CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. I've noticed with Singer that a lot of the first model # like this model a 95-1 then they revised it to 95-10 improved with metal gears also happened with a lot of other models like 7 class,45K & others.
  2. Looks good!! It probably should work nice too,that small pulley is smaller than usual so it should slow it down alot.
  3. 2nd idea,There's a vertical rod for the knee lifter on the back that if you tilted the machine back & set it back down could of gotten in a bind.
  4. This machine was designed for binding thin material like clothing.It might sew 4-6 oz leather w/#69 thread but it will never use #207.It would probably work on wallets & real thin leather for fine stitching.
  5. One thing to try is putting some Teflon tape on the bottom of the foot to decrease the drag on the leather.You might even be able to find some thin sheet Teflon @ a good hardware that you can cut to size & glue on the bottom.
  6. If your trying to do quality work you need a better machine like the 5100 that has the walking foot & smooth feed dogs to get a quality look.
  7. This is the same machine w/o reverse http://parts.singerco.com/IPinstManuals/31K.pdf
  8. This is why HD machines for leather have a walking foot,because on your machine as you tighten the foot pressure it creates more drag & doesn't want to feed,so when you loosened it to help it feed,it'll lift causing skip stitches.Try getting some teflon tape & put it on the bottom of the foot & it'll let the leather slide through easier.This might help your feeding problem,BUT someday soon if you serious you will an much heavier duty machne. It also might help to oil the leather to soften it.
  9. That is a great film.I've always been amazed how Singer made such great machines back in the day before electronics.They were made with good precision too! I bought a book off ebay that has the pics & highights of this film & even the pages with the words are in it. Thanks for posting it.
  10. I have to applaud you in your dedication to make this belt & keep a machine running that has an obsolete part.I get call every for them every once in a while & send them to you.I also think it's great that you've improved them.As far as SingerI think after time just like you found out there's a better way to design things & maybe that's why they went to gears esp in a factory where most of them were w/oil getting on them & streching I'll bet they got some complaints & improved them.They also done this on a lot of other machine like the 29's.It sure would be nice to read some of their engineers notes from back in the day about some of the designs.
  11. You go back & forth ,left to right w/the material,like a burlap bags to pair a rip.They used to do it to work shirts & pants,but they used a different machine.
  12. That's called a darning attachment so you can move the material with your hands.That's great you got it going.
  13. Does it sew ?
  14. You might check to see that this adjustment on the wingnut on the backside so the line is pointing to the m or h see fig#31
  15. These units are very costly over $200.00 US. the last time I priced one.You might try running the thread through 2 or 3 of the holes on the spool pin on top of the machine,this should make more tension @ the discs & keep the thread from sliding out.
  16. Hello Ike, Is the screw that the lever pivots on loose?This can also happen when you take the end cover off to oil the internals & forget to line it up.
  17. Ike, The tension to loosen is the first one & the thread goes down the back underneath & up the front.Here's a video
  18. You'll probably have to flip the motor pulley to the other side & maybe even move the motor to the right because the small pulley that goes to the machine will line up with the machine pulley & the belt from the motor goes to the large pulley on the reducer(which will be approx 1&1/2" to the right).The best thing to do is set it underneath & you'll see what you have to do to get it lined up.
  19. Hello Ike, WOW for the first one you did a very professional looking job! Looks great !
  20. The 29K51 is the one that has small little gears in it that haven't been made for over 30 yrs,if they break you'll have to find another nachine for parts.It was made to sew 1/4" thick although some people have sewn thicker it'll just put more stress on the gears.
  21. When you have a problem like this,you might want to double check your needle threading before you start in adjusting alot.Once in a while I've had people forgoet to go around the 2nd tension 1 & 1/2x & that will do it.Or the thread migt of jumped out of the top tension.
  22. Yes,we do & we also have the spring (aka finger) too if you just want to get that.
  23. Chuck,is the thread winding even as it goes from side to side?If it piles up on one side you can loosen the screw on the tension unit & slide alittle to the other side to get a even wind.You might need to keep turning the screw on the finger more to the left until it starts working.Or you might even have to bend the finger up to get it to kick off.
  24. Which machine?
  25. Eric gave you some good advice.I also like to add it's best not to get in the habit of wnding the bobbin w/o sewing in 5 yers time you'll have 10 ys of wear on the machine.You can wind bobbins w/a drill if needed by getting a small bolt & nut that fits in your bobbin & wind them w/o have to spin your machine.
