Northmount
Moderator
  1. My comments work for a typical machine. Never used an Aerostich, and recognize that its operation is mostly on/off type thing. So I'm not sure how you would manage ensuring the hook has caught the thread before turning. Look at his video at 4 minutes to see how to turn 90 degrees. He also mentions a needle down operation for lining up with a hole or position earlier in the video. Hope this is of some help to you. I notice some other videos too but haven't looked at them. Tom
  2. Needle should be down, but starting to rise, maybe a 1/4", so the hook has grabbed the top thread so you don't get a skipped stitch. Don't raise the foot so far that it releases the top tension. Turn piece 90 degrees and keep going. Tom
  3. Northmount
    Value
    A photo might help people visualize what you have and enable them to make comments. It would be nice to know where you are from or where you obtained them. That could help too! Tom
  4. To do this type of repair without disassembly, the part needs to be turned on a lathe, then a diagonal cut made through the new piece, then glued into place with the diagonal cut carefully aligned. A careful job will leave just a hairline where the diagonal cut was. Tom
  5. @laether Lots of post about servos. Try a google search "site:leatherworker.net servo" without the quotes. Add additional words to refine your search. Tom
  6. @tieflyer Please read and conform to the Market Place rules http://leatherworker.net/forum/forum/70-announcements/ Add photos and full description. Thanks. Tom
  7. Northmount
    Australia
    @teatree I assume you are requesting help with a sewing machine. Perhaps you could provide a bit more information such as the type of machine and what you need. I'll leave the post here for the time being until we hear back from you, but think it would get more attention if it was placed in the sewing machine forum. Tom
  8. You are probably trying to push the presser foot through the plate or feed dogs. I would suggest that instead of randomly trying these adjustments, you obtain the service/instruction manual and go through the complete setup, starting witht he outlined sequence. It must be making more noise as it runs as well instead of a nice smooth operation. Tom
  9. @levinus Moved to Home > Marketplace > Items For Sale > Hand Tools-Leatherworking Tools Tom
  10. @SStrey Moved to Fabrication > Leather Machinery Tom
  11. Industrial strength is a mis-nomer. It's just a old steel domestic. Have you read this post? Tom
  12. @GaryTullos Up to about 3/8" roughly. Tom
  13. @Patti Moved to marketplace ... Tom
  14. @LeHoang @mattattenborough Matt hasn't been active since Nov 22, 2017. Only a single post. Tom
  15. Switch directions after the needle has risen maybe a 1/2", but before it rises above the surface of the leather. Reversing directions before the hook has caught the loop may result in a skipped stitch and a bird's nest on the bottom. Tom Edit: That should be 1/4"
  16. I have found places that sell quantity lots, so instead, went and bought a binder with the size of rings I wanted and took them out and trashed the cheap cover. Tom
  17. Depends a lot on what you are looking for. What type of patterns? Bags, holsters, carving/tooling, Etc. http://www.bighousedaddy.com/ is one that came up recently on another thread. Tom
  18. Have a great retirement. Pop in once in a while for an update. Show off the kids and any new leather items. We appreciate your work and advice. Tom
  19. Marketplace > items for sale > machinery - sewing and stitching Tom
  20. @ljk moved to > market place > items for sale .... Deleted double post Tom
  21. As Dwight says above, " The key is the insulation. The building has a minimum of 4 inches of styrofoam insulation in the walls and 6 inches in the ceiling and the floors. " Foamed-in-place insulation is the best bet, reduces air infiltration and exfiltration. My son's workshop uses foam insulation, drywall on the walls, open ceiling, 14" high ceiling, open trusses. Uses nat gas radiant heating, leaves the temperature set at 40 F when not working. Sets up to 65 or so when he is working in it. Shop is comfortable, and stays dry except when bringing his tractor inside after moving snow. Then it takes time to remove the moisture to due to how well sealed the shop is. Remember with radiant heating, only what is exposed to the radiant tube receives direct heat. Convection from those surfaces does the rest. He really doesn't notice the cost of heating the shop due to how well it is insulated. Winter in his location is down to -40. Adequate insulation really makes the biggest difference to comfort and utility costs. Foamed-in-place insulation done right can eliminate the cold steel or wood bridging from outside to inside. I don't believe you will have problems with leather drying out anymore than with other heating systems, as long as it is not too close to the radiant tube. Tom
  22. Please include photos. Your IP address indicates you are near South Fork ... for anyone looking for a more precise location. Tom
  23. @Mizzy I moved your post to Leather Sewing Machines. Will get more exposure to members in the know. What a find, and from what I understand, unusual to find many used machines in Australia. I see from your IP address that you are in New South Wales. Tom
  24. The thing you apparently don't use to iron (press) your shirt or pants. Tom
