 134-35 to people with the 135x17 or 16 & always mention if they have a problem with skipping stitches they might need to lower the needlebar a small amount.
Tilt the machine back,look @ the clutch & then turn the machine until you see the hole in the outer part & make sure you can see the BB in there B4 doing anything else.I'm sure it's in there BUT we need to know for sure.
Yes,the machine will turn & so will the hook unlike the 111w type machines,but when the clutch kicks out it will appear to be out of time like your machine is.
