Everything posted by TomG
Use a Hangman's Knot. It also has a few other names. Fishermans knot, etc. You can use it on rope, string, jewelry cord, fishing line and whatever. I would suggest no less that 4 wraps.. more for larger rope/string.
No way that I know of. They are not meant to be opend so far that they bend. I use a pocket knife to open them just enough to slide over the ring I'm putting them on and then just rotate around.
Here you go..
Heat pressing vinyl lettering onto veg tan leather
TomG replied to BoulevardEast's topic in How Do I Do That?
I heat press logos onto Latigo all the time. I use the the metallic stretch in gold from JSI Signs. Heavy pressure and a cool peel. I've tried scraping it off and can't. I can use acetone and remove it, but that's about it. https://shop.jsisigns.com/perfecpress-metallic-stretch-soft-foil-sheets--sheets-p10.aspx -
Thanks. Much better quality than the other copies that I found. Tom
- 14 replies
- skipped stich
- needle size
(and 2 more)
thanks. Is there a link or way to get the entire manual? I have 155 that I need to do a total adjustment to.
- 14 replies
- skipped stich
- needle size
(and 2 more)
I'd like to see the manual. Is there a way to post it to Dropbox or something so you don't have to scale it down? I could give you a Dropbox folder to put it in.
- 14 replies
- skipped stich
- needle size
(and 2 more)
I have had 1 or 2 sides from them that had a core which was hard as fiberglass and even looked like it. I could barely cut one of them with a saw Try it with a box knife and new blade. If that has a problem take it back.
The rod you get at the hardware store should be more than ample. You are talking about kids and either wood or Poly mallets I would assume. You never hit any of these with a steel hammer anyway. Yes, you mix the 2 parts in equal amounts. And only what you'll use in about 1/3 - 1/2 of the setting time. I would not suggest putting the 2 part is and mixing there. You need to premix it until it's grey. If I was going to do a bunch of these, I would take a piece of wood, drill holes that would just hold the rods, with enough space between them for the stamp to clear. Put a rod in each hole. Mix up the JB (I use Popsicle sticks) and put a small amount on the end of the rod. Then, slide the stamp on. I would work fairly quickly so that I could put something on top of the assembly and weigh it or clamp it down a bit. Just so you don't loose the adhesion from expansion. A couple of things,,, The rods need to be pretty straight out of the stamp. As close to a right angle as possible. if the rod is a tight fit, don't put hardly JB in the bottom. It is thick and a tight fit won't allow it to spread up the shaft. This is fine as you will put more around the outside where the rod and stamp meet. You just don't want a slug of JB in the bottom of the hole and almost no rod in the hole <g>... Make sure you wipe the tstamp hole and rod down with something to remove any oil or grease before assembly. Good luck
Take a stamp of each size to Home Depot ot Lowes or other hardware store and find the proper steel rod to fit. Cut it to lengths that match the "real" handles. Grind off any rough or sharp edges on the top end. You may be able to get a small machine shop to donate time to do the cutting and grinding. Or a parent who has the appropriate tools at home Use JB Weld to put a SMALL dab in the hole. Then spread some around the junction of the shaft and the top of the stamp. Once dry, it's not coming apart. Oh.. Be sure to use the regular stuff. It takes longer to set, but it gives you more working time. Even still, don't mix more than you can apply in about 3 or 4 minutes.
I've used OTB for years and never felt gouged. They now offer USPS flat rates, so lighter items should be less. I ordered a bunch of brass buckles and Dee rings a while back and I think it cost around $11 in a flat rate. Yeah.. Buckle guy has some good stuff, but I balk at a $5 handling fee. I usually have a $1 handling fee added in automatically, but that's just to cover my direct envelope and "label" costs. I don;t feel that I should make a profit on the shipping. Oh.. try cdw plus.. They don't carry a whole lot but are a good source for low quantities and prices include S&H. Mainly they have snap swivels, Dee's round rings and such. Plus they have some plastic stuff. http://cdwplus.com/
Various sized rivets, different base-same head?
TomG replied to Mocivnik's topic in How Do I Do That?
I think it's the Leatherworkers Manual, or the Leather Tools book, they show how to cut down longer rivets to size. I'm out of town right now but maybe someone else has a copy and can confirm which one and maybe even post the picture. -
Oh yeah. That's why I'm so puzzled. The only thing I can figure out is that I am putting a hell.of a lot of torque on them screwing them in so maybe when they stripped out.
Not shrinkage. He said they are coming out. He resells them, so...
Yeah.. I've done th e Loctite Blue and the superglue, but this customer says they keep coming loose. I think he's not being 100 percent straight with me, so Red it is. If he still loses screws, then he's fired. I've already done that once but he can't find anyone else stupid enough to do these so I took o e more order from him. Already regretting it
That's the one. I think I got mine for around $20 on sale
After Fredk's suggestion, put it in a room with an Ozone generator for a few hours. Make sure no one is around to breathe the ozone
Oh yeah.. He's paying for the change. Damn near as much as new leashes. But, if I can remove the screws relatively quickly, it will be the easier method for me.
Tried that. It gets so hot it starts to burn the leather. But.. I think I found a solution, but haven't tried it in the shop yet. I clamped the screw as tight as I could get it in the Weaver tool, held a heavy flat blade screwdriver between my legs and engaged the screw head. Used a 5/16" drill bit in my small cordless and was able to drill through he smooth side and it popped off. Now to rig a table vise to hold the bit, And use the drill press. I don't like a spinning drill that close to the jewels or femoral artery.... Thought of that, but it's a proprietary design, complete with a gold logo, so I'd still have to unscrew one end at least to modify it away from his design.
I have made a half dozen specialized leashes for a customer and they decided that they now want nickle hardware instead of brass. Unfortunately, I used Red Loctite instead of blue because on a couple of previous orders, he had "claimed" that some of the screws came loose. I personally find this a but hard to believe because they all had the blue Loctite and were installed using a Weaver screw clamp and a power screwdriver. So my question is how do I remove the brass screws? I've tried using a 3/8 drill in my drill press, but part way into the head, it spins. I tried a cutting chisel, but the leather layers(3) are so tight I can't get the chisel in and even if I did, the bottom edge of the leather would probably cushion it so much the chisel would not work. My next attempt is using a dremel grinder, but that seems sort of doomed to fail, but what do I have to loose. Oh, yeah... No, I can't just cut the ends off and redo it. The leash would be way too short.
I make these all the time. Go on eBay and look for this: slotted straight flat tip punch. They are Chinese made tools. you'll probably have to sharpen and stop them, but they do the job Tom
Thanks all. I expected as much. And Wiz, I know you are one of the sewing Gurus, so I was hoping that you'd chime in I'm very happy with the 227 and I don;t have a whole lot of call for the 207 and up sizes, but it would be nice to do it once in a while. I had a job recently restitching some leather furniture, and it used 386, I think, and I had to hand stitch everything. Took about 20 hours. LOTS of stitching... Anyway, thanks for the input. Later
I'm sorry if this has been covered (probably has ) and I just couldn't find it. What determines the largest thread a particular machine can handle? I have a Consew 227R-2 and 138 top and bottom is about it. I'd like to be able to sew 207 or 277 but not sure if there is a trick or a mod that will allow it. Thanks
This is a 24" US Robotics Laserpoint 1. The blue tape is great for all kinds of stuff. I've never had it leave any residue either. The only problem I've ever had using it on leather is if I apply it to the flesh side to say, keep antiquing off the back, when I pull i off it really fluffs up the flesh side fibers on a lot of pieces. I also am using a thin plastic sheet with the spray adhesive. But since the cutter uses a pretty good amount of force as it cuts and the vinyl cutter is designed for the vinyl to drape over the cutting bed, the leather tends to peel loose unless it's taped down. and cut Sloooooooooowwwwwwww
Denatured Alcohol. About $10 a gallon at the hardware store
