If the leather is lifting the presser foot up, the presser foot spring needs to be tightened down more to overcome the leather sticking to the needle. Now if there is glue or something else causing the leather to stick to the needle, then of course you should go to the root cause and fix it. But, if you are sewing heavy stiff leather, heavier and stiffer than what you usually use, you will have to increase the presser foot spring pressure. Or get soft leather! Tom
@aguwa Really, six posts! Please only click on the submit/post button once and wait for the server to respond. Could be a slow network connections, slow device browser, busy server, etc. All good things take time. I'm deleting the other posts. Tom
@Game Moved to Sewing Machines forum. Tom
OP appears to be in the Willoughby, Ohio, 44094 area according to his/her IP address. Tom
If we ignore power factor for alternating current circuits, you can do a quick comparison of power by multiplying volts x amperes. Assuming unity power factor (which it isn't), VA would equal Watts. (And 1 horsepower = 746 Watts if you want to look at hp instead.) 240 x 1 = 240 VA 110 x 1.5 = 165 VA So obviously your 240 volt 1 amp motor is more powerful than the 110 volt 1.5 amp motor. Tom Edit: Motor you referenced is 180 W. Therefore PF = 180 / 240 = 0.75. PF of AC motors is typically 0.5 to 0.8. But again, just the VA comparison is adequate for many cases, including yours.
Converted the jpeg file to a PDF to make it easier to read and print out. Great tutorial. I've been thinking of trying it out. Maybe after current projects are done. Tom Leather_Mask_Making_Tutorial_by_Ranasp.pdf
Advice for cylinder arm machine for sewing saddlebags
Northmount replied to sam000lee's topic in Leather Sewing Machines
New comes with a warranty and support. I my mind, that is too much for an old machine with a clutch motor that you are going to hate. Get one that is setup to use 138 or heavier thread. Tom -
Only the pattern is copyright. You can make as many as you want for sale or gifts. You just can't copy and sell the pattern. Tom
Terry's 141 MB PPT file converted to pdf, 8.8 MB. As noted above, it contains screen shoots from various web sources. Trunk Build Images.pdf Tom
@sold2018Need photos, shipping etc. Please read the marketplace rules and update your post. http://leatherworker.net/forum/forum/70-announcements/ Tom
Looks great. I like the colourful stones! Tom
40W Chinese Laser - Engrave and Cut Leather - Discuss
Northmount replied to Billy Hell's topic in 3D Printers and Lasers
Will not be USB powered as it uses far more power than the USB port can supply. It should have USB connectivity for programming and operation. Tom -
IP address resolves to Sydney. Tom
Sapphire swivel knife sharpener
Northmount replied to Hasbeencowboy's topic in Patterns and Templates
photos might help Tom -
@Reddturtle moved to leather sewing machines. You should get more responses from the experts here. Tom
leather techniques Secrets from the Workshop
Northmount replied to Dangerous Beans's topic in How Do I Do That?
Plus 1. Really helpful to drop all background noise that does not contribute to the purpose of the video. Tom- 34 replies
- saddle stitch
- creasing
- (and 12 more)
When installing zippers, make sure the centre of each side of the zipper lines up with the centre of the edge it is being stitched to. So staple or tack or what ever method you use to hold things in place before sewing, starting at the centre and working both directions for both sides. It helps prevent skewing the zipper and making it hard to zip up as it is fighting with the heavier leather on each side. Tom
Try this "Flat Plate Open Three-Way". I'm no saddle expert at all, but found it at http://www.saddleonline.com/blogs/content/different-styles-western-saddle-rigging Did a Google searched for "saddle rigging ring dee plate" trying to catch the different terms I have seen. Also found this. It references 3 way plate and a source. And take a look at the bottom picture on this page. They may be able to tell you where they source them. http://www.madisonsaddlery.com/saddle.html Tom
These are the settings that work for me. For some period of time, I wasn't receiving any email notifications. I don't remember which setting I changed. I suspect it was "Send me news and information" Tom
If you are making a 2 layer collar (lined) add a strip of poly webbing between the layers. It won't stretch and therefore the collar will retain its shape better when subjected to water and other abuses. There are some other posts about eliminating the stretch problem somewhere here if you wish to search for them. Tom
Unplug it, leave it sit for a while, then try again. May have to re-do the setup. This happened to someone else on the forum, but don't remember who or when. Another party had damage due to lightning strike nearby when it was left turned on. Some electronics seem to be very sensitive to power line transients. Good luck/ Tom
Looks like it was folded/bent tight towards the flesh side. That stretches the grain side, and when released, wrinkles the grain side. Tom
Looks to me like it was done with an embossing roll. Don't see any joins that you would normally see if it was stamped. Tom
@RB12 If you are not wanting to use foil to make coloured impressions, you can use it cold to make impressions in veg tan leather. You can also use it hot without foil to burn an impression into many types of leather. It will need to be able to operate at a higher temperature to burn impressions. You can have a die made by a photo engraving process, or by CNC milling, or other processes and use an arbour press to stamp veg tan. There are lots of routes to go. Do a search for hot foil press here on leatherworker.net and you will find several threads with more information. Tom
You could purchase an eBook from Tandy that describes the use of several tools. https://www.leathercraftlibrary.com/p-1141-leathercraft-tools-by-al-stohlman.aspx There a a number of other helpful books there too. Tandy and YouTube have a lot of videos describing tooling and how to do it. If you are close to a Tandy store, you could check to see when they have free tooling classes. Tom
