shoepatcher
Everything posted by shoepatcher
  1. The screws on the needle bar clamp are toast! I would replace them. You have a part number for them? I have acquired a bunch of 45 K parts including feet. glenn
  2. JJN, You get your patent elastic up and running? glenn
  3. If it works, that's all that counts. I have never seen a plain drawer on any Singer shoepatcher that was original. They all had a front that was milled with a knob in it. glenn.
  4. Anyone have a Plough Gauge for Sale?? I have someone looking for one. Send me brand name and price please. Thank you glenn
  5. Not an original Singer drawer. Looks more like an Adler drawer. glenn
  6. I have the drawers for the short arm Singer treadle patchers. I had a an Amish company in Ohio build them to original Singer specs. Drawer sides are thicker than the singers were and they have dovetail joints on them. $28.50 US plus shipping. The long arm drawers are longer and wider. never had them made.. glenn
  7. 180 shim for size #180 needle, 200 for size #200 needle, 230 for #230 needle, etc. You can use a larger shim with a smaller needle BUT you CANNOT use a smaller shim with a bigger needle!!! glenn
  8. 1.- back the tension off the needle. What size needle and thread you using? 2. -needle is blunt you are using 3. Needle needs to be centered the feed dog hole from left to right and back to front. 4. Sub class Model of 45K? glenn
  9. First oil the linkage holding up. Send us a few pics of the back of the machine se we can instruct you what to do. glenn
  10. I have a 17 Durkopp manuals and parts list but not the 18. The 18 was a stationary shuttle shoepatcher. " Constabulary" on this site made a video of one he rebuilt. I suggest you contact him and see if ne has a manual. glenn
  11. 335 with toys and set up for binding. These honey and brown ones were made in mid to pate 1980's. small bobbin. i do not believe this has the new bigger G size hook. Front tension assembly and take up lever cover has been damaged. It needs some work but can be fixed.
  12. Contact Hoffman Brothers in Chicago. They bought Ferdco which was a later company but may have info. Send us pics of the machine and we can tell you what it is a clone of. glenn
  13. Try Bob Kovar at Toledo Sewing. weaver Leather on line
  14. No, feet are different unfortunately. Contact Kwok Hing. They have generic parts for the 69 binding feet, feed dog, throat plate. Lot cheaper than Adler. glenn
  15. evilblackdog, The unit on the back of the machine is called a Dimas unit. It was made by a company in Denmark for the 1295, 345, 335, 1245 to put toys on the machine. You can order the front stitch length plate and the reverse lever rod form Pfaff. You will also need a standard throat plate, feed dog, inner and outer feet. Save all the Dimas parts. I have worked on them and that unit is no longer made. You can remove the trim knife as well from near the hook. Take motor, control box off. Contact me with anymore questions. Obviously, you will need a servo motor. Save all parts.!! glenn
  16. Do you mean a Chandler 305-64? I do not know of a 303-64. If so, that was made in Japan by the old Chandler Company out of New York after they lost the Adler distribution right to sell Adler's here in this country. Copy of an Adler 105-64. I believe some Adler parts are still available. Can we see pics of the machine? glenn
  17. First question. What do you want to do and sew with this machine. It has automatic functions but the motor is 3 phase and 220 and as johnnydb stated in the previous post, getting a phase converter bought and hooked up will not be cheap. Plus, you have to have air to run this machine with the functions if I am not mistaken. it is NOT an old type clutch motor. That is full function motor with a control box. glenn
  18. Nope, not the same. Sorry. I would check the stud on a Seiko or Consew 744. They normally copied the Singer machines. glenn
  19. I believe there is a screw made by Seiko to screw the cover plate down so it will not move. glenn
  20. A stud from a 111W will not work? glenn
  21. Max. stitch length is 9mm. Foot lift is 20mm. that is what makes the 669 so nice. glenn
  22. I have sewn on the 69 in a couple of subclasses. great machine. However, I own a 669 eco. It is fabulous. Until about 1.5 years ago, only machine built in this class in the new generation. Seiko came out with one in 2019 i believe but not as good in that stitch length is not as long or is the lift as high. My question is what do you want to sew and what weight of thread do you want to use? Answers will determine what machine I would recommend. I can give you the differences between the machines. glenn
  23. Unusual for Eli. I would still call him. He is the leading expert on the Landis 16 right now! aaaaaaaaaaaaa Something pissed him off for sure but what? I give people 2 chances. Like James Bond said. " Once is chance, twice is coincidence, 3 times is enemy action!" Glenn
  24. Contact Eli Schalbach at Landis Sewing In Port Aurthur, IL. He rebuilds them. glenn
