Here is a picture of the tiny bobbin used by a Singer 29k71 patcher. I've compared it to a couple of US dimes. The inside clearance is about the thickness of 4 dimes, or 3/16 inch.
The machine you are referring to is probably the venerable Singer 29 series shoe and boot patcher. The photo below is my Singer 29k71. This is a patch machine in my World. It sews embroidered patches over pockets on Biker's vests and jackets. It also resews shoes when the thread lets go around the toe box and vamp. It has resewn pull tabs on boots. It has sewn purse straps back in between the lining and outside layer on the narrow sides where no other sewing machine can go. One of the most unusual jobs I put it to work on was sewing around the top and bottom of hand made leather dice cups. I use it to sew long seams up the arm which it does well due to the 360 degree rotating presser foot. One thing I never do with my patchers is sew belts, holsters, sheathes, or any other long or thick items. I have other machines that are built for those things. This machine is not for production. It is for repairs. The bobbins this model uses are just under the diameter of a US dime (~5/8") and hold 3/16" of thread. If you load it with #69 bonded thread, it will sew quite a few small projects. But, if you load it with #138 thread, it will only sew about one long dress belt.
Here is a copy of the manual for the Singer 211G155 and 156. Singer_211G155,_G156.pdf
Make sure that the two spring loaded screws that hold the shuttle assembly onto the end of the arm have about 1 full turn of slack. If they are tightened all the way down the shuttle can squeeze the needle and thread. You need enough clearance for the thread and needle to go around the shuttle without binding. Those little coil spring on the screws allow it to float a bit. Remove your leather and top thread, then slowly run the machine while watching the needle and shuttle interact. Does the shuttle hook hit the needle, or squeeze it against the shuttle ring? If so, back off the screws another half turn. Check for a bent needle! Next, verify that you are using the proper needle size for the thread combination you're using. Consult this needle and thread chart.
You have just described the Consew 206RB-5. Juki has several walking foot machines meeting your wish list, including the DNU-1541 and LU-1508NH.
No sir, they cannot be converted into a walking foot. But, you can convert it into a roller foot machine. I saw one at Toledo Industrial Sewing Machines that had a roller foot and the flat foot was in the drawer.
I had one until last spring. It can take a #23 needle if you want to use #138 thread. But, I found it to be more at home with #69 thread and a #18 needle. The most I used in it was #92 bonded thread, with a #19 or #20 needle.The maximum thickness is 5/16 inch on that model. But, it should be soft to medium temper material, like denim or chap/garment leather. Be careful turning the stitch length knob on the balance wheel. The top rear shaft has threads machined into it and they get brittle and break after 75 years of service. When the threads are gone you will have trouble changing the stitch length. The maximum stitch length is about 4.5 to 5 to the inch on that model. But, it can be tweaked for a bit longer.
New Servo Suggestion? (Consew 206RB-5)
Wizcrafts replied to MtlBiker's topic in Leather Sewing Machines
If you have a clutch motor from before, swap motors until the servo dealer reopens and learn to feather the clutch. Back out the big bolt to get the free movement you want and tighten the return coli spring to pull the lever up. You can buy a 45 or 50mm pulley for it if you really want to go sloooooow. -
Beginning to look for a sewing machine.
Wizcrafts replied to mcmuck's topic in Leather Sewing Machines
Juki makes some of the most reliable industrial sewing machines in the World. They still produce the TSC-441 from which the Cowboy, Cobra and Techsew (our supporting advertisers) harness and holster stitchers are cloned. Sewing factories and garment producers have buildings full of working Juki machines. They are not the only top name, but are among those. Proof of this is that most of the Juki line is cloned by lower price manufacturers. As for buying a used Juki, make sure you know up front what condition it is in and what, if anything was wrong when it was traded in. Any sewing machine can be worked hard and need some new parts or at least a good going over and adjustments. Sometimes a dealer leaves those tuneups until the machine is about to be sold. It would be wise to see the machine sewing. Bring in your material and ask them to sew it with the type of thread you plan to use. Be aware that new Juki machines can sometimes cost twice as much as their clones. Some of this has to do with the duty charged on Japanese imports. If a particular model is built in China, a different duty rate may apply. These charges can ramp up the prices unexpectedly. -
Wawak (Canadian division) caters to what is known to the industrialized world as "the needle trade." Like other industrial countries, Canada has all manner of professional sewing shops, alterationists, garment and accessory factories, tailors, shoe and boot makers, shoe repair shops, seamstresses, hobby sewers, domestic sewing machine dealers and industrial sewing machine dealers. Canada has a rich history producing sewn goods from all manner of materials. There was and still is a thriving needle trade in many major Canadian cities. You also have a top quality sewing thread producer named Cansew. For decades there has been a leather supplier in Toronto, whose name is Moore Pearsall Tannery Warehouse. They are a major supplier of high quality bridle and harness leather, as well as veg-tan, retan and chrome-tan leathers. Toronto has some industrial sewing machine dealers who have been in the needle trade for many decades. Unbeknownst to many here, Toronto (and other Canadian cities) are prime haunts for movie producers. A lot of costume makers and gun smiths are busy making movie props in Canada. Somebody I see every day made holsters for the movie Romeo and Juliet, which was cast in TO. My friend, working under the art department, measured Leonardo DiCaprio and the other primary actors for their custom holsters, then built them in his basement and sewed them together on his Union Lockstitch machine. A few years later he moved back to the USA. Added: You can buy double-sided leather tape from Wawak in 60 yard spools, in widths from 1/4" through 1". I use it to install zippers, to secure hems and seams, to hold patches on hats, vests and jackets for sewing, and, to hold various pieces of leather together securely for sewing. The one inch wide tape is great for securing double leather belts, especially if you want to pre-bend them inwards for sewing on a natural curve.
Basically, Frobana machines are non-existent Stateside, or elsewhere, unless one becomes available used, as is. I have seen exactly one in my life, but it wore a Gritzner name tag. There used to be a seller/rebuilder in Canada, a decade or two ago. And Henry Veenhoven, in Toronto, used to sell hand operated Junker and Ruh sole stitchers, but they aren't anything like a Frobana/Gritzner. There is no comparison between a hand cranked Frobana and a motorized Landis 12(letter). If you make or repair shoes and boots, get a 12F or 12G and be done with it.
So, feather the damn clutch!
We usually slow down the motor, not the machine. I have some motors equipped with 2 inch pulleys and under. Clutch motors usually have a 3/4 inch shaft and small pulleys can be found online. Just make sure you buy from a sewing machine dealer who has 3/8 inch width pulleys for type 3L belts. If a small motor pulley doesn't slow it down enough, there are speed reducers available in 2:1 and 3:1 ratios. For every inch of motor pulley reduction, you will need an equally smaller 3L v-belt.
If you have a scanner, or a printer that also has a scan function, place your photo(s) on the scanner glass and select an option to scan to your computer. You may have to run the setup program again to get scan to computer to work. Save the scanned file with a .jpg or a .png file extension. You can then upload that/those files to our forum as long as you keep the file size down to our allowed maximum of 1.4 megabytes per upload. Now, in the event you don't have a computer and must do all this on a mobile device, take pictures of your photos, avoiding reflections as best as possible. Then search your Gallery for the photo you want to upload and use the Upload button to send it hither. If the image file is too large, try to email it to yourself using gmail. Setup an account if necessary. Open a new email in Gmail; address it to the same email address; drag or select the photo file to attach, then type a Subject and press the Send button. Wait a few seconds, then check for new messages. The one you sent to yourself should arrive in your Gamil inbox. Save the attached file, then try uploading it here. You can also try sending the attached file from Gmail to a different email provider that you already were using. Save the attachment and repeat the upload attempt.
TOTALLY BUMMED OUT!! CANT GET A COBRA Class 26!
Wizcrafts replied to KennethLee's topic in Leather Sewing Machines
This is turning into a most interesting topic! Festivus approaches. Let the airing of grievances begin! -
I buy mine from Toledo Industrial Sewing Machines. But, you can get them from most industrial sewing machine dealers, like Leather Machine Company, Campbell-Randall, Hoffman Brothers, Nick-O-Sew, etc. These bobbins are used in all of the 441 clones.
Here is a manual for the Singer 150W103 The 150 series all use System 134, DBx1, 135x5, 135x7, DPx5, SY 1955 needles The description in the manual states that this is a high speed tailoring machine.
Have you considered this equivalent machine? -
Cut out the excess slack via the check spring adjustments. The first adjustment is to set the lower travel via the movable curved bracket under the check assembly. The further down the spring moves, the lower the slack. Fine tune the action with the position of the curved slot by loosening the small set screw in the curved slot. Moving the disks clockwise tightens the thread. Moving them counterclockwise loosens the thread.
The Singer 153 series uses the same needles and bobbins as the 111 series. They are the common walking foot System 135x16 and 135x17. The needle bar stroke depends on these lengthy needles to complete its downstroke without hitting the presser and vibrating foot. Substituting and lowering the needle bar height for a shorter needle system will cause the bottom of the needle bar to hit the feet when sewing at maximum thickness, or when the feet are lifted to remove the work and release the top thread tension. Use the correct needle system and time the hook as per the specs. If the needle's eye is too high at pickoff time, loosen and lower the needle bar to retime it.
Advice on buying a post head sewing machine
Wizcrafts replied to kjack88's topic in Leather Sewing Machines
Fascinating! -
Watch the check spring on the take-up stroke. If it shudders as the lever pulls the thread, then you hear a slight click in the bobbin area, the top thread may be getting hung up on the way past the bobbin case. To fix this you may have to adjust the lever that pulls back the bobbin case so it lets go sooner, and/or lower the hook in the hook saddle assembly. This is tricky, if even doable.
No. Shoe polish will wear off and will soil your clothes. If you want to darken/blacken a leather strap that already has a top finish applied to it, use Leather Refinish. This paint is sold on eBay and elsewhere in 4 ounce jars and is rubbed on in a circular motion with a sponge. You can apply several coats to get full coverage. It comes in various colors and shades thereof. I use Leather Refinish to change colors, or touch up colors on upholstery projects and leather jackets. It is water fast once it dries and is hard to rub off. I recommend getting a complete starter kit to prepare and condition the strap before you dye it.
Reliable Barracuda and its look a likes
Wizcrafts replied to Trouthunter's topic in Leather Sewing Machines
The official literature claims that the maximum thread size is #92 bonded, using a #21 maximum needle size. The hook clearance would have to be increased to clear a #22 or #23 needle and lockstitch knots that are 50% bigger than expected. Other parts may also need to be opened up to pass the oversize thread. This will probably cause the loss of the lower end of thread handling, shifting the range up by 1 thread size. But, 138 thread will really stress out the take-up lever and associated crank shafts and bearings. The bobbin tension spring might have to be stronger to not bend out permanently from the large thread. The top tension beehive spring might have to be replaced with a heavier duty coil spring. The check spring will need to be tweaked. These changes and running heavier than recommended thread will likely void any warranty that normally comes with the machine. If you consistently run #138 thread in this machine you will wear it out rather quickly. -
What height will your shoes have as you sew over the post? Most common post machines have a 6 to 7 inch high post and about 10 inches clearance from the needle to the inside of the body. This should be adequate for most shoes and medium shank boots. You will have to decide in advance on the type of feed the machine should have. You'll get maximum visibility with a roller foot machine. Some are only bottom drive and some are top and bottom driven. My Singer 168 post machine has triple feed walking feet. I used to have roller foot post machines that I used to sew caps and hats. If you get into sewing tall boots you will probably have to think about getting a Puritan machine. Red Wing work boots have some seams that are sewn with three needles running a chainstitch on the inside. Puritans come in a variety of post heights, from as low as 6 inches, all the way up to 3 feet. You will probably have to buy a used machine.
