shoepatcher
Everything posted by shoepatcher
  1. The spring should be under no tension until you raise the foot. That is how I would set it. glenn
  2. Folker, That looks just fabulous. You did on hell of a job on that. Fun to rebuild? glenn
  3. Jesse, Where are you located? If in the states, call MJ Foley. They are the largest Juki dealer in the country and sell Mitsubishi motors. Very knowledgeable on them. Call 1-586 948 6070 and ask for technical assistance. glenn
  4. I have seen them where the rod enters the hole in the bracket and then just bends. It is held in place by a small cotter pin and there is no upward bend in the rod. You can also try bending the bracket out ward ever so slightly. remove the bracket from the machine before you try bending it in case you put to much strain on the bracket and snap it out of the casting . glenn
  5. W.S. Bessett still in business making attachments for sewing machines. They are in Maine now. I have used them in the past. glenn
  6. I have a service manual for Claes 8346 machines glenn
  7. It could be both. We need to see pics of the packing and the machine to better help you. glenn
  8. I have seen coiled springs cut down because they initially had to much pressure for the application. I would start by taking a link out a time and see if that changes the pressure on the foot. glenn
  9. Damn. That is a new one on me. glenn
  10. Folker is correct. The 30-5 is a long arm high lift small bobbin machine. Small bobbin like the 30-1, high lift like the 30-7.
  11. The Adler is the better machine because it is a high lift version, long arm version. However, some parts are no longer available although I might have them. The Singer is the better machine for parts and availability. I would buy the Adler but that is me and I rebuild patchers. glenn
  12. Is that a 205-370?  Is so, the owner should have been shot leaving it in that condition!!~!!  .  Any questions, contact Allen at Weaver.  He is the foremost expert  on that machine having worked on them for over 20 years.
  13. Wiz. Really? In Japan, it should have been labeled 29K172A, not 29K172. MUMMMMM???? glenn
  14. Nice Jimi. It binds well. Remember, generic Pfaff feet are cheap. glenn
  15. Most of the machine seems to be there. It is a green colored meaning they were made from the late 50's to early 70's. Cleaning is up, possible repainting of the head, rebuilding it should not be too hard to do. Take lots of pictures while doing it. I rebuild machines as does Constabulary. I would take the machine on. glenn
  16. No. The 29K 171, 172, 173 series followed the 29K71, 72, 73 series. It was the last series made at the Kilbowie plant in Scotland. Is yours gray or kind of a slate blue in color? For some reason, people have more trouble with the 171,172,173 series. Many consider the 29K71,72,73 series the best Singers every made in a shoepatchers. It is the one most copied by Clone makers in China.
  17. One thing you may not know Jimi is the 335-17/B is a binder machine yes but it is a symmetric feed binder. To make a it that kind of binder, you must use the cover plate the moves. If not, the old plate with all the holes makes it a no binder machine or one you can install other items on that plate. Symmetric feed binders are more rare and work better. glenn
  18. It may not have four motion drop feed. It may have a skip feed instead. Send us a pic of the brass model plate off the machine. I think it has to have the letter "P" in the model plate to have 4 motion drop feed.
  19. And yes, I have gotten needles with a sharp edge or burr in the eye. It does happen. Also, new generic bobbin case for 335 are fairly cheap to buy. glenn
  20. Great job as usual Jimi. You want to get the correct needle clamp screw as the one you have is sticking way out and that can be a problem if you are sewing something tight. You ever put the correct wing screw and locking clamp on the base plate you made on the on the older 335 you restored? . If Pfaff parts are to expensive for the Pfaff, go to Consew wingnut, clamp and screw from a 227 on the Pfaff. glenn You can get generic feet for the latest 335 you are doing cheap on eBay or College Sewing. glenn
  21. Most parts for a Consew 226 should fit a 111w155. The 226 is a copy of the 111w155. glenn
  22. Yep. The black one you did had to be a very early 335 since it was black. I have seen very few of those machines ever. The Pfaff 335 was the best in it's class for decades. The best machine now is the Adler 669 of which I have one. No other new generation machine in this class. It is a beast. Keep up the photos. glenn
  23. That is one I have not seen before. I agree. Heavier than a 111, looks like a 144 for sure. glenn
  24. Jimi, I have to say, even after 4 years later, this project still blows me away how well you did rebuilding this scrap of a machine into a nice workable 335 and I rebuild machines!!!!! Truly a great job and labor of love. I once rebuild a Singer 168101 post about this bad but I was able to get most of the parts and screws and that made it easier than what you had to do. glenn
  25. Since you are in California, I suggest you contact Yamata in California. They sell the Goldstar GSM-550 motor. The motor sells from between $126.00-$150.00. I got mine from All American Sewing in Louisiana. You have to order the 50 mm pulley separate. Normally comes with a 65mm pulley. Anyway, I have used several of them and recently put it on to my new Adler 669 cylinder arm. It runs nice at slow speeds and has the power at the slow speeds. You can get a synchronizer for needle positioning for about $25.00 more. It is a good servo motor. glenn
