The longer needle breaks easier & are harder to find(we stock them though) so they adjusted it for the more common 135x17 needle.This needlebar is hard chrome steel & very hard to tap,BUT I do have it in stock for $24.00 + shpg,call to order.
This machine has some pretty aggressive feed dogs & since it doesn't have a walking foot to help feed it will probably leave alot of teeth marks on the bottomside.Take some of your samples over there & try it b4 you buy it & see if you can live with the marks.
It depends on the material some leathers are sticky & the stitch length will shorten & the flat foot will also have problems going over a seam where this will allow it to feed better.
This is a Chinese copy of a Singer 81-10 serger,3-spool auto-lube.Around 1995 here in the states YMC used to bring these in & they were not a quality machine this one might of been $95.00 cost for the head.
@rac1812 Slightly loosen the 2 screws on the small hook gear & see if you can get the hook to lower,if it won't move down you could grind out the slot on the bottom of the needle plateTry to increase the size of the slot from front to back(grind on the front side) & try not to take any metal off of the top of the slot.
The 331 is similar to a 335 in the fact the feed dog doesn't lift the material off of the needle plate when it goes back.This creates alot of drag esp in sticky materials like vinyl & leather & will cause the length to shorten.You could have some worn feed parts,lift the foot up & push the needlebar front to back & try the feed dog too to see if there's any play.
The 331 a needlefeed & looks like the 335.
@WizcraftsIt will help your foot lift if you grind alittle off of the top of the foot(the comes in contact when the regulator is all the way down) so it doesn't hit the stitch regulator.
As long as the Adler has the rubber timing belt it would be a better choice w/reverse & the handwheel is larger & it will run slower than the 211.And would sew 138 easier than the 211.
As chisel said get the tab of the bobbincase under the groove of the needle plate & also when you stop & want to pull out your material make sure the take up lever is all the way @ it's highest position.
@wyattuphaus Sounds like you might have something caught in the shuttle,take it out & clean it & re-install & oil the groove it rides in & report back.
