CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. The Juki 471 is more suitable for sewing nylon webbing since it has lower feed dogs & teeth on the upper feet (which could be ground off BUT you still have the bottom feed dogs w/teeth that can mark the bottom of the leather) The 441's can be fitted w/a smooth feed dog that won't mar since it has a needle feed.
  2. Try Shop Talk www.shoptalk-magazine.com for one.
  3. Have you checked w/a voltmeter that your getting voltage on 2 of the wires?
  4. Nylon should work as long as your machine is in good shape to sew it.You might want to look around the outside of the hook(the piece of tin held on with 4 screws),the needle can hit it & put nicks in it.
  5. How does the hole look in the needle plate?They can get chewed up pretty easy from needles hitting it.
  6. You could get some dirt under the feed dog causing it to tilt? Also check that it isn't bent.How about the top pressure foot does it come down straight?
  7. Maybe this will help?
  8. Hello Elizabeth, Welcome to the forum & the leather sewing business.We also look forward to help you with a servo motor & anything else you might need.We have a lot of machines for you to come down & drool over on our showroom floor.LOL
  9. Another one from the Buckeye,Welcome aboard here & it looks like your doing a great job carving already!!
  10. I found the 332LGLR in sizes 18,2022,23 they should be here in a couple of days.
  11. Wow,Shoe System gets $7.50 a pk & they aren't even leather point.
  12. Looks pretty good,but if you had the 207 in the bobbin it would hide the knot better.
  13. Yes,it's looking better BUT ,I always tell people when your checking tension to make sure your leather is thick enough for the thread,so you should try the larger thread on 2 layers or the thickness of the project you plan to sew.And practice alittle on that thickness before you try sewing on a piece that has tooling & is cut to size,it a lot easier than pulling out stitches or possibly having to start over. You can see that's why the 277 & 207 combo looks better than the 277 & 277 the thinner thread on the bobbin helps to hide the thread therefore making your stitch look better as you get into thicker the 277 & 277 will look better.I know a lot of people always run a size smaller in the bobbin when they are sewing on thinner leather.277 is best when your around 3/8" & thicker the knot hides better.
  14. The head weighs 123Lbs.or almost 56 Kgs. I wouldn't run it too fast,not over 600 st pr min & keep it oiled because parts will be very hard to find. Here's a pic of the one we have.
  15. Yes,it's pretty hard to find one the exact length w/a tapered head on it.We stock a lot of them because they are so easy to drop & never be seen again!! LOL
  16. Yes,it is a good idea to make sure it has oil before you start using it.
  17. If you still need them,give us a call we have them in stock.
  18. Hey Alex,Thanks for the info I didn't know about that.
  19. That's good to know,Thanks for sharing.
  20. They had them in the oil holes for both the upper shaft bushings,you can normally reuse them,just put oil on them or replace with a small piece of felt cut to fit.
  21. You sure seem to find some great old machines.You might put the rusty one in a vat of diesel fuel & let is soak for a few months(maybe a year,LOL) & you might save it?
  22. 1/4 turn might be enough,you have to try a sample,a piece of paper or thin cardboard can be used to check the length.
  23. The easiest fix is to get the knob al the way in & use a screwdriver on the feed cam screws to adjust the length.You get to them through the top cover on the rightside of the timing belt turn the handwheel around & you see a big headed screw,turn it 1/2 way around & there's a smaller screw that you'll have to use a small screwdriver to get into the hole with.There should be 2 screws in there,one is a short locking screw & you take it out & turn the other one underneath to the right f/a longer stitch,left is shorter,then test sew until you get the length you want then re-install the short one to lock it in.We do have the shaft in stock BUT it's a big iob to change.
  24. Yes,they are priced in the ballpark esp if the one sews like they say & maybe you could get the other one sewing & sell it.
