If you reverse at the wrong point in the stitch cycle, you may loose the loop that was being formed. Try making sure the needle is on it's upstroke (after the hook has caught the loop). Tom
His IP address is located in Franklin Ohio Tom
- 7 replies
- stitcher
- sewing machine
(and 1 more)
Yes, share some more info with us. Text, photos, whatever. Thanks Tom
I'd make a new top. 2 layers of 3/4" plywood or MDF with Arborite or other laminate on top. Much less problem than filling the space. Allows you to place motor and machine where it fits best for you. Rout out a ledge for the machine to sit in. Hinges on a flatbed are handy but not necessary, but are nice to have. Tom
Made a stitching awl and... ruined it with linseed oil
Northmount replied to DrmCa's topic in Leather Tools
What I was taught many years ago is not quite true! It is a combination of raw and heated oil. Just looked it up in Wikipedia to refresh my memory. https://en.wikipedia.org/wiki/Linseed_oil Quoted ........................................ Stand oil Stand oil is generated by heating linseed oil near 300 °C for a few days in the complete absence of air. Under these conditions, the polyunsaturated fatty esters convert to conjugated dienes, which then undergo Diels-Alder reactions, leading to crosslinking. The product, which is highly viscous, gives highly uniform coatings that "dry" to more elastic coatings than linseed oil itself. Soybean oil can be treated similarly, but converts more slowly. On the other hand, tung oil converts very quickly, being complete in minutes at 260 °C. Coatings prepared from stand oils are less prone to yellowing than are coatings derived from the parent oils.[19] Boiled linseed oil Boiled linseed oil is a combination of raw linseed oil, stand oil (see above), and metallic dryers (catalysts to accelerate drying).[19] In the Medieval era, linseed oil was boiled with lead oxide (litharge) to give a product called boiled linseed oil.[20][page needed] The lead oxide forms lead "soaps" (lead oxide is alkaline) which promotes hardening (polymerisation) of linseed oil by reaction with atmospheric oxygen. Heating shortens its drying time. End Quote ............................................. Tom -
It is never boiled. It is treated with additional chemicals including drying agents that help it dry faster. Many of the same driers as used in oil based paints. Boiled Linseed Oil is really a misnomer. Tom -
Moved your post to "Leather Sewing Machines". Please take a look at pinned topics like Tom
Wipe it down with a solvent such as varsol or other paint thinner for oil based paints. Might have to do that 2 or 3 times to remove the sticky partially set BLO. Tom -
And the photos are? And your location appears to be Huntley Illinois according to your IP address? Tom
Wow! Great work! Tom
Hi Uwe Is the pin supporting the latch (or pawl) an eccentric? Where there happens to be 2 lock screws, there isn't likely a flat on the pin so 2 screws to make sure the pin stays in position. Just a guess, but you are the fellow to investigate ... and can avoid having to grind the latch if such is the case. (I used to work on a lot of mechanical accounting machines in the ancient past. There were many eccentrics to adjust!) Tom
- 10 replies
I have used Kydex to make clips that hold the phone, either wrapped around the sides or top to bottom. Heat formed it, and cemented it to the leather case. I have used a wallet style that flips up to open or like a book cover that flips to the left side. I think the book type is more user friendly and shields the ear from some of the ambient noise. There are also photos here somewhere that show the ruggedized case cemented or riveted to a leather wallet cover. Some ideas for you. I might use that Nano Suction stuff for the next one instead of clips. Tom
If you so a search for "iphone 10 specification" (or other make and model), you will find a link like this https://www.apple.com/ca/iphone-x/specs/ It will give the dimensions so you can build to fit. You can print actual size and even get the proper radius for the corners. I have made wooden blocks the same size as the specifications so I could wet mold a case to fit. Tandy has some self adhesive tacky stuff now that you can adhere to the leather and just press against the phone's back to hold it in place. Got a piece on sale a while ago, have yet to make anything using it. It's called "Nano Suction Sheet". https://www.tandyleather.com/en/product/nano-suction-sheet-8-1-2-x-11-x-1-mm-216-x-279-x-1-mm Tom
Grind or file the tip off the set screw, or as above, grind or file a flat on the blade shaft. Tom
Moved to "The Business > Suppliers" Tom
Closed shop- exotic leather scrap - best offer
Northmount replied to Patti's topic in Leatherwork Conversation
Click on your user name at the top right corner. Pick Profile and go to it. Tom- 11 replies
- turkey feet
- lizard
- (and 4 more)
Contains good info about this type of machine that others may find useful. So we don't like to delete threads like this. Tom
Stick Barrette
Northmount replied to D2G's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
You can reduce your file size (resolution) and be able to post many photos in a single post. 800 x 600 resolution is adequate. Tom -
If it is manually oiled, you should oil the machine everyday with heavy use. It it sits for days without any usage, should oil it before use, unless it is only for a 5 minute job. If so, you can stretch out oiling somewhat. Tom
- 10 replies
- pfaff
- pfaff 335 h3
(and 1 more)
You need to start with an approximate diameter that you would like to end up with. Calculate the circumference = 3.14 x diameter. Divide the circumference by your stamp length 0.8 mm. (pretty small stamp) Round the number up or down to a whole number. Use that as you new circumference. Divide by 3.14 to get your new diameter. Tom
OP appears to be in Maine USA according to the IP address. It would be great if members could add their location to their profile. Tom- 11 replies
- turkey feet
- lizard
- (and 4 more)
Hand tooled/stitched chinks
Northmount replied to jsangl's topic in Clothing, Jackets, Vests and Chaps
@jsangl Very nice work. If you resize your photos, you will be able to upload many more at a time. 800 x 600 pixels is adequate. At that resolution you could add maybe 100 photos in one post. Lower resolution photos are good for people that live on the fringes of the internet with slow connections. One lady I know would open her webmail and go do something else for half an hour or more while it was loading her email. Tom -
Rather than stuff a bunch of off topic photos into this thread, do a google search "site:leatherworker.net stitchless" without the quotes. You will find a number of photos as well as some distractors like a triangular coin purse! Tom
Been a while :)
Northmount replied to geordieracer's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
@geordieracer Very nice work. You can resize your photos to a lower resolution and be able to post many more at a time. 800 x 600 pixels is quite adequate for viewing here. Saves on upload and download time for people with slow network connections too. Tom -
I've seen a purse and a knife sheath done this way. The people called it stitchless. Tom
